Brief build thread
Bryan Cedar 1 | 18/06/2020 11:35:12 |
127 forum posts 4 photos | Beautiful work which I could not come near to, but should the lower pipe under the sump not be routed under the mid position pipe closer to the sump which would look much better? |
David K | 18/06/2020 13:07:42 |
258 forum posts 259 photos | Hi it is routed as the plans described , I presume this is how they route on a full size engine. Also i think the angle of the picture makes it look a little more untidy. |
Emgee | 18/06/2020 13:40:55 |
2610 forum posts 312 photos | Hi David I am not certain but guessing that on the full size any such pipes would be clipped at one or more points to avoid damage by vibration, same with fuel lines and electrical cables, not good to have any of those damaged. Nice work on the engine. Emgee Edited By Emgee on 18/06/2020 13:41:26 |
Steviegtr | 18/06/2020 14:06:28 |
![]() 2668 forum posts 352 photos | Brilliant work Love it. Steve |
David K | 19/06/2020 19:15:17 |
258 forum posts 259 photos | I milled the cooling fins on the sump underside then drilled through for the sump plate The sump plate and oil union made from stainless These are the parts to be fitted to the sump The oil feed from the pump runs through the sump before running up to the main bearing |
Steve Addy | 21/06/2020 21:00:44 |
![]() 158 forum posts 107 photos 1 articles | Lovely! Steve |
David K | 22/06/2020 15:53:05 |
258 forum posts 259 photos | While i was soldering the oil lines i cut some brass tube and made the oil filler and breather pipe. |
David K | 22/06/2020 15:59:12 |
258 forum posts 259 photos | Casting for the carburettor was a little rough looking Tried to tidy it up as much i could while opening up the float chamber and bore The float chamber is a dummy so the fuel runs directly to the jet and metered by a needle. I made these from stainless and also a brass float chamber lid and butterfly. Carb and manifold |
David K | 22/06/2020 16:17:30 |
258 forum posts 259 photos | Spark plugs , i can buy 1/4 32 plugs but they are quite expensive so i had a go at making my own. Started with some steel hex bar , Corian offcut for the insulator and some 1mm tungsten rod for the electrode. I first turned the body leaving a little extra for the electrode, i would have threaded them but i realised i did not have a 1/4 32 die so i ordered one I milled around the electrode and then undercut with a small diamond disc I then used a flat bottom cutter to drill through to the undercut and form the electrode. The body was then counterbored using a drill and leaving a taper for the insulator to seal against |
David K | 22/06/2020 16:23:44 |
258 forum posts 259 photos | The Corian being turned to fit the body and drilled through 1mm for the electrode The insulator is loctite'd in , i also left a slight 'lip' on the top of the body and this was pressed over slightly holding in the insulator. I soldered some brass thread to the tungsten ready for being loctite'd in place Finished plug |
David K | 22/06/2020 16:28:53 |
258 forum posts 259 photos | While i was in the grove i made a couple of even smaller plugs into earings for the Gf. |
Russ B | 22/06/2020 18:51:10 |
635 forum posts 34 photos | Never made spark plugs, but doesn’t Corian start melting over 100c? |
Meunier | 22/06/2020 19:00:34 |
448 forum posts 8 photos | Posted by David K on 22/06/2020 16:28:53:
While i was in the grove i made a couple of even smaller plugs into earings for the Gf. Her name wouldn't be Rosemary by any chance ? Edited By Meunier on 22/06/2020 19:01:07 |
David K | 22/06/2020 19:30:06 |
258 forum posts 259 photos | Posted by Russ B on 22/06/2020 18:51:10:
No idea but researching on the internet it would seem it has been use by others ok. If they fail i will get my wallet out and buy some.
Edited By David K on 22/06/2020 19:30:39 |
David K | 01/07/2020 20:36:06 |
258 forum posts 259 photos | A few pictures of building the engine up Camshaft Crankshaft Rods Barrels Heads |
David K | 01/07/2020 20:38:06 |
258 forum posts 259 photos | End case / oil pump Timing camshaft |
David K | 01/07/2020 20:47:15 |
258 forum posts 259 photos | Time to make a stand , i was given a chunk of alloy a while back , apparently it was used for securing power lines and i have been wandering what i could use it for. So i cut it in half with a slitting saw Then milled away to form the stand sides A couple of cross braces and engine mounts and i now have a stand . A bit unconventional but i like it. |
