Member postings for Andrew Johnston
Thread: Rev. Counter
13/07/2022 21:07:44
It's badly worded but I think the comment refers to the four magnets referenced by SoD. The answer is it gives four pulses per rev.That can mean a number of things:
* Faster response to a change of speed
* Same update rate but better averaging
^ Better S/N ratio equals more robust in the event of noise
Postscript: Beaten to it sad
Edited By Andrew Johnston on 13/07/2022 21:08:05
Thread: Advice on how best to convert a 3/16x40 Plug Tap into a Taper Tap
13/07/2022 10:38:18
Posted by Jon Lawes on 13/07/2022 00:33:13:
Our entire hobbies are "p**sing around"...
Speak for yourself, don't presume to speak for me. My aim is to make good parts with the least expenditure of time.
For the thread size concerned, especially in brass, I just use a plug tap or screwcut. No need to use taper/second taps.
Thread: Help with square thread
12/07/2022 21:45:05
Looking at the picture the thread is definitely Acme/trapezoidal, not square. Forget Wikipedia, Acme style threads can be whatever the manufacturer decides, although there are standards for the shape of the thread form.
Looking at the picture can we assume that the screw mates with a gear? If so then the flank angle of the thread should match the pressure angle of the gear. Furthermore the depth of the thread will be determined by the addendum and dedendum of the mating gear.
Thread: Connecting battery charger fly leads
12/07/2022 21:36:02
Posted by Mike Crossfield on 12/07/2022 21:16:39:
This is part of a sophisticated battery management system which includes recharging from regenerative braking.
That's a new one on me. I've designed the battery management hardware for a number of electric vehicle battery packs, including regen capability. But this was always for the main battery pack, not the SLI battery?
It turns out that regen is not as useful as one might think, not least because the battery needs to be at a relatively low SOC to accept the short term high currents without being over-voltaged.
12/07/2022 21:29:28
Posted by DMB on 12/07/2022 21:07:19:
...there would need to be a substantial build up of hydrogen...
Not so, hydrogen is explosive in air from 4% to 74%. When I first started working on electric vehicles in the early 90s we were using lead acid batteries. We had to have hydrogen sensors fitted in our battey room and in each vehicle. One of the experimental battery packs we were asked to look at had clearly had an internal fire, suspiciously just above the battery vent.
12/07/2022 20:35:44
Many car batteries these days are sealed, so they shouldn't vent hydrogen unless grossly overcharged. So no risk of explosion. I always connect my charger across the battery terminals.
11/07/2022 21:14:42
Posted by Emgee on 11/07/2022 19:37:55:
Would''t it be better to use the face of thicker wheel rather than the side of a wheel...
No idea what you're trying to say, but the reliefs on the tap are being ground on the periphery of the wheel, as shown in the Clarkson manual.
Thread: Filing rest - hardened guides ruining files
11/07/2022 21:10:51
Armchair - check
Popcorn - check
Beer - check
Let battle between hardened rollers and soft rollers begin!
I don't have a filing rest, but when using filing buttons I regard them as consumables and leave them soft.
11/07/2022 16:08:07
The proper way to grind reliefs on taps:
Thread: LED lamp help please
11/07/2022 12:26:26
Modelling a diode as having a resistance, or trying to measure same isn't useful. The forward characteristic of a diode is exponential. The forward voltage drop of a diode varies with current, temperature and the particular diode. The theoretical value (at an arbitrary current) is set by the semiconductor physics of the precise materials and doping levels used.
Most multimeters have a diode symbol on the dial, in which position the forward voltage drop of the diode can be measured. No measured drop means the diode is the wrong way round, or is duff.
From a practical stance the most important number for a power diode is the forward voltage drop at rated current as this will determine device dissipation and voltage loss for the following circuit. The drop at rated current is usually several times the nominal voltage drop.
I would agree with the above comments that a signal diode isn't the best choice; a power Schottky, say 1A rated, would be better.
On other points I'd also agree that running diodes in parallel is frowned upon. But sometimes needs must; a rule of thumb is that each diode should be rated for two thirds of total current. The only time resistance and diodes go together is when looking at the slope of the breakdown voltage with current in Zener diodes. The 'resistance' in breakdown is often listed on datasheets. The name Zener diode is a bit of a misnomer, as at higher voltages the breakdown mechanism is dominated by avalanche breakdown, not the Zener effect.
