Here is a list of all the postings AdrianR has made in our forums. Click on a thread name to jump to the thread.
Thread: How easy is it to make a chain sprocket? |
31/05/2020 17:32:37 |
A pure guess. In the evolution of the chain, for me it would make sense to have made a chain with a solid links that are joined using side plates. This would explain why sprockets had every other tooth missing as the chain only had a hole between the solid links. When the roller chain came along, if the pitch was the same it could run on the old sprockets. So maybe either the sprocket design took a while to catch up with roller chain, or the original chains were replaced with roller chain. Adrian |
Thread: Parting tip breakage |
30/05/2020 19:17:42 |
The way the tool sprang to the left and back looked rather odd. In slow motion it looks like the tool was pointing slightly to the right then twists back square. I suspect the cross/top slide has a lot of play in it. Another possibility is the spindle bearings are worn or the lathe is not rigid enough and the work climbed over the parting tool. Also from the swarf it looks like he was cutting harder when it broke. Unless of course he was moving the saddle to the left. Reminds me of trying to part on my worn out 1912 vintage Drummond, I had that climb right over the parting tool and stall on top of it. Adrian |
Thread: milling machine which one ? |
30/05/2020 17:45:26 |
I have just been through the process of choosing a mill. For me it eventually came down to SIEG SX2.7L or SIEG SX3. In the end I bought the SX3. Mostly as I wanted a mill a little bigger than my existing one and the SX2.7L was the same size. I have just finished a strip down and clean, which I highly recommend doing, and I have just measuring it's specs. So far I am pleased how well it is built. I bought it from ARC along with a starter set as I wanted to get the vise and clamping kit. I have not measured the vise yet, but it seems to be well built and the clamping kit looks OK.
Adrian |
Thread: Workshop Gloves |
30/05/2020 17:16:40 |
It is possible to get gloves designed for working with lathes etc. **LINK** If you don't want to wear gloves but want to keep fingerprints off your work, there are finger gloves. +1 for barrier cream I have a tub of Rozalex next to the workshop door, turn the alarm off and put it on. By the time i remember what I was doing it is dry.
Adrian |
Thread: Optical Chucks |
30/05/2020 16:36:23 |
If you fancy a project, MEW issue 98 pg 44 Simple Prismatic Centre Finding Microscope
Adrian |
Thread: Problems bending 3/16" dia copper pipe without kinking |
30/05/2020 16:23:49 |
I wonder if you could fill it with water, freeze it and then bend. Or possibly a sugar or alcohol solution which would freeze to slush.
Adrian Edited By AdrianR on 30/05/2020 16:25:52 |
Thread: New Lathe - cleaning the oil off |
29/05/2020 07:28:36 |
I just finished my new mill. Paraffin, tooth brush, couple of rolls of kitchen roll torn into quarters. I would also take the top and cross slide apart to clean the muck out of the slides, threads and bearings. Moly grease to reassemble and as said above oil it.
I put a magnet under my paraffin pot before poring it away, I am glad I took the advise to strip and clean, this was just from the quill and fine feed.
Adrian Edited By AdrianR on 29/05/2020 07:39:26 |
Thread: What Did You Do Today 2020 |
28/05/2020 19:11:12 |
At last, finally finished cleaning my new mill, very happy I did due to the amount of muck I got out of the bits that shouldn't have muck in. It is now all clean, greased, DRO fitted and bolted down. Now I need to tidy up the workshop and perhaps I should also clean the windows etc like George, there was a definite hint the other day. Adrian |
Thread: Lathe motor |
28/05/2020 18:51:26 |
I have a Kenwood Chef 902, it has an electronic speed control with speed feedback via a magnet on the end of the motor shaft. The speed is varied by moving the whole PCB to/from the magnet. If yours is like that you would have to work out to extend the speed control knob to where you can reach it. It should be possible to reverse the motor if it is the same as the 902 as the field and commutator are on separate wires. This site has some pictures and the circuit diagram **LINK** BTW the speed controller has a habit of failing. There are people supplying a small kit of components to fix the PCB. The kit I got from ebay also had new brushes too. Adrian Edited By AdrianR on 28/05/2020 18:54:22 |
Thread: Repair advice, please! |
28/05/2020 10:36:09 |
Looking at the drawings above, that looks like it could be fabricated out of 3" OD, 1/4" wall steel tube. m-machine-metals can sell you 76.2mm OD x 6.35mm wall for £17.83 + P&P Adrian |
Thread: Macro-photography |
27/05/2020 19:47:28 |
Blimy I manged it, helps if you put your hand between your eyes too |
Thread: Experimental Vibration Analysis of a WM280 Lathe |
27/05/2020 18:53:01 |
I had a go with my phone and a FFT app. Had to put sticky tape over the microphone so it only picked up vibrations. My lathe vibrates at 100, 200, 300, 600Hz. I am sure is all from the induction motor as it does not change when I stop the chuck. Quite surprised by the the energy in the higher harmonics, just occurred to me it could be the back chip guard ringing. Will have to check that. This check did make me take notice of the lathe noises, I realised my motor belt was too loose and slapping against the casing. Ho hum
Adrian |
Thread: Model engineering on BBC2 |
27/05/2020 17:50:07 |
I just found this youtube play list that explains how the machine works. **LINK** Adrian |
26/05/2020 12:41:16 |
Adrian, That is a great model. I would so love to spend some quality time with that so I could figure out how it actually works. All moves to fast to follow. Great name by the way Adrian |
Thread: Stressing over numbers |
26/05/2020 12:18:03 |
I watched a video by Stefan Gotteswinter recently about how to turn precision diameters, it is worth watching **LINK**
Adrian |
25/05/2020 17:11:54 |
A final thought for you. I have been looking at pictures of D-W and the MkII seems to have a thicker angular casting. It looks that it could be machined out of a solid block of CI. Could be an answer if all else fails. This site has a picture of it **LINK** Adrian |
25/05/2020 14:34:05 |
There is always metal stitching not sure how easy it is to buy the metalock stitches Could be worth giving them a call. |
25/05/2020 13:44:12 |
Just a thought re your 44 fudge factor 8000/180 = 44.44444. Your scaling factor in the fftfreq is 8000/size and size is 8000*180 I recently downloaded a FFT app for my android phone, I think I will go lay it on my lathe bed. Adrian
Edited By AdrianR on 25/05/2020 13:46:02 |
25/05/2020 12:53:43 |
Stupid question, what is a D-W?
Adrian |
Thread: Kennedy Hacksaw Crank refurb |
25/05/2020 12:49:13 |
My problem was hubris and a bargain, plus not wanting to get too close to the saw when I bought it. The mains lead was so hardened and cracked there was a couple of inches of bare conductor sticking out of the motor. When I saw it running smoothly I snapped up the bargain, didn't think to check how loose the slides were. Live and learn Adrian |
