Capillary gaps required for silver soldering.
Hopper04/08/2020 10:49:47
7881 forum posts
397 photos
Is it not like Loctite where roughing the surfaces with coarse emery paper provides myriad surface scratches a few thou deep for the liquid to flow through and form a grip?
Gary Wooding04/08/2020 15:13:55
1074 forum posts
290 photos
I know that silver solder is a different alloy to sterling silver (92.5% pure silver) but the following anecdote might be of interest.
Some years ago I was given a small enamelling kiln which I thought might be useful for melting small amounts of sterling silver for casting small items.
To try it out I put a few grams of silver scrap into a dish type ceramic crucible and placed it in the kiln. The silver melted OK but it when cooled down I was surprised to discover that there was a thin film of silver underneath the crucible. It turned out that, unknown to me, there was a tiny, almost invisible, hair-line crack in the crucible.The molten silver had become sufficiently fluid to flow through the tiny gap.
ron vale 114/08/2020 18:29:47
50 forum posts
5 photos
Have a look at a gap of 0.01mm., a gnats todger wouldn'tfit through it but the solder will When i got all my bit laser cut byMalcolm i drew them with that gap..no problem whatsoever, plus if too tight you can tweak it a bit but you cannot narrow it
I was scared of soldering, so i practiced on some scrap..No problems now
Andrew Tinsley14/08/2020 21:24:12
1817 forum posts
2 photos
Hello Ron,
I don't have much problem silver soldering these days, as I have done a good number of boilers. Like most people replying, you state a gap measurement. Most manufacturers supply the gap range for the various grades of silver solder, so that isn't a problem.
The query I have, is how do you set the gap to 0.01mm ? Apart from the centre punch method, there have been no answers, I know the basics of the science behind the soldering. What I don't know is how do you jig the gaps?
Cheers,
Andrew.
duncan webster14/08/2020 22:23:09
5307 forum posts
83 photos
I think there is a misreading somewhere, 0.01mm is less than half a thou' I think it should be 0.1 mm, 4 thou'
ron vale 114/08/2020 22:36:25
50 forum posts
5 photos
Duncan Mea Culpa yes 0.1mm
Michael Gilligan14/08/2020 23:08:42
23121 forum posts
1360 photos
Job vacancy for a well-endowed Gnat devil
Bob Worsley21/08/2020 16:53:26
146 forum posts
My apologies to duplicating this thread.
I have asked the same question starting in June in the Workshop Techniques forum.
I also am confused, still.
I have never made any boilers, just about to start though.