Thread: Making parting off tools
09/07/2022 11:55:45
This is what steel swarf looks like when using an insert parting tool:
The swarf is slightly narrower than the insert and considerably thicker than the selected feedrate.
See this discussion: Parting Off
Edit: Messed up the link
Edited By Andrew Johnston on 09/07/2022 11:59:16
Thread: Gear cutters
08/07/2022 20:23:00
I've decided it's not appropriate to outline the mathematical basis of gears in what is essentially a practical thread.The only thing I will add is don't get your hopes up about Tracy Tools or Home and Workshop. When I was looking for a range of 5 and 6DP involute cutters for the gears on my traction engines they never seemed to have anything in stock. I was able to buy a job lot of cutters on Ebay, from the US, that covered all the spur gear tooth counts I needed, except one. For that I bought a new cutter from Victornet in the US.
08/07/2022 11:04:59
Posted by raysal on 08/07/2022 10:28:45:
...it does not mater what DP or Module set of cutters I buy...
No, that is incorrect. I have to go out now, syndicate meeting about our broken sailplane, but will try and explain in more detail later.
08/07/2022 09:40:01
I'll second the book by Ivan Law. Good on the fundamentals of spur gears but weaker on more advanced types of gear. The maths isn't complicated, early secondary school level.
Which gear cutter to use for a spur gear is easy. For each cutter the range of teeth it wil cut is specified. Simply pick the cutter that covers the tooth count desired. The form of the cutter is exact for the lowest tooth count in the range and gets progressively less accurate as the tooth count increases. The errors are small and don't concern us in most ME applications.
Be aware that the numbering of cutters in the Module system is the the reverse of that in the DP system. So a number 1 cutter in Module will cut a gear of 12 or 13 teeth. In the DP system a number 8 cutter will cut a gear of 12 or 13 teeth.
Thread: Closing a thread, why?
07/07/2022 08:59:28
Posted by Nigel Graham 2 on 07/07/2022 08:49:36:
...because he thinks it might do that, or might have known it happen elsewhere.
Give me some credit; the decision was made on direct personal experience. I did visit a local club but it seemed to be full of whining old men. I also made the mistake of saying I was a professional engineer; you'd have thought I had farted in a lift given the response.
07/07/2022 08:39:53
Posted by RMA on 07/07/2022 08:07:46:
...we put the world right every week, and I have no doubt this is replicated in every club!
Which is precisely why I don't belong to a model engineering club.
Thread: Quick change toolpost
06/07/2022 22:07:01
See this recent thread:
QC Toolposts
Personally I don't use them, almost. A 4-way does for me for most turning and is more rigid, although I do run my lathe to the limits.
I would also agree with Tony, it is an unanwerable, and rather lazy, question. You might just as well say what is the best car to buy without giving any details.
Thread: Lathe tool recommendations?
06/07/2022 16:13:42
Posted by SillyOldDuffer on 06/07/2022 11:13:52:
...Must be useful for something, but to my mind they fall awkwardly between two stools.
Before the advent of inserts brazed carbide was recommended for iron castings to get under the skin, complete with sand, and to get through chilled area. i've got a few industrial ones from way back but haven't used them for decades. Carbide inserts work well, even for tough and hard materials. Plus the castings for my engines seem to be old school as they have never had any hard spots.
06/07/2022 14:24:20
Posted by Rowan Sylvester-Bradley on 06/07/2022 11:02:09:
...nothing to stop the tip being driven deeper into the tapered recess.
The tapered recess is just that, tapered not parallel. So once in place the insert does not move any further. I gently tap a new insert in place with a nylon hammer. I use 3mm inserts, but I use a relatively large industrial lathe:
Parting Front Wheel Hub
On a smaller lathe I'd use a narrower insert, probably 2mm if you go the insert route, narrower still if using HSS.
06/07/2022 09:49:45
Personally I wouldn't buy sets. Buy HSS blanks and grind your own tools. For carbide I use CCMT inserts for 80% of my centre lathe turning. My repetition lathe was designed to use 5/16" square HSS blanks so that is what I use. I suspect the Logan won't allow the best to be got from carbide.
For threading I use full form inserts, except for specials where I grind a HSS blank.
