colin hamilton | 15/09/2023 15:33:47 |
186 forum posts 94 photos | Quick update: I've just connected a 450V 200uF and it runs like a dream. Thanks for all your input. Cheers Colin |
noel shelley | 15/09/2023 16:04:04 |
2308 forum posts 33 photos | It's good to hear that all is well again. Thank you for letting us know. As you use it just check that it does NOT run to hot, warm is fine. Noel |
not done it yet | 15/09/2023 18:42:44 |
7517 forum posts 20 photos | Posted by noel shelley on 15/09/2023 16:04:04:
It's good to hear that all is well again. Thank you for letting us know. As you use it just check that it does NOT run to hot, warm is fine. Noel It should not be in circuit for long as a ‘starting’ capacitor? |
colin hamilton | 15/09/2023 19:10:01 |
186 forum posts 94 photos | Posted by not done it yet on 15/09/2023 18:42:44:
It's good to hear that all is well again. Thank you for letting us know. As you use it just check that it does NOT run to hot, warm is fine. Noel It should not be in circuit for long as a ‘starting’ capacitor? I'm pretty sure I can hear the centrifugal switch disconnecting it shorty after starting. I only know about centrifugal switches thanks to this thread!!!! |
colin hamilton | 16/09/2023 12:40:44 |
186 forum posts 94 photos | Update no 2: It turns out the capacitor was sealed inside a can. It's actually 20uF so with my 200uF I'm guessing the windings won't last long. I'll get another ordered. |
noel shelley | 16/09/2023 13:07:37 |
2308 forum posts 33 photos | AH ! The bit that shouldn't get hot is the motor ! Noel |
Robert Atkinson 2 | 16/09/2023 13:08:08 |
![]() 1891 forum posts 37 photos | As long as the centrifugal switch is working and the motor is not getting hot the bigger capacitor may not be a problem. It is mainly purpose is to provide a phase shift. The current depends on both the capacitor and the winding. Robert.
colin hamilton | 16/09/2023 23:32:49 |
186 forum posts 94 photos | Posted by Robert Atkinson 2 on 16/09/2023 13:08:08:
Sounds good. I may just let it be for a while and see what happens |
