not done it yet | 16/04/2022 12:24:12 |
7517 forum posts 20 photos | If the OP is worried about that last umpteenth signicant figure, I suggest he uses a suitable micrometer to make his final measurements. DROs are good enough for most things, but clearly the OP is not wanting to make confirmation measurements with a standard measuring device which can be checked against sufficiently accurate standards - like a set of gauge blocks. My cheap DRO set indicates to 0.01mm and obviously has tolerances on accuracy and precision, but is good enough for most machining operations. For most modellers, I reckon the ‘fit’ is more important than the absolute accuracy. They are not making serial machines or parts for production items. How many drawings even require dimensions to those tolerances? That is outside of science/NASA/etc requirements. The 0.001mm set is clearly better than the cheaper set - but would I always actually trust that last digit to be absolutely accurate? No, because there are always errors involved in making any readings. A spec of sawdust and a plank comes to mind… |
John Haine | 16/04/2022 12:58:30 |
5563 forum posts 322 photos | Posted by Michael Gilligan on 16/04/2022 09:28:50:
The scales could be natively Imperial ... MichaelG. Could be, except they aren't! |
Michael Gilligan | 16/04/2022 13:32:33 |
![]() 23121 forum posts 1360 photos | Posted by John Haine on 16/04/2022 12:58:30:
The scales could be natively Imperial ... MichaelG. Could be, except they aren't! . Then, evidently, I chose my word, and its underlining appropriately. MichaelG.
bernard towers | 16/04/2022 14:24:12 |
1221 forum posts 161 photos | Im with NDIY its not the size its the fit! |
Dave Halford | 16/04/2022 15:54:13 |
2536 forum posts 24 photos | Posted by choochoo_baloo on 11/04/2022 16:15:16:
My question is, practically, do 5 micron read-heads matter for an ambitious ML7 user hoping to aim for sub 1 thou tolerance? (from time-to-time; not always!) No The DRO on a lathe does not tell you the size of the work piece, only the travel of the carriage or cross slide assuming a read head runs exactly parallel to the scale and the mountings are not flexing. That then leaves tool deflection, tool height, head bearing wear, blah blah. What they are good at is telling you when backlash has moved a supposedly clamped cutting depth and save having to count the number of turns on the carriage/leadscrew handwheel especially on lathes like mine that does not have either graduated. They also confirm that a spring cut is just that though only a mic can tell you if you should be taking one in the first place. |
