Here is a list of all the postings Brian G has made in our forums. Click on a thread name to jump to the thread.
Thread: Emco Unimat 3 Threading tool |
29/12/2022 11:45:17 |
Hi Andrew Are you aware of the Unimat groups on groups.io? The biggest is groups.io/g/Unimat which is nominally for DB/SL models but has a lot of U3 owners, whilst groups.io/g/Unimat3 is smaller but just for the 3. Both groups are public so you can "try before you buy". This post looks particularly relevant to your needs, being a way to fit screw cutting gears to a U3. If you have access to a 3D printer you could create the necessary gears in Fusion 360. Brian G |
Thread: Another EVRI calamity. |
25/12/2022 07:48:39 |
The article doesn't say which carrier, but it is nice to know we aren't the only ones. Brian G Ah yes, exactly where I wanted my parcel – delivered to somebody else’s foot |
Thread: QCTP Identification |
21/12/2022 21:48:11 |
Posted by John McCulla on 21/12/2022 20:24:40:
Posted by not done it yet on 21/12/2022 20:14:25:
C0mparison of the measurements might give some idea. They are on their websites. Where are the measurements on the Warco site? I couldn't see any apart from the tool holder capacity. Brian G Edit: Unfortunately both firms have measured different parts of the toolpost, but if you compare either of them with the (imperial) measurements of a genuine 400 USD Aloris AXA toolpost they appear to be pretty close copies of the same toolpost, so may well be interchangeable. Edit again: If your compound slide has an integral boss for the 4-way you will either have to machine this down to fit one of these toolposts (or possibly bore out the central cam of the piston type). In that case you may prefer to use your credit on the Warco rear toolpost first if the 250 will swing the compound clear of the bed. BG Edited By Brian G on 21/12/2022 22:04:27 Edited By Brian G on 21/12/2022 22:14:17 |
Thread: Calculating Thread Dial Chart |
15/12/2022 12:07:44 |
Posted by Rod Renshaw on 15/12/2022 11:21:27:
Anyone remember the recent posts on the forum regarding a screwcutting tool with a loose lifting piece which automatically lifts and retraces it's path when the lathe is reversed ready for the next cut?... Rod I must have missed the post, but it sounds like you mean one of these:- Flip-up Toolholder If not, thanks for reminding me, hopefully the workshop will be moved in January and this will be another one for my "to-do" list. Brian G |
Thread: Acto tool and cutter grinder |
13/12/2022 14:23:40 |
Have you considered the Brooks design? The words and music are in MEWs 16 + 17. I have one on my "to do" list as it is made without castings and appears similar in operation to the Stent although it uses Unimat-style (but much thicker) round bars instead of dovetails. There is a build on gadgetbuilder.com. Brian G |
Thread: Lathe spindle bearing selection |
12/12/2022 19:35:02 |
Posted by C T on 12/12/2022 19:04:31:
Posted by HOWARDT on 12/12/2022 18:59:33:
None on your website mention P6 bearing tolerance, but seems plenty elswhere. You could also obtain correct grease from the bearing supplier chosen. What is P6 referring to? According to SKF P6 is closer tolerance than their standard bearings and P5 is closer than P6. **LINK** Brian G |
Thread: Staying on Track. |
08/12/2022 16:03:19 |
I think 'Empire' may be trumped by Charlie Shackleton's protest film 'Paint Drying', created for the sole purpose of forcing the censors to watch ten hours plus of exactly what it says on the tin. Brian G |
08/12/2022 13:28:42 |
Posted by Neil Wyatt on 08/12/2022 11:38:50:
It shows how infrequently the flange touches the rail. Imagine the wear if trains were actually guided by the flanges. At the end there was a link to this, reminded me of riding in a Scottish EMU, coming from Kent I had no idea that there were units with glass behind the driver. Brian |
Thread: Doug Roseman &/or Steam Fair models in general |
03/12/2022 15:28:56 |
This is Doug Roseaman's website www.fairgroundmodels.co.uk Brian G |
Thread: Toys for Christmas |
28/11/2022 13:13:23 |
Posted by jaCK Hobson on 28/11/2022 11:39:39:
Something by Starrett. Might be more of a last minute Cyber Monday deal but this looks handy for lass than £25 https://www.amazon.co.uk/Starrett-10MH-150-Square-Student-Combination/dp/B003XU78JA +1 for Starrett, even some of their cheapest products are beautifully finished and most come in really nice little red boxes so that family like to give them as presents. I'm about to try and persuade my wife that she wants to buy me a no.18AA centre punch Brian G |
Thread: Unimat milling table - post modification |
14/11/2022 18:10:26 |
I let my subscription lapse when I moved, so cannot check it in the online issues, but I remember reading an article on this subject. IIRC it used a second round bar to locate the column and added a leadscrew and graduated handwheel. Looking at the index I think it will be Rhodes. M. "Milling Head Alignment Guide for the Unimat 3" MEW 124 (April 2007). Brian G Edit: This is the article I remembered, and I found some of the text and a couple of photos published here as a news article Edited By Brian G on 14/11/2022 18:30:50 |
