Here is a list of all the postings Rod Ashton has made in our forums. Click on a thread name to jump to the thread.
Thread: EMCO 150mm Rotary table with Stepper motor indexing |
01/11/2018 10:38:54 |
Erm! Joe. how does the worm drive come out of the casting please?? |
01/11/2018 07:14:25 |
Reading and watching. Thanks Joe. |
Thread: For discussing the merits of alternative 3D CAD programs. |
31/10/2018 09:29:00 |
Better intro to FreeCAM :- **LINK** |
Thread: Rotary table with Arduino |
30/10/2018 14:49:52 |
Help. Was there an article(s) on converting a rotary table with a stepper and an Arduino in the MEW? Directions to issue No,s appreciated if it was the case please. |
29/10/2018 15:09:56 |
Joe that is fine. Thanks |
29/10/2018 15:03:42 |
Bazyle - Here is FreeCAM video also if you want to machine.**LINK** |
29/10/2018 13:13:01 |
Bazyle - **LINK** |
29/10/2018 13:00:24 |
Joseph - Could you be persuaded to share the details of your pre-load pulley/spindle adaptor please. |
29/10/2018 07:51:14 |
Had the identical 150 Emco. Plus a stepper, driver, and Arduino Uno under the bench for ages. Waiting for its project opportunity. Thank you for the inspiration. Go and hook it all out now. |
Thread: Learning CAD with Alibre Atom3D |
28/10/2018 16:25:11 |
Oh well I have only been at it for forty years. (Acad 78 I think) Bound to get the hang of it soon!! |
28/10/2018 15:52:09 |
Well I just redrew it to send you a screenshot and the trim function worked as I would expect. Must have drawn it in a more acceptable way. It was the first time I had used the programme. Apologies for wasting your time. Still playing
28/10/2018 14:47:29 |
Jason - I actually tried it both ways.( Incidentally the selection sequence is worth a observing) So if left with a circle and the two tangential lines to trim, I would usually accept a highlighted cutout suggestion, or select my cutting entities and then the portion to remove. Could not find a way to do it. At least by my accustomed methods? |
28/10/2018 14:04:14 |
Trying the demo version. Quite neat. Confused a little by the "trim" command. Drew a circle with two angled tangent lines attached. Then tried to trim out the inner unwanted portion of the circle from the line tangents. But it would only select and delete the whole circle. What is the procedure please. Hope I am not premature with queries? |
28/10/2018 11:24:25 |
For the cylinder fins :- If you do not have a 4th axis and could be bothered to make a form cutter? You could helically mill it in the vertical plane. Several basic cam programmes have this facility. i.e. Estlcam. |
27/10/2018 14:03:28 |
Muzzer - Further to your post. Take a look at FreeCAD. Lots of tube videos and the omissions above are mostly present and of course it is free. Edited By Neil Wyatt on 27/10/2018 15:53:14 |
Thread: Mikron F75 |
25/10/2018 10:56:35 |
Bill - If this is the belt driven horizontal head. I tried for a long time to figure it out. In the end I converted it to something else. Not too helpful I know!! |
Thread: Sussex Steam Co. can't contact them, no answer for weeks! |
24/10/2018 16:11:31 |
Over to you Dave. |
24/10/2018 15:08:13 |
Will give Fabiano the opportunity to reply and then it is available to you Dave if you would like it. |
24/10/2018 14:14:09 |
Fabiano - I have one of their Beam engine kits, unused. If that should be what you are looking at? It has the pre-soldered boiler also. For sale at half price if you would like it Edited By Rod Ashton on 24/10/2018 14:19:29 |
Thread: Sieg/Arc X3 CNC conversion |
20/10/2018 12:41:07 |
Well I have fixed it. Thank you gentlemen. There are two small 5mm screws that "secure" the X axis bearing block to the Y axis carriage. These were "like something in an old fashioned piece of headwear". As the Y axis screw was covering them, the screw needs to be wound back to the Y axis block after removing the stepper, the two aluminium keeper blocks and unscrewing the coupling shell. The two bearings are pulled off and the Y screw can then be rotated back to expose the 5mm screw positions. It is required to pull the loose table assembly forward about another 2", to clear completely. Fully degreased the screws and the sockets before fitting star washers and copious thread lock. Hard to believe that the integrity of my machine relied on two 5mm screws and no washers? I am a bit protracted here for the sake of any other owners. - If you have exposed spindle steppers, clamp something on there and rock the shaft while checking underneath at these two screws above the Y axis ballscrew.
