To Web Master
Robbo09/08/2009 21:36:47
1504 forum posts
142 photos
Hi David Edwards2.    Using the MyHobbyStore website, there is no list of back issues available.   You just order  ?no of back issues and tell them the numbers in the comment box, as David Clark 1 says.      If they are not available you will get an email offering you copies of specific articles copied from the master copy.    Then it's best to phone/they will phone and you can sort it out that way.    May be best to phone in the first place, indeed, if you like talking to charming ladies then this is the way to go.
Sexist? - not me.
Trevorh20/08/2009 14:02:23
316 forum posts
89 photos
Hi,
   I have just tried to enter the back issues area only to be told that its for subscribers only
I have been a subscriber for a number of years
I entered my details including the subscription number when I first joined the web site, so why won't it let me in?
Looking at the box where you enter your number - it doesn't let you enter the full number and so I have left off the first couple of zero's
any help please
Trevorh20/08/2009 14:03:14
316 forum posts
89 photos
Sorry but just one other point
under my name what does it mean "set a status"?
David Clark 120/08/2009 14:33:05
3357 forum posts
112 photos
10 articles
Hi There
Enter the 8 digit code where the ***** are.
Ignore the 2 leading00s and everything from the R inclusive
00********R MEW153
In other words enter the numbers where the
are.
regards David
Trevorh20/08/2009 19:53:07
316 forum posts
89 photos
Ok now I'm confused
I typed in the 8 digit number in the box maked Subscrition number for MEW as I do not subscribe to the other one
I typed just the 8 numbers missing off the first 2 zero's it won't allow any more digits to be typed
saved it and it didn't make the blind bit of difference
Help
David Clark 120/08/2009 20:20:23
3357 forum posts
112 photos
10 articles
Hi There
Email me your subscriber number and name and postcode and I will get it checked on Monday.
regards David
Robbo20/08/2009 22:48:35
1504 forum posts
142 photos
Although I had entered my subscriber number when the website first started, I could'nt  access the back issues when they were put on.    When I went back to personal details and entered the number again then it worked fine.
Ian S C26/01/2010 10:53:41
7468 forum posts
230 photos
Old Lathe,Chuck accuracy.This is in the workshop Tools and Tooling section.It has no posting box,the site bottoms out after the third reply.Ian S C
Les Jones 126/01/2010 13:12:22
2292 forum posts
159 photos
Re Ian S C's report of the problem with the "Old lathe chuck" posting.
I could read it (Or part of it.) using Firefox 3.5.7 but not with IE8 or Opera.
I tried adding another reply using Firefox. With Firefox I could see this reply but with IE8 I could not. (I did not try using Opera as this is on a different plug in disk drive.) I suspect
there is some hidden character in the third reply that is causing the problem.
I think if the web master could delete this reply it may solve the problem.
Les.
David Clark 126/01/2010 13:24:53
3357 forum posts
112 photos
10 articles
Hi There
I will try and get it sorted.
I can't get to the bottom of the post to delete it.
regards David
Les Jones 126/01/2010 14:44:59
2292 forum posts
159 photos
Hi David,
                 I can see that you have managed  to delete what was the third reply. The problem now seems to have moved to just after the last character of my test reply. The bottom slightly darker grey box which normally contains "Message members" etc is missing.
This is using IE8. Using Firefox  it looks OK
Les.
David Clark 126/01/2010 15:37:27
3357 forum posts
112 photos
10 articles
Hi There
Have deleted post.
Has this sorted it out?
regards david
Les Jones 126/01/2010 17:57:33
2292 forum posts
159 photos
Hi David,
                   Yes it looks like you have fixed the problem. I have not tried adding a test post but the box to enter the text is now there as is the button to post it.
I imagine problems like must eat into your time. I suspect it was not as simple as just hitting a delete button somewhere.
Les.
Ian S C29/01/2010 12:13:57
7468 forum posts
230 photos
Should I be getting two different foremats at random times, it does'nt worry me just curious. The normal format has the adds on the right side, and is the one I prefer.The second has large print, but its not so easy to find the log on box for example.Ian S C
David Clark 129/01/2010 13:18:49
3357 forum posts
112 photos
10 articles
Hi There
No, totally wrong.
You have an error somewhere.
Forward more details.
regards David
Ian S C29/01/2010 13:38:12
7468 forum posts
230 photos
David, apart from it starting last Sunday/or was it Saturday,about then, theres not really much I can say,I'v been waiting for someone else to ask,think I'll just wait and see.Thanks Ian S C
KWIL29/01/2010 14:08:02
3681 forum posts
70 photos
Ian
Whe  you have large format have you tried [Ctrl+scroll] to change/reduce the format to normal?
Edited By KWIL on 29/01/2010 14:08:24
Ian S C30/01/2010 11:16:23
7468 forum posts
230 photos
Kwil, the lay out of the two formats is totally different,they don't look related to one another apart from the fact that all the information is the same.I don't know much about computers,Iknow were Ctrl is, butscroll, is there a key for that? I tried clicking on the scroll bar on screen. Ian S C
KWIL30/01/2010 15:39:29
3681 forum posts
70 photos
Ian,
Scroll is the roller on top of some mice , the [ctrl+scroll] allows you to change magnification.
Frank Dolman30/01/2010 20:42:47
106 forum posts
     I have had this too, also at random.  It usually reverts ( perhaps"pops"
   would a better word ) to normal after a second or so but sometimes it
   lasts for a whole session
