Member postings for Emgee
Here is a list of all the postings Emgee has made in our forums. Click on a thread name to jump to the thread.
Thread: Insert tip query
07/05/2016 09:15:19
Raymond, not all well known maker inserts have in-built rake of 7deg, various angles are used depending on use, also some are just 90 degrees.(zero rake)
Emgee
Thread: custom big tap needed
04/05/2016 15:34:22
Hi Douglas
The threads on the wooden screw done in the thread-box look to be greater than 60 degrees, they could even be 90 degrees which would be the same as the threads on a tap for tapping wood I made some months ago.
If they are 90 deg that would explain the TPI errors found.
Emgee
Thread: Metric Bantam lathe and 19tpi threads
30/04/2016 19:54:28
Simon
My Bantam 1600 Mk 1 gears are 16DP, same apron as in Muzzer's pictures.
Emgee
Edited By Emgee on 30/04/2016 19:54:57
Edited By Emgee on 30/04/2016 19:55:23
Thread: Cross vice backlash
28/04/2016 09:33:23
I also bought a cross-vice from Graham Engineering when I also bought a pedestal drill. The drill has been used regularly over the last 30 odd years and is still an accurate tool. The cross vice is used in the same way as Lambton, for accurate positioning of workpieces to drill marked out holes, mine may be a later model than Lanbton's as it already had the axis locks fitted as purchased.
Emgee
Thread: electric - measuring the kwh for my workshop
25/04/2016 19:13:02
I use a metering device called Owl, provides all the info you need, they were sold on special offer terms a few years ago but the link below gives a starting point for full info.
Emgee
Thread: which plastic rod
25/04/2016 13:43:21
Hi Matthew
Are the boats to be used on water or just scale static models ?
If building an early sailing ship then wood will be most appropriate to original materials, you could also use wood for the metal parts with addition of some paint to disguise the material.
Emgee
Thread: Single / three phase motor
24/04/2016 20:55:02
Says Ph 1 on the 2nd line from right on the right label. Ph 3 on the left hand label so believe it can be used single or 3 phase. The kW output stated seems to confirm this also.
Emgee
24/04/2016 20:48:23
Hi Matthew
I take it you just want to do some practise turning as you don't state any purpose.
Try Delrin, or similar, most acetal rods are easy to turn and you will get a good finish. As always you do need to have a sharp tool for best results. HSS is more than adequate if ground with good clearance angles but with a radiused tip.
Emgee
Thread: Are we all infringing this patent?
24/04/2016 09:14:14
The practise of mould making by cnc machines was being done way before this patent was lodged, it also states "receiving a file from a customer" so any all in house method would not infringe the patent.
It is everyday practise now to make moulds for laminated fuselages and wings to produce highly stressed model aircraft, these are cut by cnc machines. This is not ME as understood on this forum, we seem to draw a line between aeromodelling and model engineering.
I agree with Bob that the patent is no doubt lodged in the hope that one day it can be used to sue some wealthy company, I fail to understand why the patent was accepted when such practises had been used for years prior to the lodge date.
Emgee
Thread: What Did You Do Today (2016)
23/04/2016 19:16:29
Ed
I use the same stepper on a 24v supply via a controller of course.
Emgee
Thread: Duralium??
22/04/2016 13:40:30
My understanding is that if built in the UK to comply with the CAA regarding models above 7kg the model will need to have inspections by a qualified person during construction stages, the inspections are made to confirm the integrity of the design and materials used and the standard of workmanship. Further details can be found on the Large Model Association (LMA) web pages.
Perhaps Christopher can advise on the specific use for the 16swg sheet.
Emgee
Thread: Tilting Table Kit?
22/04/2016 09:23:07
Another option is the 6 1/2" x 4" Sine table by Dave Lammas, solid bit of kit. Castings available from Blackgates at
Emgee
Edited By Emgee on 22/04/2016 09:24:01
Thread: Duralium??
22/04/2016 09:17:08
Christopher,
Look for HE15 or 2014.
Also consider using carbon fibre laminate, it's lighter and stronger.
Emgee
Thread: CES Change of Owner
20/04/2016 21:27:35
I hope the former owners of CES who it seems have decided to take early retirement can now enjoy a less stressful way of life.
Like many I have always received good service from CES and hope the new owners provide the same service, prices charged of course may determine their success or failure.
Emgee
Thread: best tools for aluminium
19/04/2016 23:28:29
Hi Rainbows
Try this store for a vast range of insert types.
Emgee
Thread: Yahoo problems
15/04/2016 09:19:06
I am a moderator on one of the Yahoo groups that doesn't have too much traffic. I agree since the changes were made the site does not function as well as with the older system. I haven't experienced difficulty in changing member status for posting and receiving mail etc. My biggest difficulty is viewing pictures in the Photo section, before you viewed 1 album at a time, now they are all loading at the same time and this makes the screen a muddle and difficult to view exactly what you want.
My biggest problem is nearly every visit my computer freezes, ctl-alt-del brings me back to screen choices. I am using Vista and Firefox.
Emgee
14/04/2016 13:29:41
Hi Bob
What design is the boxer motor ? did you build it ?
Emgee
Thread: Inverter Tripping RCD
09/04/2016 17:12:37
Neutral to earth fault.
Emgee
Thread: Jasons tips
07/04/2016 14:22:19
Muzzer
H13 denotes recommended for non-ferrous as does H13A, H10 and H10A. Sandvik use this code for turning and milling inserts suitable for non-ferrous which also includes titanium.
The last 2 numbers in the code denote tip radius, as far as I can see thats in 02, 04, 08 rads, where did you get the 03 code ?
Emgee
Edited By Emgee on 07/04/2016 14:23:14
Edited By Emgee on 07/04/2016 14:25:01
07/04/2016 10:58:36
As stated earlier H13A is the recommended grade for non ferrous materials, H10 has a finer grain structure and is also recommended for non ferrous and plastic materials,not all ground inserts have a polished surface, chip breaking will also be dependent on the grade of aluminium being cut, some are stringy whatever grade of insert or tip shape is used. Agree BUE can be a problem if no lubricant used.
Emgee
Edited By Emgee on 07/04/2016 11:28:28
