Michael Gilligan | 31/12/2018 07:29:25 |
![]() 23121 forum posts 1360 photos | Posted by Nick Hulme on 31/12/2018 01:54:50:
I recommend 3. Ditch the "Shade Tree" engineering, it's not funny, clever or useful. . I am genuinely bewidered, Nick What do you mean by that recommendation ? ... A google search was't much help MichaelG. . http://lmgtfy.com/?q=shade+tree+engineering Edited By Michael Gilligan on 31/12/2018 07:32:18 |
John Haine | 31/12/2018 08:43:39 |
5563 forum posts 322 photos | Posted by Nick Hulme on 31/12/2018 01:58:07:
Posted by John Haine on 01/04/2018 10:41:39:
As far as I can tell, since the material can be chucked in any position along the Z axis, there is no particular benefit in having a Z home switch. A Z axis Zero will be a known distance from the work holding equipment (Chuck) and allows your CAM to know where to stop to avoid collision. Simples. Indeed, but you don't need a home switch to do that, you can zero the machine coords manually, for example at a marked position at the tailstock end of the bed. The controller does need to know where the end of the material in the chuck is so it knows where to start machining, and generally this depends on exactly where you put it, so the Z offset needs to be set anew for each workpiece unless you can arrange a hard stop. For that I have a touch off system. This slowly moves the tool towards the bar end until it just touches, stops quickly, zeroes the Z work coordinate, then withdraws 20 mm, leaving the Z DRO reading +20. All the Mach 3 wizards, and my own Gcode, assume the bar end is at zero. |
John Haine | 31/12/2018 09:39:33 |
5563 forum posts 322 photos | Maybe in our climate shade tree engineering is best done in an armchair by the fire? |
SillyOldDuffer | 31/12/2018 10:10:41 |
10668 forum posts 2415 photos | Posted by Michael Gilligan on 31/12/2018 07:29:25:
I recommend 3. Ditch the "Shade Tree" engineering, it's not funny, clever or useful. . I am genuinely bewidered, Nick What do you mean by that recommendation ? ... A google search was't much help ...I don't think Nick is casting aspersions on Butch Lambert and all the other good folk down at Shadetree Engineering and Accuracy! This outfit is based in Terrell, Texas (pop 17239) which was home to the No. 1 British Flying Training School during WW2. However, Nick's Shade Tree is more likely to be found in the novel 'The No 1 Ladies Detective Agency', featuring Mme Precious Ramotswe and set in Botswana. The trope is that african gentlemen laze under the Shade Tree during the heat of of the day, wasting their time talking nonsense, while women do all the work. In the UK we use Armchairs for the same purpose... Dave |
Martin Connelly | 31/12/2018 10:11:34 |
![]() 2549 forum posts 235 photos | I have a repositionable z axis home/limit switch, it clamps on the ways. Having collets, a 4 jaw chuck and two 3 jaw chucks that are all different distances from the headstock makes use of manual data input (mdi) risky if you make a mistake with z axis movements. Also using as a home switch before work comences allows everything to be switched off when I want to stop (always saving fixture settings on exiting Mach3) . Re-homing next time I power everything up means the z axis is set without touching off the workpiece. I also have x axis homing for the same cold start reasons. Since I sometimes have to move the tool post from one tee slot to another calibrated tool holders and tool tables are not much use to me. Martin C |
Michael Gilligan | 31/12/2018 10:35:34 |
![]() 23121 forum posts 1360 photos | Posted by SillyOldDuffer on 31/12/2018 10:10:41:
I recommend 3. Ditch the "Shade Tree" engineering, it's not funny, clever or useful. . I am genuinely bewidered, Nick What do you mean by that recommendation ? ... A google search was't much help ...I don't think Nick is casting aspersions on Butch Lambert and all the other good folk down at Shadetree Engineering and Accuracy! This outfit is based in Terrell, Texas (pop 17239) which was home to the No. 1 British Flying Training School during WW2. However, Nick's Shade Tree is more likely to be found in the novel 'The No 1 Ladies Detective Agency', featuring Mme Precious Ramotswe and set in Botswana. The trope is that african gentlemen laze under the Shade Tree during the heat of of the day, wasting their time talking nonsense, while women do all the work. In the UK we use Armchairs for the same purpose... Dave . Thanks Dave ... perhaps you could now tell me the relevance of Nick's closing comment: ... it's not funny, clever or useful. MichaelG. [ still bewildered ] |
