Member postings for Cross Slide
Here is a list of all the postings Cross Slide has made in our forums. Click on a thread name to jump to the thread.
Thread: Minilor FR1
04/01/2015 13:06:31
Hi Trevor,
I have a Minilor TR1 which I am stripping down and rebuilding. It is the lathe collet chuck that accepts ER25s. The lathe spindle is bored to about 13mm.
Steve is spot on with the FR1 description.
Cross Slide
Thread: Meddings Dril Tru
10/07/2012 12:41:07
'... Having first removed the chuck and arbor from the machine using a suitable drift.
10/07/2012 12:38:32
Hi,
There is usually a hole through the centre line of the chuck - insert a suitable length of round steel and give this a sharp tap with a hammer... this should remove the arbor from the chuck body...If it does not replace the chuck and arbor with a new quality arbor and Rohm or Jacobs chuck.
Cross Slide
Thread: Macc Models
29/06/2012 12:36:03
Hi Joe,
I have ordered metal stock from Macc Models with no problems at all.
Many thanks for providing a good service
Thread: soba centre square
23/05/2012 12:25:33
Hi OM,
Excellent work .... How is the HBM. Must confess I have only bought Toolmex or Bison and never hand any problems... But my wallet is very much lighter!
OS
Thread: 5"g Netta
22/05/2012 12:48:08
Hi,
Any one building this loco?
CS
22/05/2012 12:46:31
Hi
Perhaps I should have added that that my Soba centre square is accurate.
CS
21/05/2012 12:33:31
Hi Les
My Soba centre square is held together with rivets.
CS
Thread: 5"g Netta
04/04/2012 12:32:55
I am about to start building Netta in 5"g. I have the plans and the original ME construction articles from the mid 1950's. This will be my first model so I would appreciate any advice (errors on the plans etc) from those have built it.
Many thanks
MCW
Thread: Drill press advice?
19/03/2012 13:14:47
I bought a far eastern import - one of the better ones from Taiwan - but....
1) Throw the chuck in the bin where it belonged and replaced it with a high quality one.
2) The quill diameter was about 10 thou smaller than the housing bore. Solved this with a cylinder of 5 thou shim brass insert into the bore. Result no play.
It is know OK for general work but for accurate drilling I use my VMB.
MCW
Thread: Rolls Royce engines going global in Singapore
03/02/2012 16:05:37
John,
You have hit the nail on the head - could also add shortage of people with the required skills which is related to lack of investment in the future.
Cross Slide
Thread: Myford / RDG
15/12/2011 13:17:35
My original myford oil gun leaks as well. But enough of leaks and oil. Why don,t we use this thread to provide RDG with our ideal lathe spec?
Thread: Myford VM-B Milling Machine
05/10/2011 13:14:02
I too have a VMB. Is there a secret to adjusting the head gib strips?
