Strange WW1 Chuck - 1MT
What is this chuck for - any ideas?
DC31k30/04/2020 12:17:20
1186 forum posts
11 photos
Posted by Clive Foster on 29/04/2020 13:38:55:
The issue with using that style of chuck on a drill sharpener accessory for a T&C grinder is body clearance from the grinding wheel.
Have you seen the Vertex drill sharpener? It uses ER collets to hold the drills, but the sharp end pokes out of what is conventionally the back of the collet.
I think they do it this way so you can repeatably set the projection of the drill (push the point against a stop and tighten the collet nut). In conventional ER use, the tool can move backwards as the collet is tightened.
A holder copying this could be made to the same taper as the ER collet, of suitable minimum wall thickness, which has potential to give a good clearance.
Only gotcha I can see is the smaller collets in any series have a good recess in the back of them (on my ER20, 7-6 is the smallest with non-recessed bore).
Rod Renshaw30/04/2020 12:52:42
438 forum posts
2 photos
Congratulations to all who did the research on this. I am amazed that this obviously old and apparently obsolete design is still being made. What advantages do we think it might have which have led to it's survival into the 21st century?
Rod
SillyOldDuffer30/04/2020 14:22:24
10668 forum posts
2415 photos
Posted by Rod Renshaw on 30/04/2020 12:52:42:
Rod
I guess easier to make than a Jacobs-type chuck with its tapers and springs and likely to have better grip because the jaws are worked with a big key.
Disadvantage is the Little Giant takes up more space and is heavier. I guess conventional pointy front chucks are generally more handy, and, while the Little Giant might have better grip, it's also more likely to get in the way. On my lathe, it's not difficult to scrape a tail-stock mounted jacobs against the 4-way tool-post. A Little Giant would be even worse in that situation.
If I had one I'm sure it would get used though.
Clive Foster30/04/2020 17:53:25
3630 forum posts
128 photos
I suspect the extra grip would have been handy when using reduced shank, blacksmiths type, drills.
The arguing with a toolpost issue mentioned by Dave is not so much of a problem if using the mostly obnoxious lantern toolpost. Being much slimmer, and usually having more tool overhang, than a 4 way or QC post clearance is unlikely to be a major problem.
As ever such things as survival for longer than might be expected are a consequence of the complex price / performance / capability equation for the period and job to be done. Mores taper drills have always been more expensive than equivalent sizes in the blacksmith, reduced shank, style. Even more so in the past than now. So it could well make sense to have a relatively large Wescott style chuck to handle bigger and blacksmith style drills with a smaller Jacobs, 1/4" capacity perhaps, for smaller work. Although I manage quite well enough with hig end 1/2" capacity Jacobs and Albretch chucks a small & large strategy has often seemed attractive.
Nigel Graham 201/05/2020 00:27:51
3293 forum posts
112 photos
That's a point, Clive - "special purpose machine".
My 'Crown' chuck resembles the Strelinger " Pratt's Improved " but appears to have no provision for a " Positive Driver " tang-key. It is also smaller, under 2 inches diameter, for the same capacity.
I described it as Morse taper but only because when trying it with both taper tooling and plain round bar, MT2 was the best fit, but I admit I've not taken this a stage further, with marking-blue.
Nigel Graham 201/05/2020 00:44:03
3293 forum posts
112 photos
Old Mart -
The modern advert...
I followed that link too, and yes, first appearance suggests it is for a wood-working machinery stockist.
Then a tantalising glimpse of a metalworking lathe in the pop-up pictures led me to explore the site further. The Italian company sells metal-working equipment too, including a range of lathes from something akin to the small ones from Axminster and Arc Euro, to industrial size and scope.
So I don't think our intriguing chucks are necessarily just for wood-working bits.
