A variable Lead threading attachment. Author Ted McDuffie
Article in MEW ??? published Autumn 1990
Ady116/06/2013 02:29:57
6137 forum posts
893 photos
Will it do metric threads on an imperial lathe? Will the dial indicator work?
Edited By Ady1 on 16/06/2013 02:33:47
Bazyle16/06/2013 10:48:18
6956 forum posts
229 photos
Jaques, Thanks for the dual language titles on your video. I am learning some new French words.
I somehow missed the ME article in 2006 so am glad this came up. It looks very useful for old lathes where most of the change wheels have gone missing and there never were metric combinations anyway. The error shouldn't matter since I find most threads are at most only 2 nuts long.
Stub Mandrel16/06/2013 16:55:36
4318 forum posts
291 photos
1 articles
Hi Mike,
i was musing on whether or not the errors intoruced by using imperfect gear ratios are significant enough to warrant using such a device for fasteners and otehr threads that just need to work, rather than be highly accurate (as in a micrometer stop, leadscrew or similar).
jacques maurel16/06/2013 21:37:15
84 forum posts
20 photos
The anwer to the 2 questions of Ady 1 is yes.
Answer to Michael Williams: the drawing 1 is just here to explain the principle.
J Maurel
Ady118/06/2013 03:11:03
6137 forum posts
893 photos
I had a feeling about this gadget and ran it through some animation software I have
The problem is that the parallelogram describes an arc as it moves... but the slide won't let it do that and forces the cutting tool part of the unit to move in a parallel fashion... so the geometry either jams up or something has to give(break)
The only solution I can see is where the little arm bolts to the big arm, you need a slot, not a hole, for that bolt as the geometry alters, and this may mess up the thread
It's a bit like a shaper drive, there's a slight arc as the drive powers the shaper head and they use a slot, not a hole, at the top of the drive
Anyway, if anyone ever builds one of these things for real... then we'll find out
jacques maurel18/06/2013 14:06:09
84 forum posts
20 photos
I've made a sofware simulation using Solidworks and the kinematics application motionworks, with the example already given (20 tpi from 1mm standard lead) the error for 90 mm thread length machined is about 0.004mm, less than the lead screw tolerance!
J Maurel
jacques maurel07/07/2013 18:53:12
84 forum posts
20 photos
I've made a short video showing the attachment at work: cutting a 3/4" BSP thread (14TPI) on a metric lathe (actual lead 1.5mm).
J Maurel
jacques maurel09/07/2013 17:08:22
84 forum posts
20 photos
Here is a link to my website, I've gathered some informations on the attachment and there is a drawing and a photo showing a threading machine from the eighteenth century using the same principle: **LINK**
J Maurel
Gary Wooding11/07/2013 07:36:26
1074 forum posts
290 photos
Posted by Ady1 on 18/06/2013 03:11:03:
I think you're wrong, because it's not a parallelogram at all. The schematic diagram is not particularly good, and is certainly not clear.
Point D is attached to the saddle via the topslide, and item 2, which holds the tool, slides across it as the lever AC rotates about point C. The link DB (item 4) is is free to rotate at both ends, so, although the vertical distance between point D and item 2 remains constant, the vertical distance between points A and B reduces as the lever rotates about point B, as does the vertical distance between points C and A.
Ted Clarke14/07/2013 14:53:41
1 forum posts
I have built a version of McDuffie's inventrion and checked its accuracy. My version is described in my article for the web journal Modern Microscopy: **LINK**
Ted
Marcus Bowman13/08/2014 19:24:55
196 forum posts
2 photos
Jacques,
I have sent you a PM.
Marcus
Ady114/08/2014 01:27:08
6137 forum posts
893 photos
I'm still not convinced about this
Anyone got it to the stage where you slap it on the lathe and run a thread out yet?
Neil Lickfold14/08/2014 03:00:07
1025 forum posts
204 photos
Jacques,
So if the sliding tool holder was set on angle, would it then be possible to turn tapered threads?
Have you got pictures showing your setup without the chip cover ?
Neil Wyatt14/08/2014 14:14:42
19226 forum posts
749 photos
86 articles
Has anyone got a spare copy of the issue of MEW with this in?
Ted would dearly like to have a copy, but there are no back issues left.
Please pm me or email if you can help.
Neil Wyatt14/08/2014 15:33:24
19226 forum posts
749 photos
86 articles
My apologies, and thanks to those who have already replied. I should make it clear it is Ted Clarke who needs a copy of the MEW with his article, "Adjustable Threading Feed Attachment for the Lathe" it is Issue 204, not Ted McDuffie who wrote the earlier article.
I have asked before, but if anyone does have a paper copy, please do let me know.
Brian Wood14/08/2014 16:52:02
2742 forum posts
39 photos
Hello Neil,
Does he want the whole magazine or just a copy of his article?.
I don't want to part with my copy, but I am quite willingly to scan and email from it.
Regards Brian
Neil Wyatt14/08/2014 19:01:16
19226 forum posts
749 photos
86 articles
He wants a paper copy. thanks for the offer.
