Having trouble turning grooves
JasonB05/08/2018 15:42:55
25215 forum posts
3105 photos
1 articles
You can take that blade out of the holder and put it straight in the toolpost, thin strip of metal between blade and screw will help
Michael Gilligan05/08/2018 16:12:11
23121 forum posts
1360 photos
Posted by Steve Sherlock on 05/08/2018 15:11:30:
... can't quite work out the size and pitch.. appears to be 3mm x 1mm pitch but the head itself was an imperial size, so either way I'm out of action until I can figure out the size ...
Steve,
Going by your photo ... Yes that is a metric screw: The proportions of the heads differ noticeably between Metric and Imperial.
If it's M3 then the socket should be 2.5mm a/f ... So I guess you were using a 3/32" a/f wrench.
Buy some better quality screws
angel MichaelG.
Edited By Michael Gilligan on 05/08/2018 16:33:49
Frances IoM05/08/2018 16:31:00
1395 forum posts
30 photos
how on earth did you take the head off a cap head screw ? normally the thread will give way - anyway sounds as though a thread gauge can be added to your shopping list - 3mm Iso coarse are 0.6 mm thread; also suggest that if you do buy a grinder (+ safety goggles) you move away from the kitchen table to do any grinding.
Edited By Frances IoM on 05/08/2018 16:38:45
JasonB05/08/2018 16:34:41
25215 forum posts
3105 photos
1 articles
0.5 pitch in my book for M3
Could also be UNC or even Whit as you often find odd sizes and poor screws on these type of holders
Frances IoM05/08/2018 16:47:11
1395 forum posts
30 photos
Jason yes - poor memory (+ I do have thread gauges!) if metric then Screwfix + toolstation only carry M4 and above - I'd double check size as I'd expect M4 at least for that application
Sherlock05/08/2018 16:48:01
52 forum posts
11 photos
Posted by JasonB on 05/08/2018 15:42:55:
Thanks Jason.. Do I have to Shim the side out first so it actually reaches the screws?
Posted by Michael Gilligan on 05/08/2018 16:12:11:
Yes I was indeed using a 3/32 the 2.5mm allen key definitely didn’t fit, I just double checked to make sure.
Posted by Frances IoM on 05/08/2018 16:31:00:
I honestly think it was a really poor screw from looking how it broke off. It left me with a donut shaped cap with the threaded part all in one peice. Having rebuilt a lfew engines I generally have a good feel for fasteners but this was like cheese. Yes, good tip about the grinder, I would definitely get a sore ear for that on the table if nothing else!
Edited By Steve Sherlock on 05/08/2018 16:48:28
Neil Wyatt05/08/2018 17:06:59
19226 forum posts
749 photos
86 articles
Sounds like the socket was too deep.
JasonB05/08/2018 17:11:49
25215 forum posts
3105 photos
1 articles
The problem with going upto an M4 fixing is that the shank is only 6mm or 1/4" square so there is not a lot of metal left, having snapped two of these holders across the screw whole I should knowblush
Michael Gilligan05/08/2018 18:11:18
23121 forum posts
1360 photos
Posted by Steve Sherlock on 05/08/2018 16:48:01:
Now I'm confused ... The head-to-thread proportion of the screws in your photo definitely looks right for metric.
If they are M3, then the head diameter should be nominally 5.5mm and the socket should take a 2.5mm key
Here is a proper one: **LINK**
https://www.westfieldfasteners.co.uk/BO_ScrewBolt_Unbrako_SHCap_M3.html
If they are Imperial [probably #4] then a 3/32" key is correct, but the head should be smaller diameter
https://www.westfieldfasteners.co.uk/A2_ScrewBolt_SHCap_UNCoarse_0.1120.html
For the sake of my sanity, could you please check the diameter of the head ?
Sherlock05/08/2018 18:38:28
52 forum posts
11 photos
Posted by Michael Gilligan on 05/08/2018 18:11:18:
Just checked Michael and the head is showing 5.4mm on my callipers here are some better photos.
duncan webster05/08/2018 18:48:48
5307 forum posts
83 photos
On my to-do list is to make up a small version of Tubal Cain's (the English one) Gibraltar toolpost for my Perris/Cowells. Why? The top slide is always in the way unless you angle it a bit when it doesn't support the tool all that well. If I want to turn tapers I can very quickly put the topslide back on
Sherlock05/08/2018 19:36:16
52 forum posts
11 photos
Posted by duncan webster on 05/08/2018 18:48:48:
They Look Great Duncan, Never heard of them before. Thanks for that. I shall look into that a little more
I'm confused myself to be honest. I always have a hard time deciphering fasteners. The thread actual threaded part is measuring 3mm with my calipers (I should add they are not fancy mitutoyo jobbies) which i suspect is a bit big for a m3 at (2.9mm ish)?
The only thread gauge I have is a whitworth and the closest if not exact match on that is 40 / 1/8"
do they in reality come out a tad smaller like the metric versions, or does 1/8" at a nominal 3.175mm sound too big?
JasonB05/08/2018 20:19:18
25215 forum posts
3105 photos
1 articles
They would usually come out a bit smaller so 1/8 x 40 whit or #5-40UNC are likely, not easy to measure thread angle at that size.
Michael Gilligan05/08/2018 20:26:20
23121 forum posts
1360 photos
Posted by Steve Sherlock on 05/08/2018 18:38:28:
Thanks, Steve ... That all supports my original impression yes
It's a rather nasty approximation of a Metric cap-head screw [*]
... relieved to see that my 'eye is still in'
Of course, I have no idea why your 2.5mm key doesn't fit the socket.
[*] Edit, for Jason : Or a 5-40 with an oversized head.
Edited By Michael Gilligan on 05/08/2018 20:35:14
JasonB05/08/2018 20:29:53
25215 forum posts
3105 photos
1 articles
Posted by Michael Gilligan on 05/08/2018 20:26:20:
Because it's more likely to be imperial at 40tpi which is a long way from the approx 51tpi of M3 and a 3/32" key fits
Frances IoM05/08/2018 20:34:00
1395 forum posts
30 photos
the toolpost on the topslide of my Perris is of course 4BA - approx pitch 0.66mm or 38.48 tpi - out dia 3.6mm - cap dia 5.56mm - the key is 3/32"
Edited By Frances IoM on 05/08/2018 20:34:30
Edited By Frances IoM on 05/08/2018 20:54:03
Michael Gilligan05/08/2018 21:01:32
23121 forum posts
1360 photos
Rough calibration, based on Steve's 5.4mm measurement:
Michael Gilligan05/08/2018 23:34:15
23121 forum posts
1360 photos
With the eye of faith [and a large Vodka & Tonic] ...
The thread angle looks more like BA than anything else.
'Mongrel' is the word that springs to mind dont know
Michael Gilligan06/08/2018 09:06:27
23121 forum posts
1360 photos
Steve,
On further contemplation; I think that broken screw is the proverbial 'red herring'
May I suggest that you concentrate on identifying the tapped hole instead ?
It should be reasonably easy to screw a plastic rod of suitable diameter [maybe a knitting needle] into the hole and take an impression of the thread pitch.
P.S. ... This is a useful reference document:
https://www.socket-allied.com/files/6414/7799/4114/SAS_Technical_Guide.pdf
Edited By Michael Gilligan on 06/08/2018 09:16:45
John Paton 106/08/2018 09:35:21
327 forum posts
20 photos
Thanks Michael - I found that inked document useful too. It can live alongside my Zeus Tables!
It amazing how often I encounter bolts with an unfamiliar thread.