JasonB01/05/2020 07:07:04
25215 forum posts
3105 photos
1 articles
My old catalogue says this type are suitable for general machine shop use so definately intended for metalwork
Clive Foster01/05/2020 09:34:02
3630 forum posts
128 photos
Were straight shank drills ever commonly sold in larger sizes over and, possibly beyond, those now found in reduced shank blacksmiths style?
Handy though blacksmiths drills can be the reduced shank limits the torque that can be applied. Can't run them at book feeds. Especially as much of the time the machine will be too fast. Big ones are awfully easy to spin in the chuck too. Which is bad for both.
If so the Wescott style chuck would have been well suited to holding them. Also good for holding special tooling on large diameter shanks, whether purchased or shop made.
Generally, for good engineering reasons, Jacobs style chucks tend to top out at around 3/4" capacity so would not do for larger shanks. (Larger ones, up to 1 1/2" (?) were made to screw on small lathe spindle noses as a less costly alternative to collet sets for more accurate work but these were always rare and rather specialist devices.)
Maybe not enough reasons to invent the device but plenty to keep using something aready established and on the shelf.
JasonB01/05/2020 10:24:33
25215 forum posts
3105 photos
1 articles
The same cataloge has drills "blacksmith" type drills with shanks larger than the usual 1/2" and interestingly ones with a larger shank than business end eg a range with 5/8" shanks from 1/8" to 1.5"
Looking at some of the smaller line shaft driven or hand powered drilling machines there are several that just have a socket and side screw so may well have just used a flat on the side of the drill much like a Weldon cutter which would have suited these single shank size drills
Michael Gilligan01/05/2020 12:53:00
23121 forum posts
1360 photos
Posted by JasonB on 01/05/2020 10:24:33:
... and interestingly ones with a larger shank than business end
The grand-daddy of the modern carbide PCB drill ...
robjon4423/05/2020 12:26:37
157 forum posts
Hi all, I have 2 of these drill chucks, a small zero to half inch one acquired for a few pence at a car boot, this I secured on a ground shaft between centres & turned a nice true running boss on the rear end this enables it to be held in the 3 jaw for a bit of quick & dirty drilling on work fastened on cross slide, the bigger one turned up in a box of "stuff" I picked up at a garage sale, 3" diameter body, 120 degree vee in the jaws, branded to the Skinner Chuck company of the USA, patent 1903, fitted an MT3 to Jacobs taper shank from ARC Eurotrade as I was passing one day, of the type with detachable tang, as the jaws interleave minimum size is zero although I don't have many drills that size, max three quarter inch, will obviously hold hexagon shanks or stock accurately true, I have used it in the drilling machine, milling head & from the lathe chuck, with drawbar when required of course & I can report that the grip can be best described as ferocious, it has never lost grip on a straight drill shank when deployed on a manual lathe or experimentally when nothing else would do on a Colchester Tornado CNC lathe ( needs must when the devil rides) absolutely cannot fault them.
Bob H
Lee Rogers23/05/2020 13:06:11
203 forum posts
There was one of these with the Drummond Admiralty B type that I restored. I understand that it was supplied by Drummond with the lathe. Lovely chunky bit of kit but looked out of place on the 1MT.
Robert Dodds23/10/2021 22:05:26
324 forum posts
63 photos
Hi ,
I've dug out a similar design of chuck.
It is different in so far as the jaws are recessed behind a front plate that's secured by a couple of screws, Without destroying all it's patina there is no evidence of any makers mark just a 3/4" stamped on the periphery.
As with others it has 120 degree jaws which I had taken to imply that it was intended to grip hexagon bar etc. especially as the back end is screwed and counterbored to fit my Zyto, but that could be a later modification..
The overall quality of the parts appears to be very good and the complexity of the jaw design and their manufacture is impressive especially if it is, as earlier posters suggest, of 18th century build.
peak423/10/2021 22:30:59
2207 forum posts
210 photos
Robert, for your interest, see also another thread, which actually points back to this one at some point.
https://www.model-engineer.co.uk/forums/postings.asp?th=175124&p=1
Bill
