Hopper | 21/12/2020 09:34:36 |
![]() 7881 forum posts 397 photos | Posted by larry phelan 1 on 14/11/2020 16:07:47:
This might be a little off topic, but I thought it might be worth a mention. Many years ago, I saw a good trick for marking a pipe/tube at an angle, the tube in question being 8or 9 inches/ What he did was to spread a handful of soot on the surface of a barrel of water and having marked the pipe both sides, where it need to meet a flat plate, he lowered it into the water until both marks met the surface, then took it out. The result was a clear black line, showing exactly where to cut. So simple ! Haha. Brilliant. Maybe those old guys did know a trick or two after all! Another trick to mark pipes square that old boilermakers used was the previously mentioned wrapping a bit of paper around the pipe, but using a readily available strip of emery tape as the piece of paper. The 2" wide stuff works well for full sized pipework diameters. Edited By Hopper on 21/12/2020 09:38:31 |
ega | 21/12/2020 10:33:06 |
2805 forum posts 219 photos | The technique illustrated in my picture is aimed more at avoiding burrs than squareness although this should follow: I have not included the accompanying text from Cliff Bowers' "Book of the Lathe" since the method seems self-explanatory. The off-cut would, of course, be retained on the leading toolbar. Edited By ega on 21/12/2020 10:33:48 |
noel shelley | 21/12/2020 11:14:14 |
2308 forum posts 33 photos | A length of shim steel or brass works very well held in place with a jubilee clip on round tube. Using the paper trick also works on box section as well. Noel |
Roger Best | 21/12/2020 21:37:24 |
![]() 406 forum posts 56 photos | The reason for not using a pipe cutter is that they dent the end of the pipe, Fine for inserting in plumbing fittings but no good to go round a boiler end plate. OK if the end plate is external though, although that raises the obvious question. So for an internal end plate the bung method is best.
John Reese | 21/12/2020 23:13:29 |
![]() 1071 forum posts | A normal pipe cutter will roll the cut edges inward. In many cases that would ruin the pipe for its intended use. |
FMES | 22/12/2020 07:33:00 |
608 forum posts 2 photos | Clamping very gently in lathe and going at it with a bench grinder by hand is perfectly acceptable also.
Woody. Non- ferrous on a grinding wheel? - shame on you! |
Brian Morehen | 22/12/2020 08:49:38 |
![]() 191 forum posts 11 photos | A jubilee clip on the pipe will give you a guide for your hacksaw for nearly the whole cut then remove the clip for the last bit you need to cut and take your time good luck.
Bee.M
