Michael Gilligan | 17/01/2016 11:00:56 |
![]() 23121 forum posts 1360 photos | Russell, I know [or at least believe] that you are just being provocative 'for the sport of it', but I would just like to make a couple of points before we let the thread get back on track:
MichaelG. |
Jon | 17/01/2016 19:34:15 |
1001 forum posts 49 photos | Posted by bodge on 17/01/2016 05:29:35:
It seems there must be some regulation somewhere for Garrys op, found this on one site Walther LP 300 air cylinder 300 bar - Reduced from £140 to £40 due to "time expired" . Would have thought it would come under the same regs as a diving bottle, No regulations for removable cylinders below 500cc as what Shaun stated 3 days ago. Therefore the scuba IDAS testing wont apply but can be done as a one off if you supplied the fittings to go on to their test equipment.
garrygun | 17/01/2016 21:13:51 |
70 forum posts | Thank you guys, didnt expect to get this much response this has been of great help. as you can see, bodge has found a walther unit £140. thats probably the price of a 7ltr diving cylinder very expensive, thats why i started to make these cyls, until the testing obstacle arose, think i might get there now with the forum help. Cheers.. |
David Jupp | 18/01/2016 07:54:12 |
978 forum posts 26 photos | Re the 'don't use beyond' date on some Aluminium pressure vessels. For those not familiar with fatigue life charts, whilst steels will show infinite fatigue life if stress is below some minimum value, this is not the case for aluminium where fatigue will proceed even at very low stress levels. Basically you can't totally design fatigue out of an aluminium item that is subject to cyclic loading. Where monitoring number of pressure cycles is impractical, inspection is difficult (or expensive compared to replacing the item with new), a rate of applying pressure cycles will be assumed and used to calculate an end of useful life date. I've recently seen such expiry dates on hydrogen cylinders (fuel tanks) for fuel cell powered vehicles. |
Michael Gilligan | 18/01/2016 10:26:01 |
![]() 23121 forum posts 1360 photos | Posted by David Jupp on 18/01/2016 07:54:12:
Re the 'don't use beyond' date on some Aluminium pressure vessels. For those not familiar with fatigue life charts, whilst steels will show infinite fatigue life if stress is below some minimum value, this is not the case for aluminium where fatigue will proceed even at very low stress levels. Basically you can't totally design fatigue out of an aluminium item that is subject to cyclic loading. Where monitoring number of pressure cycles is impractical, inspection is difficult (or expensive compared to replacing the item with new), a rate of applying pressure cycles will be assumed and used to calculate an end of useful life date. I've recently seen such expiry dates on hydrogen cylinders (fuel tanks) for fuel cell powered vehicles. . That's a VERY useful summary, David Thank You. MichaelG. |
Martin Connelly | 18/01/2016 10:42:05 |
![]() 2549 forum posts 235 photos | Jon, the most recent interpretation of the PED that I have seen is that the 1 1/2 times test pressure should be applied to the safety valve release pressure not the operating pressure. This makes the test pressure higher than just using expected working pressure as your starting point so is a more rigorous test. It is because it is possible for the operating pressure to be at fault at higher than nominal pressure and the system can still work as normal. Martin |
Neil Wyatt | 18/01/2016 10:48:48 |
![]() 19226 forum posts 749 photos 86 articles | > Basically you can't totally design fatigue out of an aluminium item that is subject to cyclic loading. Such as a DeHavilland Comet I do worry about the first generation of alloy mountain bike frames... I wouldn't hurl myself down a hillside on one from the early 1990s. Neil |
Michael Gilligan | 18/01/2016 11:15:01 |
![]() 23121 forum posts 1360 photos | The move by SodaStream [10 or more years ago], from Steel to Aluminium cylinders is of some interest. There was presumably some clear business advantage to this, but the safety aspects are a little worrying. ... The company makes it reasonably clear that the cylinders are rented, not sold, and that they should not be unofficially re-filled ... but that does happen. I would be grateful for any comment from the wise ... Does SodaStream individually test the returned cylinders, or scrap them when time-expired, or what ? MichaelG. . P.S. I have a sufficient supply of the old Steel cylinders to meet my needs; but the question is generally relevant to this discussion. |
Michael Gilligan | 18/01/2016 11:20:00 |
![]() 23121 forum posts 1360 photos | Posted by Neil Wyatt on 18/01/2016 10:48:48:
Such as a DeHavilland Comet MichaelG. . P.S. Follow the hyperlinks ... there are some great pictures. Edited By Michael Gilligan on 18/01/2016 11:23:30 |
Neil Wyatt | 18/01/2016 12:08:10 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Michael Gilligan on 18/01/2016 11:20:00:
Such as a DeHavilland Comet Thanks! When I was a boy I wanted to work at the RAE doing exactly that - putting together crashed planes to work ou what had gone wrong. Neil |
David Jupp | 18/01/2016 14:39:31 |
978 forum posts 26 photos | Michael, RE Sodastream cylinders. I have no specific knowledge but;- 1. Just because it is possible to design an item in steel with infinite fatigue life, that doesn't mean that approach was taken - could just as easily have been designed for a safe life of a certain (large) number of cycles. 2. Steel is generally more vulnerable to corrosion than Aluminium is, internal corrosion of steel vessels is an inspection headache. External corrosion is a problem too. 3. Probably other factors to consider too, like resilience when dropped or otherwise mis-handled. Without more detailed information it's difficult to reach any conclusion about any potential differences in safety levels between cylinder types and their associated inspection regimes. |
Michael Gilligan | 18/01/2016 14:58:39 |
![]() 23121 forum posts 1360 photos | Thanks, David ... That's useful comment. The old SodaStream cylinders were very heavily built [for their capacity] and, rightly or wrongly, I feel 'comfortable' with them. ... They are a useful benchtop source of compressed gas. If I understand correctly, the move to Aluminium coincided with the change to a proprietary screw fitting and the introduction of some strict licencing rules. [probably as a defence against Product Liability claims] Despite which: Adapters are widely available, and therefore people can and do refill the Aluminium cylinders. MichaelG. . Edit: This is the sort of 'information' that worries me ... [quote]
Edited By Michael Gilligan on 18/01/2016 15:07:38 |
jason udall | 18/01/2016 15:40:10 |
2032 forum posts 41 photos | Gentlemen. It appears that you have discovered one of the important principles of modern life. For example. Design/ build /test vessel to given pressure both working and safety levels.. Readily achieved. .. Negotiate "relavent " standards.. ( esp. Identify said standards)...not so easy. I have this from my day job with low voltage / emc/machinery "directives"...buckets of test houses that will take your (modest ![]() But sign off to a directive..nfc..."we just test the tests you ask for. .up to you to chose the test criteria".and make the declaration. .. * nfc ...relates to low probability. .. Edited By jason udall on 18/01/2016 15:43:18 |
jason udall | 18/01/2016 15:40:44 |
2032 forum posts 41 photos | Love this forum sw Edited By jason udall on 18/01/2016 15:41:49 |
