Retapping
Michael Gilligan | 26/06/2019 23:30:46 |
![]() 23121 forum posts 1360 photos | Posted by Nearly Done on 26/06/2019 19:37:56:
Should have said OD of thread is .085" looks to have 44tpi . @JohnF I agree that it doesn't look very worn ... I was simply comparing the measured OD with 0.126" MichaelG. Edited By Michael Gilligan on 26/06/2019 23:31:22 |
JasonB | 27/06/2019 07:03:07 |
![]() 25215 forum posts 3105 photos 1 articles | At that age it may well have been cut with a 2 piece die which could have been adjusted over or under a nominal diameter so may not look worn but could be undersize or simply sized to fit whatever the matching pitch tap produced. It would help to know what the item is and what part of the world it may have come from.
Michael Gilligan | 27/06/2019 10:13:05 |
![]() 23121 forum posts 1360 photos | Posted by JohnF on 26/06/2019 23:09:09:
Looks like a Hardy Perfect strapped tension adjustment lock nut ... . @ Jason JohnF seems pretty confident ... hopefully 'Nearly Done' will confirm or refute. MichaelG. Edited By Michael Gilligan on 27/06/2019 10:14:40 |
JasonB | 27/06/2019 10:22:34 |
![]() 25215 forum posts 3105 photos 1 articles | I missed the reply that it was an English fishing reel. |
Michael Gilligan | 27/06/2019 10:33:46 |
![]() 23121 forum posts 1360 photos | For the job at hand, this probably comes under the heading "too much information" ... but I will post it anyway, for convenient future reference: **LINK** https://www.ring-plug-thread-gages.com/PDChart/BA-thread-data.html MichaelG. |
SillyOldDuffer | 27/06/2019 11:33:49 |
10668 forum posts 2415 photos | 5BA is looking good (dimensions, English made, and John's fishing reel knowledge), but if it's a non-standard thread, or was made off-spec by worn/inaccurate tooling, what's the best way of making a nut to fit? If it was a bigger diameter screw, I'd make a silver steel tap metric pitch = 0.6 'near enough', and undersized to suit the worn out male. But this, I think, is a tad delicate for my lathe, mill and clumsy paws. How were small taps made in the good old days? Dave
JasonB | 27/06/2019 11:43:30 |
![]() 25215 forum posts 3105 photos 1 articles | 5BA may look good on paper but not a lot of use to the OP. He has said that the male thread measures 0.085", don't know about you two but that's smaller than what I drill tapping size for 5BA so any 5BA nut is going to slide straight onto the thread not screw. |
Nearly Done | 27/06/2019 11:45:57 |
14 forum posts 3 photos | Thanks Michael, All info is appreciated. Yes John is correct it's from an early hardy perfect. I did do some research before getting the nut made and even ran a brass 8BA nut down it, but that nut was not very thick I think John could be right about oversize due to old tooling. I think I shall try an 8BA die on the stud and see how it feels. really appreciate the help given on here. |
Nearly Done | 27/06/2019 11:56:51 |
14 forum posts 3 photos | |
Michael Gilligan | 27/06/2019 12:24:47 |
![]() 23121 forum posts 1360 photos | Posted by JasonB on 27/06/2019 11:43:30:
5BA may look good on paper but not a lot of use to the OP. He has said that the male thread measures 0.085", don't know about you two but that's smaller than what I drill tapping size for 5BA so any 5BA nut is going to slide straight onto the thread not screw. . Which is exactly why I wrote: "BUT if it started life at 5BA, it must be very worn." MichaelG. |
Michael Gilligan | 27/06/2019 12:32:44 |
![]() 23121 forum posts 1360 photos | Posted by SillyOldDuffer on 27/06/2019 11:33:49:
... if it's a non-standard thread, or was made off-spec by worn/inaccurate tooling, what's the best way of making a nut to fit? . First: Measure it [much more accurately than any of us has done thus far] 'Know thine enemy' MichaelG. |
Nigel Graham 2 | 27/06/2019 12:44:23 |
3293 forum posts 112 photos | It's certainly not 5BA, whose o.d. is very close to 1/8 inch. (8BA is actually 0.126 " full diameter, and a lot of model designs specify 1/8 " dia rod for 5BA studs, so within tolerance.). I still think 7BA but I'm surprised an 8BA nut will fit. SO 7BA 0.098 " full dia, pitch 0.019" : 2.5 mm 0.48mm respectively. 8BA 0.087 full dia, pitch 0.017 " : 2.2 mm 0.43mm " " Diameter measured: 0.085" (2.16mm) Pitch from the photograph, very slightly <0.5mm Inch values rounded to 3 dec. places from 4-figure tables. The sizes look odd because the full BA range is a metric geometrical series. If it's none of what anyone's suggested it can only have been some non-standard thread of the maker's own. Does anyone have a spare 7BA nut they can give, or a 7BA tap they can lend, to Nearly Done? (I might have a tap, but not a nut.) |
Michael Gilligan | 27/06/2019 12:50:43 |
![]() 23121 forum posts 1360 photos | Posted by Nigel Graham 2 on 27/06/2019 12:44:23:
(8BA is actually 0.126 " full diameter, . I beg to differ, Nigel ... but presumably that's a typo, and you meant 5BA MichaelG. . Edit: What worries me most though is that there seems to be some confusion between metric pitch and tpi ... Back to the gardening now [pull weeds whilst the sun shines] Edited By Michael Gilligan on 27/06/2019 12:54:22 |
Nigel Graham 2 | 27/06/2019 13:43:31 |
3293 forum posts 112 photos | Thank you Michael. Yes, my error. FIVE BA is of 0.126 " diameter. ' I quoted the Imperial sizes of BA threads to cater for measuring these parts in both, and directly from a text-book giving both scales in one table for the same reason. BA is metric but so different from the ISO-M range only one or two sizes are vaguely close together, and then only by coincidence, not proper fit. I wondered as an exercise if they could feasibly be screw-cut on my Imperial lathes. Using a spread-sheet (whose absolute reference function really comes into its own for such things), I managed to produce some fairly close change-wheel combinations for short threads before the cumulative pitch errors become too large. They'd still need finish-profiling by die,' I'm not yet gardening fit, and my lawn (using the term loosely) is becoming a hay-meadow with lots and lots of flowering grasses and their seed-heads. Managed to trim the front-garden buddleia yesterday, before its low-growing branches closed the pavement to anyone over three feet tall. |
Andrew Johnston | 27/06/2019 14:14:36 |
![]() 7061 forum posts 719 photos | I'd agree with the OP and MG; the pitch is greater than 0.5mm, not less, at around 0.6mm. However, the thread is a mystery to me. Possibly a special by Fred in the toolroom? Like MG I should be in the garden, but to hell with it; I'm going to knock out the rest of the traction engine frost spikes on the repetition lathe. It's going to take several proper workshop sessions to overcome the frustrations of the last two years at work. And to come to terms with being a member of the great unwashed, aka unemployed. Andrew |
Michael Gilligan | 27/06/2019 15:07:12 |
![]() 23121 forum posts 1360 photos | This is insanely ambitious, but I wanted to play with another iOS App [ the reference object length is, as before, 20mm on the rule ] As Andrew suggests ... Perhaps it is "Fred's special coarse" MichaelG. |
JohnF | 27/06/2019 15:55:52 |
![]() 1243 forum posts 202 photos | Nearly done, just go for 8BA and I'm sure you will find it OK , I have made many parts for these reels over the years and never found anything other than BA or Whitworth threads on them. I just made a locking screw over the W/end for one 5/32 Whit LH. see photo. The reason for the very small anomalies in the sizes is due to wear on the tools - taps and dies - most of these craftsmen as an apprentice purchased a die plate -- you see heaps of them on the auction site, just a flat plate slightly egg shaped with die thread cut in, these were used to make the taps and in time became worn but because the parts fitted together it mattered not. As a matter of interest Hardy [of Alnwick] vintage reels mostly have the initial or mark of the man who made it stamped inside thus if you needed a spare part or additional spool it would go back to the person who made it. Just to recap I would make a new one and you may or may not know after the lock nut is fitted the top of the thread was very, very lightly riveted over so it could not be lost. John |
Nearly Done | 27/06/2019 16:23:05 |
14 forum posts 3 photos | Thanks John. I hoping you could be right, as the new 8BA nut made for me does go on for Almost two turns. Im hoping running a 8BA die carefully down will clear it !! One is on its way from eBay. That is a beautiful locking screw you have made there. Ive been taking my time getting this reel working nicely and this is the last thing to finish it. Inside Its stamped RB who I believe was Robert Borthwick who worked at Hardy's 1890 to 1920. Gents Thanks for the replies. |
Michael Gilligan | 27/06/2019 18:34:54 |
![]() 23121 forum posts 1360 photos | Posted by JohnF on 27/06/2019 15:55:52:
Nearly done, just go for 8BA and I'm sure you will find it OK . ... I stand corrected I must be doing something terribly wrong with my measuring, as there is no way that I can make the pictured thread 59.1 tpi MichaelG. [ in the Dunce's Corner ] |
JohnF | 27/06/2019 20:36:58 |
![]() 1243 forum posts 202 photos | Michael, you may well be right from your expanded photo however the proof of the pudding etc, the best way is to hold an 8BA tap against the thread and use only the number of pitches the nut will have - not many they are quite short. Although I have never come across one it is worth noting that its very close to 3/32 x 48 BSF ??? It is most unlikely that the thread would have been anything but a "British standard" -- used advisedly because of the time this reel was made -- which would point to Whitworth, BSF to BA but I appreciate there were a great many threads used in various industries. ND yes you are as far as I am aware correct about the initials RB John [Michael you can take the hat off ! ] |
