Michael Gilligan | 01/10/2023 08:08:45 |
![]() 23121 forum posts 1360 photos |
MichaelG. |
JohnF | 01/10/2023 17:15:16 |
![]() 1243 forum posts 202 photos | Bernard, Something to be aware of with this type of security device is that if you have more than one junction in the loop wire its possible for remove an item from the loop without there being a warning if you have switched it off to remove an item for e.g. demonstration. The answer of course is reconnect asap whilst the demo takes place. This is probably unlikely for your situation but I know of such an event happening at a show on a relatively large stand where for convenience they had several junctions in the said loop. We used to use these but stopped after this happening to the other vendor. Forewarned is forearmed ! John |
Howard Lewis | 01/10/2023 17:28:13 |
7227 forum posts 21 photos | Our club alarm is acontinuous wire loop, but if the loop is disconnected from the battery box, (connector removed or wire cut ) the alarm sounds. So it sounds like it might be a switched socket, probably 3.5 mm, so that when the plug is inserted, the connection between the battery and the alarm is broken One side of the battery is connected permanently to the alarm, and the other side is fed through the jack plug to the loop where the far end s are joined.. The alarm wire does not actually carry nany current, but if it is broken in any way, the alarm is activated HTH Howard |
duncan webster | 01/10/2023 17:34:21 |
5307 forum posts 83 photos | so if someone cuts the wire you won't know? |
Howard Lewis | 01/10/2023 18:17:16 |
7227 forum posts 21 photos | If someone cuts the wire, the circuit is broken and the alarm sounds |
Michael Gilligan | 01/10/2023 18:34:11 |
![]() 23121 forum posts 1360 photos | Posted by Howard Lewis on 01/10/2023 18:17:16:
If someone cuts the wire, the circuit is broken and the alarm sounds .
If there is no current flowing in the first place, what is it detecting when the circuit gets broken. Sorry Howard, I just don’t understand … can you explain, please ? MichaelG. |
bernard towers | 01/10/2023 19:08:04 |
1221 forum posts 161 photos | Pull the pin is ok but what if the wire is cut? |
Michael Gilligan | 01/10/2023 19:12:59 |
![]() 23121 forum posts 1360 photos | Posted by bernard towers on 01/10/2023 19:08:04:
Pull the pin is ok but what if the wire is cut? . Nothing much … That’s why I referred to it as a quick&dirty option and mentioned “chain/wire/string/ whatever” MichaelG. |
John Doe 2 | 01/10/2023 20:59:21 |
![]() 441 forum posts 29 photos | Obviously, any device using electrical or electronic detection, must send current through the wire, otherwise it cannot detect if the wire is cut - (unless the "wire" is an optical fibre). With electronic detection, the current only need be a few milliamps - the amount required to hold a gate or a transistor on/off. With an electrical system, the current will need to be more to hold a mechanical relay on/off, but still only milliamps. |
Michael Gilligan | 01/10/2023 21:12:37 |
![]() 23121 forum posts 1360 photos | That much I understand, John … but Howard seemed quite explicit: ” The alarm wire does not actually carry nany current ” MichaelG.
duncan webster | 01/10/2023 21:20:30 |
5307 forum posts 83 photos | I think the alarm relies on a plug holding a N/C switch open, pull out the plug, the switch closes and the alarm sounds. The wire could be string. Not how I'd do it |
Macolm | 01/10/2023 22:01:01 |
![]() 185 forum posts 33 photos | It seems to me that a simple wire loop alarm is none too secure these days. It would be all too easy to bypass a section, for example using a length of wire with pins attached at each end, with these simply pushed though the insulation of the loop so as to contact the wire inside. Then cut the loop wire without triggering the alarm.
A possibility to improve security would be to include a resistor at each item to be protected. Thus a length of wire, each with the resistor in the middle, for each item, would be looped through it to conceal the resistors. All would then be connected in series as before.
Now an electronic circuit would be required with a comparator against a narrow window of total resistance, so that shorting out any resistor would trigger the alarm. It would be simple to have a potentiometer that could set the window thresholds to cope with the actual number of items being protected. This addition circuit would only require one integrated circuit with ancillary components, as well as whatever is already needed for the alarm function. |
duncan webster | 01/10/2023 23:25:10 |
5307 forum posts 83 photos | But that would take a fair bit of time, so unless the stewards area sleep the simple method is a lot better than nothing, provided it reacts to a cut wire.
Macolm | 02/10/2023 11:58:12 |
![]() 185 forum posts 33 photos | With a pre assembled single length of wire with resistors incorporated it would indeed be tedious. With a better detection system though, I envisaged that short lengths with central resistors, and plugs and sockets, would be procured. Each item owner would fit their wire, then simply a case of plugging together. Easy, also to remove one item, and set up the protection of the remaining items. |
duncan webster | 02/10/2023 13:10:03 |
5307 forum posts 83 photos | I meant it would take the thief some time. Having resistors in line is potentially better as you say, but a lot of plugs /sockets if each model on display had it's own |
Michael Gilligan | 02/10/2023 13:18:32 |
![]() 23121 forum posts 1360 photos | |
John Doe 2 | 02/10/2023 15:52:28 |
![]() 441 forum posts 29 photos | I am curious, (and have obviously led a sheltered life !), What sort of a display would need this sort of protection, and are the displays often left unattended by the owner/stall holder? (toilet breaks, I suppose). What sort of things do people steal? do they really steal things like tiny model spades etc ? Having an alarm implies that the stall owner will not be standing next to the display, so how will they catch a thief even when the thief sets off the alarm - surely by the time the owner has returned to the stand, the thief will have mingled into the crowd?
What a sad World.
Michael Gilligan | 02/10/2023 16:05:33 |
![]() 23121 forum posts 1360 photos | Posted by John Doe 2 on 02/10/2023 15:52:28:
What a sad World.
. Indeed it is |
Robert Atkinson 2 | 02/10/2023 16:58:09 |
![]() 1891 forum posts 37 photos | A loop alarm is a deterrent at all times and an aid when stand is attended. You can't watch everything all the time. Electrically a loop pases current all the time and alarms if the current stops. Simplest implementation is a a relay. Loop is in series with the coil and power source. Buzzer / sounder is in series with nomally closed contact. Disadvantage of this is the relay coil uses a fair bit of current and is powered all the time so limits life on batteries. Robert. |
duncan webster | 02/10/2023 17:06:48 |
5307 forum posts 83 photos | The problem is club stands where there are lots of valuable models. Quite a few reported instances of things like Stuart Turner Models disappearing, easily slipped into a bag whilst the steward is chatting to an interested onlooker, and then practically untraceable, sold on ebay a few months later where they will fetch Several hundreds of pounds. Perhaps we should engrave a postcode onto our models if we want to display them, but having a frame number on your pushbike doesn't stop it getting pinched. Mine was lifted out of a back garden when #2 son couldn't be bothered locking it up. And yes, the low life will steal anything Edited By duncan webster on 02/10/2023 17:55:07 |
