The design of a miniature traction engine
Roger Best | 06/01/2021 21:27:12 |
![]() 406 forum posts 56 photos | Good progress, amazing stuff. If you take a front-on view of the Steam Wagon next to your engine I am sure we will see the difference in proportions, especially if you take the body off the Wagon. |
noel shelley | 06/01/2021 22:36:50 |
2308 forum posts 33 photos | Nice work Nigel ! Bassette Lowke did a set of drawings in1.5 scale in the late 40s, I have a set. If they would help PM me. They are very detailed. Noel |
Roger Best | 17/01/2021 18:01:33 |
Roger Best | 17/01/2021 21:05:03 |
![]() 406 forum posts 56 photos | It is very much a first-off. There has to be a good bit of process development and "does it look right". In such a case three attempts is good. many people need three attempts to make a part with full instructions and published tips. |
Roger Best | 02/02/2021 20:57:40 |
![]() 406 forum posts 56 photos | Looks great, amazing actually for something so small. A row of rivets and a scored line will disguise the common plate. Sorry - no idea about pumps. |
Harry Wilkes | 11/02/2021 18:20:35 |
![]() 1613 forum posts 72 photos | Looking good H |
Roger Best | 12/02/2021 20:17:55 |
![]() 406 forum posts 56 photos | Always a good idea to check the proportions...and generally admire. |
Steviegtr | 12/02/2021 20:19:45 |
![]() 2668 forum posts 352 photos | Great work so far. Keep it up. Steve. |
Nigel Graham 2 | 22/02/2021 21:35:49 |
3293 forum posts 112 photos | Fine work there! Aluminium inserts for PB - I'll try to remember that. That flywheel's spot-on. I don't think you've had to lift the motion excessively. The top of the firebox is a bit on the thick side but not that much above the barrel, and the cylinder saddle will compensate for some of its thickness anyway. I may be mistaken but I think the engine in the photo behind yours is a single-crank compound. Are you following that or making a single-cylinder engine? If the latter your cylinder-block will be proportionately a little bit less tall. I don't suppose you are the first to be caught by things like someone putting an axle in the way of the fire-door. They would! Many traction-engines have either the axle or a motion-shaft not actually in its way but above it, and some seemed to have been designed to make access right awkward. At least yours is below the door. I've certainly fallen into my own design traps many times. There are plenty of bits on my steam-wagon that are second, third... mods to overcome mistakes I had not foreseen maybe 10 weeks - and often years - beforehand. |
Roger Best | 22/02/2021 21:40:52 |
I would recess the top of the firebox. Is there boiler under it at that point? |
Craig Brown | 22/02/2021 21:51:32 |
110 forum posts 57 photos | Starting to take shape now, really looks the part 👍 |
Roger Best | 07/10/2021 20:51:37 |
![]() 406 forum posts 56 photos | Just noticed this thread in my "favourites". Looks like I saved the wrong page. Can anyone point me to the blog?? ta R |
Jon Lawes | 08/10/2021 06:35:58 |
![]() 1078 forum posts | Probably this one, although I can't be sure. It's certainly a very skilled Nigel. |
Michael Gilligan | 08/10/2021 18:27:53 |
![]() 23121 forum posts 1360 photos | Posted by Jon Lawes on 08/10/2021 06:35:58:
Probably this one, although I can't be sure. It's certainly a very skilled Nigel. . Methinks that egi probably stands for editor glue it MichaelG. . Edit: __ Removed the parentheses, to kill the wretched smiley things Edited By Michael Gilligan on 08/10/2021 18:30:30 |
Roger Best | 16/10/2021 13:30:57 |
![]() 406 forum posts 56 photos | Thanks guys. I can follow Nigel's wonderful work now. I hope he wasn't too put off by this forum. The format of the page isn't what I remember so it could be something going on there. Fortunately there was a video hosted by YouTube and that lead me to a number of newer videos. Nigel Taylor's YouTube home page (edited after finding new posts on the blog site) Edited By Roger Best on 16/10/2021 13:57:08 |
Roger Best | 16/10/2021 13:52:40 |
![]() 406 forum posts 56 photos | Correction: I found some newer posts on the blog site: |
