Poor surface surface finish milling steel
Andrew Johnston05/07/2023 10:53:53
7061 forum posts
719 photos
Posted by John Doe 2 on 05/07/2023 10:42:59:
Are they designed for that?
Yes they are; the name endmill is a misnomer. They are intended for cutting using the side flutes.
s d05/07/2023 11:02:52
30 forum posts
11 photos
So here's the facing vs side milling. I'm happy enough with the face finish, those ridges are fairly even and the surface feels smooth. This is with a 10mm rougher (the side milling was with the 6mm HSS 3F I think).
The rougher doing side milling is better than the other tools, it's much more regular, but still has those vertical dents.
Martin Connelly05/07/2023 11:42:30
2549 forum posts
235 photos
Anything that can be done to stiffen the process will help so if all the none moving axes are locked and the stick out of both the spindle in the head and the tool in the collet is reduced to the minimum then the next question is are you tightening the tool in the collet sufficiently to reduce flex. If you are not using a ball bearing ER nut and suitable wrenches to put high torque on the nut and therefore high pressure on the tool shank then the tool position may flex slightly in the collet holder.
Martin C
John Doe 205/07/2023 12:32:37
441 forum posts
29 photos
Ah, fair enough.
Do we know then, if the milling bit is true and regular ? - is it possible to check each flute "diameter" with a DTI? - perhaps one is slightly proud compared to the others.
In the same vein; does a DTI show any bend in the driving shaft, as measured against the side of the cutter as it is rotated through 360°.
Edited By John Doe 2 on 05/07/2023 12:33:28
Dave Halford05/07/2023 12:35:41
2536 forum posts
24 photos
Isn't side milling supposed to be approx. the radius of the cutter in depth so for the 6mm dia cutter three passes would be required for 10mm thick work.
s d05/07/2023 12:51:04
30 forum posts
11 photos
Posted by Martin Connelly on 05/07/2023 11:42:30:
Martin C
Two wrenches as as much as I can tighten it. Could it be the er32 collet holder itself? The machine came with an mt3 keyless chuck.... I could try that instead, or is that a terrible idea 😂. Running out of things to try.
Edited By s d on 05/07/2023 12:51:34
s d05/07/2023 12:54:24
30 forum posts
11 photos
Posted by John Doe 2 on 05/07/2023 12:32:37:
Ah, fair enough.
Runout on the spindle is very good but there is more in the collet holder. Used multiple tools and get similar result difficult to isolate as I only have a keyless chuck alternative. There is flex in the column too.
JasonB05/07/2023 13:08:50
25215 forum posts
3105 photos
1 articles
Posted by Dave Halford on 05/07/2023 12:35:41:
Most makers that publish cutting data tend to show 1D to 1.5D on their 4-flute cutters so two passes at the most when also using the usually published 0.1D stepover.
It is possible to use more Ap (vertical) depth if the Ae (sideways) stepover is less particularly for the 5 or 6 flute finishing cutters.
Don't try the drill chuck
The irregular pattern would seem to suggest flexing somewhere rather than a regular pattern that could be attributed to runout.
Edited By JasonB on 05/07/2023 13:10:58
Edited By JasonB on 05/07/2023 13:14:19
s d05/07/2023 13:55:42
30 forum posts
11 photos
Posted by JasonB on 05/07/2023 13:08:50:
The pic with the face milling on the same side has a section that was side milled and is 6.5mm deep. It was done either with the 10mm or 6mm tool. I think it probably does get worse with deeper cuts but it's always there.
Just measured the flex again between the table and the tool, its about 0.015" (my indicator is imperial) easily with 1 hand levering against he vice, with two hands its 0.003"/0.076mm in x. About the same or a little more in y.
Similar reading from table to spindle and pulling on the top of the column maybe abut 0.004. No lose column bolts, all are very tight and there are no cracks in the paint between the column and base (nice that they painted it after it was assembled, including the allen bolts!).
I only get a tiny deflection if I try to man-handle the table in this setup.
IDK if this is significant or totally normal but the spindle-to-head flex is barely measurable so don't think its bearings. Or course there's a lot of leverage on the column.
Don't know what else to do.
Michael Gilligan05/07/2023 14:26:00
23121 forum posts
1360 photos
Posted by s d on 05/07/2023 13:55:42:
0.015” sounds WAY TOO MUCH … is that a typo ?
s d05/07/2023 14:26:51
30 forum posts
11 photos
Posted by Michael Gilligan on 05/07/2023 14:26:00:
Yes it is... thanks! Will edit it.  Can no longer edit.
Should read 0.0015", sorry.
Edited By s d on 05/07/2023 14:28:21
Michael Gilligan05/07/2023 14:33:21
23121 forum posts
1360 photos
yes
