Here is a list of all the postings Geir has made in our forums. Click on a thread name to jump to the thread.
Thread: WARCO WM-250 lathe family and WM16 mill - 001 |
22/05/2013 21:14:13 |
What would be a good rotary table size for the HBM BF25, 6'' or 4''? The machine has a 700x180mm table, but is otherwise similar to the Warco WM18. Can anyone recommend a good rotary table - preferably on the "good value for money" side - not necessarily the cheapest. |
Thread: Lathe alignment and cross slide play issues |
18/02/2013 19:19:08 |
Joey, I am absolutely with you on the rethinking aspect, it is what I need that is relavant, not what is possible. I am moving on to the reason I started this exercise which was making a tailstock die stock holder. So once I make sense out of the measurements/setup I will be attempting a 2 MT using the top slide... Geir |
18/02/2013 09:35:53 |
I have some basic lathe knowledge, and enough engineering background to see when I am getting out of my depth |
17/02/2013 21:13:47 |
Jason:
Your advice helped fix the lead-screw play - the nut was completely loose. Harold: Thanks for the helping clear this up - 0.002mm is probably good advice when making cylidrical squares. I was thinking of attempting to make some, but I can see that this may have to wait a little. The lathe is mounted on a wooden bench and inducing a twist will, as you mention in your article, require something substantial to push against. The squares will have to wait for a new bench/frame. Is twisting the bed always a good fix for minor alignment errors? The chinese lathe I have is fixed to the bench using three screws that run centrally to the bed. One at the tail (as depicted), and two at the head-stock. Inducing a twist will involve shimming on either left or right side of the screw. The "box" structure of the bed frame will probably be quite resilient to twisting without applying considerable force, and I wonder how effective shimming will be? It may be that actually re-aligning the head-stock, as per Andys comments, is the most viable option? Regards, Geir |
17/02/2013 18:21:17 |
Thanks for the quick replies, they are very appreciated. I am tending towards not worrying overmuch about this right now, especially as the procedures for "fixing" could easily do more harm than good. However I am still curios as to how one determines the most likely source of the misalignment. Rod: I agree that deflection might be an issue, however I tried to take very light skimming cuts (dust) to eliminate this as problem. However I see that there is still a good probability that I am still measuring deflection. I did use a carbide insert cutter, and I from what I am reading these are not ideal for these kind of light cuts, however the finish was excellent as far as I could see (feel). The way I understand it the test bar must be unsupported and that deflection must be handled by using an appropriately thick bar and take light cuts. The lathe is set on a very sturdy wooden bench that has been additionally reinforced to provide a stable level surface. The lathe is fastened by two bolts, one at the headstock and one at the tail end. Jason: In the "lathework" book, HH states: "With repeated machining and checking, one should be aiming at a virtually error free result, certainly no more than 0.002mm on diameter over 100mm length". I must agree that I thought this a little on the extreme side as well, as any dust or minute deflection would make this virtually impossible to measure and maintain. The handwheel seems to be nice and tight, I will look for the nut you mention.
Edited By Geir Ertzaas on 17/02/2013 18:22:45 Edited By Geir Ertzaas on 17/02/2013 18:23:18 |
17/02/2013 16:16:48 |
I have just acquired a new lathe, a WM250 type. It seems to be very robust and reasonably accurate, however I have two questions/issues that I was hoping someone could comment on. Issue 1: Excessive play in the cross slide lead-screw. By pushing the cross slide back and forth I can move it ~0.7-.8mm. Is there any way to limit this play a little? It is not a major problem, mostly irritating. Issue 2: Bed alignment with head-stock. I have carefully skimmed an unsupported 100mm length of 25mm free turning steel and measured the diameter at both ends. There is a difference of 0.02mm (smaller at tail) between the diameters. Is this something to worry about? Reading Harold Halls lathework leeds me to believe that this 10x more than acceptable. How would one go about figuring out what needs adjustment, and what are the adjustment possibilities on this type of chinese lathe? Regards, Geir Edited By Geir Ertzaas on 17/02/2013 16:23:19 |
Thread: Rotary table dividing Calculator |
14/12/2011 16:37:37 |
As far as I know Mediafire is a hosting service with its own servers and not a P2P network. There is no reason to suspect that a file hosted there in any way will "get infected" by a virus. If the person uploading the file provides a clean file it will stay clean for the people downloading the file. That said, one should always be cautious when downloading files from any source, especially unmoderated filesharing services like Mediafire.
