Torsion Spring
Stub Mandrel17/04/2013 20:07:08
4318 forum posts
291 photos
1 articles
On piano/music wire, I have an 'L shaped' bit of 16swg wire I use for poking crud out of the spray bar on the dishwasher after svereal years of damp but intermittent use it has a few small rust stains on it, though it is very dull and clearly not stainless.
Does anyone know what type of steel is used for piano wire?
Jeff Dayman17/04/2013 20:28:49
2356 forum posts
47 photos
Hi Neil,
I remembered it was ASTM A228 in US and Canada, but realized that spec wouldn't likely mean much to folks in UK or Yurrup. I googled it and found the following link to a PDF.
Note the composition does vary a little in the % of alloying elements from std to std so piano wire is similar spec around the world but not exactly the same spec.
I doubt the spec variation would mean much to your dishwasher crud poker wire but it might to a springmaker.
JD
Edited By Jeff Dayman on 17/04/2013 20:30:38
Stub Mandrel17/04/2013 20:58:20
4318 forum posts
291 photos
1 articles
Thanks Jeff,
So it's a fairly standard carbon steel, but it does seem to have good corrosion resistance.
Rufus Roughcut17/04/2013 21:26:38
83 forum posts
20 photos
Hi Ian R4
Would you not be better using new on each side of latch bar as per your edited pic, which would unburden the single spring a bit.
Barry
Jeff Dayman17/04/2013 21:33:15
2356 forum posts
47 photos
Hi Neil,
In my experience piano wire does not do well in damp environments. In industry I was involved with two major corrosion related incidents with piano wire parts. One was in valves for hydronic home heating, the other in photocopiers. Both involved severe corrosion in just a few weeks regardless of heavy grease coatings on the wire. Several hundred thousand wire parts failed in the valve case, and tens of thousands in the photocopier case, and had to be dealt with in both cases at huge expense to the firms. The piano wire was mandated originally as a cost down measure vs our design dept's original spec of stainless wire, by the forensic accountants in the purchasing depts. Didn't work out that way! I'm gunshy about piano wire if there is damp conditions, as a result of these experiences.
JD
Stub Mandrel17/04/2013 21:37:38
4318 forum posts
291 photos
1 articles
Interesting Jeff,
It seems it is good with occasional exposure (dishwasher pokers and model aircraft bits), but can't take sustained life in a damp environment.
Ian S C18/04/2013 11:40:47
7468 forum posts
230 photos
Would not have thought a photocopier would be concidered a DAMP enviroment. Ian S C
Jeff Dayman18/04/2013 12:08:23
2356 forum posts
47 photos
Hi Ian,
Photocopiers are used in all environments worldwide. Some are dry, some are damp, hot,cold etc. One of the big challenges designing that type of equipment is making it reliable in the varying conditions, as the behaviours of paper and static electricity vary widely with environment. The major piano wire corrosion problems occurred in machines primarily in South America, Vietnam and Thailand.
JD
Stub Mandrel18/04/2013 21:21:11
4318 forum posts
291 photos
1 articles
I've been told that paper is one of the most difficult materials to handle automatically.
Ten years ago, our paper used to come with an arrow on it so you could put it in the machines the right way up, wrong way and it would soon misfeed. It's to do with the curl of the original roll.
Funnily enough the paper we get now ssems to be 'omni-directional'.
Rufus Roughcut18/04/2013 21:52:44
83 forum posts
20 photos
That's because its made flat primarily in South America, Vietnam and Thailand which are much nearer the equator so dosn't realy know which way to roll.
Barry
Had a go with TIG 1.5mm stainless weld wire at work, for spring warmed it a bit when bent and quenched quick and seemed a sturdy spring, was a blueish hue when i quenched.
Ian Robinson 419/04/2013 08:09:07
20 forum posts
3 photos
Posted by Rufus Roughcut on 17/04/2013 21:26:38:
Hi Ian R4
Barry
I think that 2 would better. You have also bent the end which, looking at the photo of the old spring [see album], there is a slight suggestion that this is perhpas how it was. As an alternative to a wire spring, I was thinking that a flat spring might be an improvement to the design - similar to the one at the other end of the lock but not wrapped around the pins - so it has some freedom to move?
Jeff Dayman19/04/2013 12:32:20
2356 forum posts
47 photos
Neil - you have a PM
Ian - a flat spring may be less prone to breakage than the wire. You can probably use a thinner gauge of stock with a flat spring to get the same force as the 1 mm dia wire. Several places online have design aids for flat springs. (Google is your friend.) What will retain the flat springs to the lock assy though? it would probably be wise to add some tabs beside the bends in the flat spring to keep them from expanding outward and a) falling off the latch face in the centre b) hitting the sides of the pocket in the door the lock fits in. These could be placed next to the round posts the wire spring is wound around, and shaped like the tabs holding the upper end of the wire spring as today. If you were thinking of maybe using holes in the spring to attach a wire or clip around the round post, I wouldn't advise it - any holes in flat springs are where breakage will usually start. A rectangular strip with no notches, holes or sharp edges/corners will make the most reliable flat spring.
JD
Ian Robinson 420/04/2013 10:41:27
20 forum posts
3 photos
THANKS JD & Rufus et al.
The problem with the flat spring idea is that the crown of its arc increases as the latch is retracted and hits the metal plate approx 1mm before the end travel of the latch. Unless the spring can be bent to eliminate this arc it isn't ging to work. I will explore the effects of the bend a little more but it looks as though two torsion springs may be better.
Ian
