Here is a list of all the postings Brian G has made in our forums. Click on a thread name to jump to the thread.
Thread: Rusty lathe for sale |
15/04/2017 18:36:00 |
Is it my imagination, or does the glass on the oilers look rusty? Brian |
Thread: 08 shunter quartering |
15/04/2017 09:54:55 |
I've been wondering about the same problem for 16mm locos as I unsure of my ability to file or broach square holes accurately enough to replicate the method (squares on squares) used on commercial locos. Rather than assembling, drilling and pinning, would it be possible to first drill holes in all the cranks on a single setup (with rods passed through the axle and crankpin holes to maintain alignment)? You could then follow IanT's method to drill holes at 90 degrees in the axles, pinning the cranks to the axles on assembly. Incidentally Geoff, regardless of how you choose to quarter the axle, would it be possible to pin across the cranks rather than inline with their throw? That way you could drill right through, allowing you to heat the cranks and make a tool to push the pins out. Brian Edited By Brian G on 15/04/2017 09:56:15 |
Thread: Cost effective way for manufacturing a small plastic part |
29/03/2017 11:13:28 |
Have you tried the estimators on www.custompartnet.com **LINK** ? Brian Edited By Brian G on 29/03/2017 11:14:32 |
Thread: Aircraft recognition problem |
27/03/2017 10:26:07 |
Posted by Geoff Theasby on 27/03/2017 09:40:57:
...Also spotted an airliner very low, enough to detect wheels not down, landing at Doncaster? Just saying this last. With commercial aircraft there is a cheat available. My son became curious about airliners flying over us, installing "Plane Finder" on his phone let him identify the aircraft and its destination. Brian |
Thread: Encouraging new hobbyists |
24/03/2017 14:54:53 |
Posted by Michael-w on 24/03/2017 12:59:33:
I'm of the 90's generation and I can think of no reason why I wouldn't want to do this! It's so interesting to me but I also appreciate others may not like it. I was lucky enough to be introduced to it through necessity and then the second unlikelihood of actually enjoying it. I then spent the money I earned working on this. I might add there are also a lot of other distractions to enjoy these days too. I know a lot of geeky people who enjoy the digital side of making which is also a skill that takes dedication, fair play to that but I do wonder if they would like this too. The time I've seen some of them pour into animation, digital models and artwork, there is definitely potential and no question of capability if they wanted to. Michael W Edited By Michael-w on 24/03/2017 13:06:04 Digital and physical aren't exclusive. My son works in a computer game studio, yet last year he wanted a lathe for his 21st birthday. Brian |
Thread: Fuel tap leak |
21/03/2017 09:46:01 |
I wonder if any problems from ethanol in petrol only affect post 1968 vehicles, as before then Cleveland Discol was readily available? If so, could it be due to the use of plastics instead of cork? Brian |
Thread: 3/4 scale Landrover |
07/03/2017 11:41:21 |
Posted by Dave Cee on 07/03/2017 10:32:44:
...Yes it is Neil. Not road legal though Possibly a good thing, many motorists have the same difficulty as Father Dougal with "this is small, they are a long way away". Brian |
Thread: Why don't we make models of things like this? |
06/03/2017 15:57:32 |
Posted by Neil Wyatt on 06/03/2017 11:54:51:
I have gathered quite a lot of information on steam hammers, one day... Neil For the workshop or just as the perfect way to crack a breakfast egg? Brian |
Thread: Workshop thermal gloves- advice please |
26/02/2017 08:21:12 |
Rather than gloves which could get caught up and do some real damage, how about replacing machine handles with wood or plastic so they are less efficient at sinking the heat from your hands? Away from rotating machinery, gloves with a "Thinsulate" layer may offer the best compromise of warmth and feel. Brian |
Thread: Square Gas Tank |
25/02/2017 10:16:25 |
As we do not possess a test certificate for the tank or boiler, we decided to test both before presenting the boiler for testing. An earlier thread carried a link to this test schedule, so our intention was to test to 185 psi and to use only pure butane. The tank is in a well ventilated position right under the roof of the open backed-cab and in operation is unlikely to be affected much by the boiler, but it could become heated in the sun as the model doesn't have the double roof of the prototype. I had wondered about a round tank concealed in a box, but didn't want to make any change to the gas capacity until we know the run time of the loco. As the tank/valve/jet assembly is easy to remove, one option might be to do this as a display tank, with an alternative longer cylinder (perhaps rated for mixed gas) for extended running, although the off-axis location of the filler (dictated by the existing hole in the cab roof) could be an issue. Brian |
24/02/2017 13:16:29 |
Hi Jason, the tube is 16 gauge, my drawing is right (or at least matches the materials I have bought), my posting is wrong. On the original tank the ends are also thicker than the tube but this is the only stay fitted. Brian |
24/02/2017 12:13:19 |