Geir
Thread: Remote display sources for DRO Chinese calipers |
15/11/2011 13:16:11 |
The Warco ones look very similar to the iGaging ones - Geir Edited By Geir Ertzaas on 15/11/2011 13:16:22 |
Thread: Yet Another Tangential Tool Holder |
11/10/2011 23:03:41 |
Very nice, looks solid and clean. A drawing would be much appreciated.
Geir
Thread: Printing multiple pages |
22/09/2011 09:15:14 |
I share Mr Halls concerns over net-piracy, however I do not believe that the fight against this kind of criminal activity will ever be won by refusing to publish electronically, or by limiting the accessibility for those who are willing to pay for the electronic content.
I do not mind some kind of watermarking or DRM (content protection) as intermediate solutions while we figure out how the publishing economy in the 21st century should be. I want access to the newest magazines and the newest books in a usable digital format without any time delay, using technology that works on a wide variety of digital platforms.
It is the up to the authors and the publishers to find business models that are sustainable in a digital world. I believe that given a little time those that refuse to adapt to the realities of this new market will not be very successful.The bottom line is that our everyday lives is becoming more and more adapted to the digital possibilities, and we (the consumers) will not accept sub par services in the digital domain.
Geir
21/09/2011 14:18:48 |
David Clarke, I don't mind the digital subscription concept, I never take out actual copies on paper, the reader however is by far the worst I have ever tried (I subscribe to a number of other digital magazines). It is almost useless on my android tablet. I got the digital ME edition hoping things would improve on the reader side. There was a small improvement with the "new" reader, however it is still not an enjoyable experience. I will stick to my paper MEW subscription and cancel my digital ME at the next crossroad.
I would be willing to pay a premium for a pdf version of the magazines. Other magazines (like Elektor, Nuts&Volts, Servo Magazine etc.) provide me with a pdf every month and I cannot understand why this is such a difficult thing for ME&MEW to do.
Geir
Thread: MEW 180 |
06/08/2011 15:08:54 |
I second the opinion of John Stevenson, the amateurish manner the digital subscriptions are handled is very close to delivering a product that is "Not fit for Purpose". I subscribe to a number of digital magazines, all of which have a superior quality to ME/MEW. The technical issues should have been ironed out before the product was offered for sale.
Geir
Edited By Geir Ertzaas on 06/08/2011 15:10:33 |
Thread: ME 4407 - New Viewer |
05/08/2011 23:50:15 |
I am still hoping for some news on the new digital edition viewer. I can see that the last issues of ME and MEW is using the new viewer. However there is no longer a convenient printing option shown in the earlier preview. I am still mostly using an android tablet to view the magazines and even with the new viewer the PDF is still the superior way to read. Please reinstate the printing option to make the electronic version more readable.
Geir
21/07/2011 16:01:08 |
What happened to the new digital format in ME issue 4408? Are we back to the old reader?
Even though the new format was still a bit lacking with regards to mobile devices (tablets), it was still leaps and bounds beyond the old reader with the pdf export option.
Regards Geir
Thread: Accessing the digital MEW using an e-reader |
15/06/2011 12:25:04 |
The Motorola Xoom and other android tablets are also ruled out as the flash application is not compatible with touch controls. There was mention of a new e-magazine format that would be ipad/android compatible in a recent thread. This other thread also discussed pdf printing of whole issues. Some large screen e-readers might be able to display pdf files. |
Thread: Yet another index |
03/03/2011 14:05:03 |
Great index! Incredibly useful for a beginner.
I wish your index was included on the main model-engineer site with a direct link to the digital issues (for subscribers). That would be absolutely perfect...
Geir |
Thread: Digital Edition and tablets |
03/03/2011 13:51:35 |
I am having difficulty viewing the digital editions on smaller touch screen devices. Touching the screen causes the magazine to zoom in or out and makes it impossible to pan about the page. It would be very nice if the digital magazine was suitable for reading on an android tablet or an ipad. Is this something that is being considered?
Best regards,
Geir Ertzaas |