Robert Atkinson 2 | 31/12/2018 10:43:22 |
![]() 1891 forum posts 37 photos | Posted by Nick Hulme on 31/12/2018 01:54:50:
I recommend
1. Enclosed. 2. Silver Contacts. 3. Ditch the "Shade Tree" engineering, it's not funny, clever or useful. Why silver contacts? Silver is not suited to precision low current switching. It tarnishes for s start. It's not suited to any kind of reliable low level (below 100mA 10V) switching. Commercial index switches are available such as the the Omron D5A but they are not cheap. I'm not an armchair or shade tree engineer, I'm a chartered engineer who has designed and built motion control systems with 1 micron resolution and 10 micron repeatability. This was confirmed using laser interferometry with nanometer scale resolution. Robert G8RPI. Edited By Robert Atkinson 2 on 31/12/2018 11:39:32 |
Mike Poole | 31/12/2018 13:09:00 |
![]() 3676 forum posts 82 photos | Kuka robots have relied on a mechanical reference to calibrate their robots for many years. The reference is simply a V groove and V shaped plunger, at its simplest a dial gauge is fitted and the centre of the V found by jogging the axis to find the null point. An electronic gauge is also available that interfaces to the control system and the robot will seek the null point automatically. This routine is only required after repair or replacement of any element of the axis drivetrain. Considering that a robot arm can be 3 to 4 meters from the point of reference and the arm is accurate to a fraction of a millimeter it has to be pretty effective. Mike |
Another JohnS | 31/12/2018 14:38:30 |
842 forum posts 56 photos | Coming in late to this; I think John Haine did a great job in making a simple, accurate home switch. I understand the potential issues, but, I assume John does as well. What's wrong with making things rather than buying them? Kudos to John Haine. Here's one I did for a Unimat SL; since given on to another club member for his enjoyment: (I expect to do the same for a little Sherline CNC lathe I've picked up)
Edited By John Alexander Stewart on 31/12/2018 14:40:02 |
John McNamara | 31/12/2018 16:00:37 |
![]() 1377 forum posts 133 photos | Hi All John Haine has used a simple contact limit switch method used by many DIY CNC router builders to sense the tool height by placing an insulated contact plate on the bed and lowering the tool until it contacts the plate that works well. If the contact can be kept clear of contamination it will work accurately. Robert Atkinson mentioned that break contacts are more reliable. I agree and a while back made a small experiment to do research on wire alignment using direct contact (on break of contact). Wire alignment is still used to align large machines. Google Cern wire alignment. **LINK** Accuracy, repeatability and low cost were the main objectives. It also had to be able to apply a force sufficient move a small machine slide not just for contact testing. The device comprises two 25mm sq BMS levers pivoting on short spring steel flexures, a flexure also drives the plunger located in the reamed round tube. the lever ratio is 10:1 The drive is a A 400 count per rev half stepped step motor driving a 1.25mm screw via a timing 4:1 ratio timing belt. Note the substantial spring that forces the levers apart and the way the motor mount is attached to the semicircular pivot. this maintains correct alignment as the levers move. yes the timing belt is too long but it was in my stock! The levers provide 10:1 primary reduction closest to the measuring point, with negligible backlash. I used this mechanical system hand driven, no step motor or timing belt on a grinder head allowing very accurate wheel positioning to 0.0001” and it was repeatable. A number of tests were done; the test shown was a piece of stretched high tensile carbon steel piano wire that contacted a stainless steel pin. Not ideal, gold would no doubt be better but I wanted to see what simpler materials could do. The wire and contact pin was wiped clean. Apologies for the rough setup but it did the job and worked. The control system was programmed to move the pin slowly into the stretched wire at various speeds then back off until contact was lost. The process was repeated thousands of times. Overall it behaved as planned, the dial indicator needle constantly moving to the same position at each measurement. around 3 tenth's accuracy with a few outliers caused by mechanical sticking I plan to use this system in the future, a few improvements are planned .