Thread: Meths, steam train set availability? |
10/11/2022 11:52:26 |
You could try Dream Steam in Kent. Although the MSS locos in the train sets are are fired by solid pellets, they also offer meths burners and other upgrades for them. Other commercial steam locos in 16mm from Mamod, Accucraft, Regner and Roundhouse are gas fired, but there are Gauge One meths fired locos although they probably won't run happily on a "small circle or oval". Brian G (No connection to the shop other than as a customer) |
Thread: Looking for 0.001" resolution carbon fibre digital calipers |
07/11/2022 19:12:26 |
Zoro offer a "Senator Polycal Digital Caliper" at £15.99 inc. VAT with a resolution of 0.01mm / 0.005" but this appears to be polycarbonate like the similar (identical?) M&W one. I wasn't impressed by the claimed accuracy of +/-0.02mm / 0.008", but even a Mitutoyo caliper costing 10 times the price doesn't claim to be more accurate, so I guess it is in the nature of calipers. Brian G |
Thread: What is a 'Gedge Flat' as seen on certain railway couplings? |
05/11/2022 09:21:54 |
Posted by Greensands on 03/11/2022 20:23:53:
Any chance of posting a copy of the RCH drawing? Drawings are available online here Railway Clearing House Wagons, the coupling hook and chain is on drawing 1007. Brian G |
03/11/2022 20:10:46 |
I just looked up the RCH drawing for wagon couplings and the link is 1 1/2" diameter with a 1" thick x 2" wide flat (I never knew it was called a "gedge" Brian G |
03/11/2022 17:59:12 |
I always thought it was to allow the coupling link to fit through the slot in the coupling hook. Was this wrong? Brian G |
Thread: I presume they have a good contract |
27/10/2022 12:14:29 |
Some companies with very high volumes of shipping pay their carriers a percentage of monthly shipping value, not a per-parcel charge, whilst almost all pay a heavily discounted rate compared to private customers. Either way, for accounting purposes delivery costs are often taken overall, not costed to each job, and as a percentage of overall costs many small packages may be balanced out by a single large order (Zoro for example sell £50k machines as well as a lot of £100+ cutters). Brian G |
Thread: The cheek of McDonalds |
23/10/2022 21:29:57 |
Posted by Samsaranda on 23/10/2022 19:28:23:
I don’t eat McDonalds, I had it years ago as the grand children wanted to eat there, I was distinctly unimpressed, however on Thursday was in London for wife had an appointment at St Thomas’s hospital. On the way home we were in Victoria Station and wanted a coffee, my daughter who was with us said I’ll get you one from McDonalds, I wasn’t impressed but she said their coffee was good so I accepted, have to say that the coffee was very good, so I wouldn’t eat there but I would have their coffee any day. Dave W On a journey we look out for services with a McDonalds rather than getting coffee from "Megabucks" or "Costly". Does anybody know if the French "McDo's" still give you a small dark chocolate with it? Brian G |
19/10/2022 20:24:42 |
Can I ask what is so cheeky about McDonald's? There doesn't appear to be anything that isn't necessary for a webpage to function and most websites will already have gathered this information before they serve you with a page anyway, they just aren't as up-front about it. If you read the privacy policy of the model-engineer.co.uk website (link here or at the bottom of the page) you will see almost exactly the same thing, the biggest difference being that McDonalds ask you to agree, probably because the data is analysed in the US, whilst Morton's don't ask (although I'm pretty sure that registering as a forum user requires agreement to the conditions). The server for every webpage you go to requires address information, otherwise it will not know where to send the information. Similarly, without your computer sending browser and hardware information, the server would be unable to decide whether to deliver a desktop or mobile version of the site, or even whether the browser could display a usable copy of the page. Because there will be many clients connected to the server at the same time, cookies are required for the server to keep all responses from a single client linked together. For example if the page first asked for which restaurant you visited and then sent you further questions about the service in the restaurant, without a session cookie there would be no way for the server to link the answers to the particular restaurant. Brian G |
Thread: Headstock alignment |
10/10/2022 18:01:21 |
I can't offer any advice Jay, but I think those who can would need to know something about the machine, ideally make and model and whether it is a flat, round or prismatic bed. Brian G |
