Farmboy | 26/05/2018 09:11:00 |
171 forum posts 2 photos | Not always easy to be sure from one photo, but the 'fastener' in the second picture looks to me like the end of the shaft with a keyway in it . . . |
Robin Graham | 26/05/2018 22:55:49 |
1089 forum posts 345 photos | Farmboy - thanks for the suggestion, but the 'fastener' turns with the shaft and pinion, so the slot can't be a keyway. I was hoping that this was some standard sort of fixing that I'd not come across before myself, but it seems not.. MichaelG - interesting indeed that you would have found it easier to interpret picures the other way up - but why? Robin
Edited By Robin Graham on 26/05/2018 22:57:11 |
Michael Gilligan | 26/05/2018 23:06:52 |
![]() 23121 forum posts 1360 photos | Posted by Robin Graham on 26/05/2018 22:55:49:
MichaelG - interesting indeed that you would have found it easier to interpret picures the other way up - but why? . Just an experimental observation, Robin ... the lighting seems to work better [shadows cast more appropriately]. MichaelG.
Farmboy | 27/05/2018 09:36:03 |
171 forum posts 2 photos | Robin, I'm probably way off the mark, not seeing it 'in the flesh', but my impression was that the gear shaft had a keyway which runs right to the end of the shaft and is visible on the 'fastener' in the last photo. The gear is prevented from rotating by a key held in place by one of the grub screws. The other grub screw probably locates in a dimple on the shaft to prevent axial movement. The end of that shaft seems to protrude through the casting with a grease nipple in the end to lubricate the plain bearing hole in the casting. If that was the case, removing the grub screws should allow the shaft to be withdrawn from the handle end . . . with a little persuasion, such as tapping alternately on either end with a suitable soft hammer or drift after application of some penetrating oil. Apologies if I have misinterpreted the photos Mike. |
Michael Gilligan | 27/05/2018 11:03:57 |
![]() 23121 forum posts 1360 photos | Posted by Farmboy on 27/05/2018 09:36:03:
... my impression was that the gear shaft had a keyway which runs right to the end of the shaft and is visible on the 'fastener' in the last photo. The gear is prevented from rotating by a key held in place by one of the grub screws. < etc. > . Agreed MichaelG. |
Robin Graham | 27/05/2018 19:44:54 |
1089 forum posts 345 photos | Mike/Michael - you are right!
Mike - I'm sorry I misunderstood your first reply - your interpretation of my pics was right on the money. I feel foolish now - after having come to the conclusion that the pinion must be keyed to the shaft I should have realised that the keyway has to extend to the end of the shaft - the boss visible at the botton of the above is welded in place, so no way was it coming out in that direction It was actually worth pursuing the strip-down this far - the shaft is bored to allow lubricant to pass to both bearings, and it was pretty much caked up. So another result - thanks! Robin
Michael Gilligan | 27/05/2018 19:51:01 |
![]() 23121 forum posts 1360 photos | Excellent result, Robin ... and it appears that nothing was harmed. ... That makes today a good day MichaelG. |
David George 1 | 27/05/2018 20:32:32 |
![]() 2110 forum posts 565 photos | Nice to see a successful operation perhaps you can give us a picture or two of the finished machine. David |
Farmboy | 27/05/2018 21:37:07 |
171 forum posts 2 photos | Yes, definitely a good day Robin is able to finish the job properly, and my ego got a boost with a Mike. |