Howard Lewis | 02/01/2019 12:20:49 |
7227 forum posts 21 photos | Presumably, those working to micron accuracy, or better, are doing so in a an environment where temperature and humidity are closely controlled? This is what is required if we are to maintain, consistently, Calibration Room standards of accuracy. Dare I suggest that for most of our hobby work, this is neither obtainable; nor necessary? 10 micron repeatability is pretty good, you are talking less than 0.0005" . Merely holding the part and/or the measuring instrument will probably introduce an inaccuracy of that size, within a short time. Your pocket rule may well be engraved "At 20'C" Human hair varies between 0.003" and 0.007" depending on colour and section. Howard |
Former Member | 02/01/2019 14:12:20 |
[This posting has been removed] | |
John McNamara | 03/01/2019 05:45:24 |
![]() 1377 forum posts 133 photos | The confusion between the US and the metric world in relation to what measure a Micron describes is confusing. Some parts of the US think a Micron is is a ten thousandth of an inch. |
Geoff Theasby | 03/01/2019 10:36:43 |
615 forum posts 21 photos | Robert, I hesitate to cross swords with a practical and qualified expert, but in respect of silver contacts, the tarnish (Usually sulphide) is conductive, as is the oxide, which can be used to make batteries. In VHF/UHF circuitry, items are silver plated to aid conductivity through the 'skin effect'. Furthermore we are advised not to polish these surfaces because the conductivity gets worse. Geoff, G8BMI |
Chris Trice | 03/01/2019 10:52:27 |
![]() 1376 forum posts 10 photos | The computer world and high end radio controls use gold contacts. |
SillyOldDuffer | 03/01/2019 12:02:04 |
10668 forum posts 2415 photos | I don't think there is a perfect contact material, you always have to consider what the switch is for. Gold is reliable because it doesn't tarnish. Despite high cost, it's economic because it can be spread very thinly. But it's inferior to silver when low-contact resistance is essential, and it melts. In pure form it wears quickly and is sticky. You don't want gold contacts when switching power - sparks and arcs soon destroy it, though there are several gold based alloys with Copper, Silver, Tin, Cadmium, Nickel or Iron that improve performance. Silver is good because it's tarnish resistant and because the tarnish is often conductive. It has the lowest possible resistance. Tends to be used for signal switching, quite often in combination with gold. Platinum is a good all rounder (lowish resistance, good heat performance and doesn't tarnish) but rarely used because of the cost. Palladium is nearly as good as Platinum, and more common because it's cheaper. Brass and other Copper Alloys offer good conductivity and are cheap. Corrosion is a problem but arranging the contacts so that they wipe when the switch is operated reduce the problem considerably - good for switching power. Power switches are likely to be spring loaded to minimise opening & closing times as a way of reducing arcing. Morse keys are interesting because they straddle various requirements. Modern keys control the transmitter by switching low voltages and they favour contacts made to make that reliable - silver, gold etc. I have WW2 morse key that's designed to switch valve transmitters at rather high power levels - it's rated 400V at 13A. The contacts are made of tungsten. A WW1 era morse key working a spark transmitter might have been asked to switch even larger amounts of power - some of them have solid silver contacts about an inch across mounted on hefty finned blocks of copper to keep them cool. I think John's choice of materials for his purpose is fine. Simple to make and adjust, easy to maintain, and reliable enough for what he needs. Dave
John Haine | 03/01/2019 14:07:53 |
5563 forum posts 322 photos | Maybe I could bring this thread to a close? To sum up:
It works for me - just thinking that other people might find the idea useful at least for its intended purpose. |
Michael Gilligan | 03/01/2019 14:34:31 |
![]() 23121 forum posts 1360 photos | Nice summary, John ... and your concluding statement seems 'spot on' MichaelG. |
Neil Wyatt | 03/01/2019 15:01:19 |
![]() 19226 forum posts 749 photos 86 articles | Here's a practical observation. Typical 3D printers use cheap, small size microswitches as limit switches typically with a lever that gives about 4: reduction in sensitivity. Even with this unnecessary lever feature, the repeatability is surprising. The z-axis stops with the leadscrew within a few degrees of the same position every time, better than a thou with the 0.8mm pitch. So.. consider using a small microswitch! Neil |
Howard Lewis | 03/01/2019 21:42:50 |
7227 forum posts 21 photos | Barrie You may well be matching one part to another to within a few microns, AT THAT TIME. In uncontrolled conditions the clearance may still be within 10 microns, but cannot be an absolute value. As you agree, heat transfer from the hand will change the physical size. We are arguing about the difference between Relative and Absolute values. if you want the latter, you have to have standardised conditions, otherwise Delusions of Accuracy take over. When I took a part to the Standards Room to be measured, it was allowed to soak to the controlled ambient conditions for at least 24 hours before anyone started to measure it with the equipment kept in that environment.. Slip Gauges were checked in the Calibration Room, under even more closely controlled conditions of temperature and humidity, and then segregated into Workshop, Inspection, and Standards Room grade, differing by millionths of an inch. In our hobby world, we cannot work to such precise dimensions, because our conditions are not controlled, nor are our measuring instruments that closely and accurately calibrated. The fits that we produce MAY remain the much the same, if the mating parts remain in the same ambient conditions, (We must accept that different materials have different coefficients of linear expansion) BUT the ACTUAL dimensions will change, as the ambients change, maybe almost imperceptibly, but they change. Howard