Hi My son and I are returning a 25-30 year-old Steamlines "Rheidol" 16mm locomotive to use and decided to start with hydraulic testing, under which the butane tank sprang a leak at just over 100 psi. The tank is a square 20 gauge brass tube 1.25" x 1.25" x 1.625" long. A 6BA stay connects the two 18 gauge brass ends and is nutted externally. We would like to make a new tank that resembles this closely as it is visible in the cab of the locomotive. The planned replacement uses 18 gauge tube and 1/8" ends, with a single 1/8" bronze stay. This should both increase the stiffness of the tank and more than double the area of the silver soldered joint. Should we also add cross stays to the tube or just build and test this design, (Or is it better to exactly copy the failed tank as it is an established design?) |
Thread: Metric screw cutting dial. |
22/02/2017 09:17:58 |
Posted by John Stevenson on 21/02/2017 22:02:00:
Typically for a metric lathe it has three gears fitted 27, 28 and 30 which are all there. According to the chart there should be 11 divisions which won't be equally spaced although No 2 isn't listed and 1mm pitch, 2.0 and 4.0 can be engaged anywhere as it has a 4mm pitch lead screw, [ checked and is correct ]
As far as I can see there should be 12 divisions, with the additional one being either 0 or 12 depending on your preference. That way the spacing between selected numbers will be constant, i.e. 1...5...9...1 with three spaces between and 1..4..7..10..1 with two spaces. For 8mm pitch you can use any two opposite divisions as the 4mm thread passes twice per revolution. On the chart it says 1.....7.....1 with 5 spaces between, but any opposite pair would work. Probably easiest to think of it as the numbers on a clock face, pick any point to be 12 o'clock and mark it up from there. There won't be an absolute right place to start, it's just about repeatability. Brian |
Thread: Working with gauge plate. |
16/02/2017 12:39:32 |
Posted by Tim Stevens on 16/02/2017 11:26:35:
...There isn't a proper general term to use for 'inch-based but not British' dimensions... There is a name for the US system Tim, the United States Customary System (which, just to muddy the water, they often call "English units". I'm not sure it would help however if there was a general name for non-imperial units as there are so many of them. I drew an Austrian railway station for a (postponed) model, and realised that despite metrication in 1871 the dimensions were round numbers of feet and inches (just like timber here in the UK). Except of course, they would have been Austrian Fuß and Zoll (316mm and 26.34mm), with just as good a right to be called "Imperial" as ours. With a quick web search I found there were dozens of different pre-metrication units, particularly across the German lands. Brian |
15/02/2017 09:48:37 |
Posted by Michael Gilligan on 15/02/2017 08:59:06:
Posted by Bandersnatch on 15/02/2017 01:32:25:
For basic units such as quarts and gallons we use Imperial.
. Now there ^^^ is a dimensional/linguistic difficulty. Please correct me if I'm wrong, but, as I understand it: Imperial Units = British Units but US 'Quarts' and 'Gallons' are each smaller than the Imperial volume of the same name. MichaelG. Canadians use imperial gallons Michael, hence the difference in mpg between Canadian and US versions of the same car. One forum I belong too has a majority of North American members and there the US system is often referred to as "customary units" avoiding confusion with imperial (which replaced customary units across the empire in 1826, hence its absence in the US). Brian |
Thread: tool misuse/abuse |
03/02/2017 09:20:35 |
Is a demolition screwdriver (the kind where the shaft goes through the handle so you can hit it with a hammer/stone/forehead) the ultimate multi-tool? Very O/T for model engineering but bang on for this topic Brian |
Thread: Bermuda bell / foot operated gong |
14/01/2017 11:39:23 |
If not too large, would the gong from a rotary fire alarm be suitable (although it would need drilling for the centre operating rod)? Alternately, although shipping adds a bit, the signal bells formerly used in US filling stations are common on eBay. Only concern is, would a bell be legal on a new-build vehicle? I understood that they were reserved for emergency vehicles. Brian
Thread: Best way to cut stock to size |
19/12/2016 11:53:46 |
My son has one of the cheap "Evolution" chop saws from Screwfix (very cheap - 110V in their sale was half price) with a TCT blade that will cut timber as well as metal (although remember to remove any sawdust from the bag before cutting steel). Works OK although the clamping seems to have been designed for partitioning etc. so it doesn't hold smaller materials or round bar that well - making a vice for it is on the "to do" list. |
Thread: need mt2 x m12x1 chuck arbor |
08/11/2016 10:37:42 |
In the past I am sure both RDG and Chronos had them, as well as M12 x 1 chucks, but I cannot see any now. There is one on eBay though **LINK** Brian |
Thread: morse taper |
14/10/2016 10:44:39 |
If there is enough space between the tailstock and the workpiece for the 3MT drill and its shank, you might use a "Jump Sleeve" like this **LINK** (usual disclaimer - I am sure there are plenty more out there). If you haven't got one already you will also need an extraction wedge. Brian |
