Ian P | 09/03/2019 23:24:39 |
![]() 2747 forum posts 123 photos | Not cross purposes really. The precision indexing between the two halves is a given and that all make sense, what I am unclear about is how they locate the (bobbing up and down) lower half of the coupling to the same or better level of accuracy. Maybe the bottom half of the coupling is solidly mounted to the base and it is the table (with what ever is on it) that is lifted to allow rotation. Ian P |
Michael Gilligan | 09/03/2019 23:40:14 |
![]() 23121 forum posts 1360 photos | Posted by Ian P on 09/03/2019 23:24:39:
Maybe the bottom half of the coupling is solidly mounted to the base and it is the table (with what ever is on it) that is lifted to allow rotation. . That ^^^ was always my assumption ... but I may be wrong. MichaelG. . Assumption vindicated: http://www.lightglassoptics.com/7-Ultradex-Rotary-Table-Model-B_p_862.html Edited By Michael Gilligan on 10/03/2019 00:34:03 |
John McNamara | 10/03/2019 03:49:44 |
![]() 1377 forum posts 133 photos | Hi All Hirth coupling Calculator. Edited By John McNamara on 10/03/2019 03:50:11 |
Pete Rimmer | 10/03/2019 06:59:13 |
1486 forum posts 105 photos | Newbould indexers use a Hirth coupling and they are supremely repeatable. |
Michael Gilligan | 10/03/2019 08:00:17 |
![]() 23121 forum posts 1360 photos | Posted by John McNamara on 10/03/2019 03:49:44:
. That's a thing of beauty, John ...Thanks for the link. MichaelG. |
Michael Gilligan | 10/03/2019 08:22:21 |
![]() 23121 forum posts 1360 photos | Posted by Pete Rimmer on 10/03/2019 06:59:13:
Newbould indexers use a Hirth coupling ... . A little searching found this on RJ Newbould's site: **LINK** http://www.newbould.com/stainlessindexer.htm Nice device !! MichaelG. |
Michael Gilligan | 10/03/2019 10:32:54 |
![]() 23121 forum posts 1360 photos | Update: RJ Newbould made some very interesting contributions to the Pactical Machinist forum: **LINK** https://www.practicalmachinist.com/vb/general-archive/ot-mother-invention-159279/ Sadly, culminating with this thread:**LINK** https://www.practicalmachinist.com/vb/shop-management-and-owner-issues/fyi-my-exit-328594/ MichaelG. |
Andrew Johnston | 10/03/2019 10:39:22 |
![]() 7061 forum posts 719 photos | Posted by Michael Gilligan on 10/03/2019 10:32:54:
RJ Newbould made some very interesting contributions to the Pactical Machinist forum Indeed; it happens to us all eventually, but still a great shame. His posts were always a pleasure to read, informative, helpful and polite. Andrew |
AdrianR | 18/03/2019 15:09:44 |
613 forum posts 39 photos | I just found in MEW #52 an article about making a "face geared indexing table". It uses a Hirth coupling. It was cut not using any bevel so only the outer edge makes contact. In #54 Scribe a line there is further discussion about setting the correct angle to cut teeth that mesh properly. |
Michael Gilligan | 18/03/2019 15:28:27 |
![]() 23121 forum posts 1360 photos | Posted by Andrew Johnston on 10/03/2019 10:39:22:
RJ Newbould made some very interesting contributions to the Pactical Machinist forum Indeed; it happens to us all eventually, but still a great shame. His posts were always a pleasure to read, informative, helpful and polite. Andrew . Just for info. Trying to follow-up on the RJ Newbould references [see also: **LINK** https://www.model-engineer.co.uk/forums/postings.asp?th=109149&p=2 I drew a blank on the Smithsonian pages. ... So, I wrote to them asking about the 'Basic Mechanisms' collection. and received to following reply from Jennifer Gloede, Outreach & Collections Specialist, National Numismatic Collection [quote] Thank you for your email. Many objects in the engineering collection can be found here: http://americanhistory.si.edu/collections/subjects/engineering-building-and-architecture [/quote] MichaelG. Edited By Michael Gilligan on 18/03/2019 15:30:30 |
Andrew Johnston | 18/03/2019 15:32:51 |
![]() 7061 forum posts 719 photos | Posted by AdrianR on 18/03/2019 15:09:44:
It uses a Hirth coupling. It was cut not using any bevel so only the outer edge makes contact. In #54 Scribe a line there is further discussion about setting the correct angle to cut teeth that mesh properly. Err, in which case it wasn't a Hirth coupling but simply a radial spline. By definition a Hirth coupling uses tapered teeth that mate over the full length. The scribe a Line in #54 describes the mathematics to make a Hirth coupling. Andrew |
Michael Gilligan | 18/03/2019 17:46:02 |
![]() 23121 forum posts 1360 photos | Re-reading 'Scribe a Line' in MEW #54, I noticed mention of Voith ... Their portfolio is impressive: **LINK** http://voith.com/corp-en/hirth-couplings/hirth-rings.html MichaelG. |
