Here is a list of all the postings J Hancock has made in our forums. Click on a thread name to jump to the thread.
Thread: First Locomotive |
25/12/2021 09:54:31 |
If a professional seller 'sells' a boiler without a test certificate it is worth precisely scrap copper price. |
Thread: What to do with a sticky (as in toffee) portable radio |
25/12/2021 09:45:35 |
The 'rubber/plastic has been 'reconstructed ' into another polymer , no way back. |
Thread: 2021 Christmas Cracker-ish humour |
20/12/2021 08:37:29 |
Two cannibals eating a clown. One turns to other and says , " Does this taste funny to you "? |
Thread: Pin-hole in oil pan - which product to patch it? |
18/12/2021 22:38:53 |
And , if you get too many 'bits' inside the hole you are trying to seal it will finish off your auto box . Do it right , or not at all. |
18/12/2021 19:52:31 |
I would be very surprised if it was just one pinhole. If you 'mess ' with it I'm sure the truth will be revealed. Only one safe way , replace or repair it properly. |
Thread: Pulse Jet Petal Valves |
10/12/2021 13:26:53 |
The people with extensive running experience of these items were members of the Ghost Squadron , perhaps the RCME forums would be the place try. |
Thread: Boiler fittings |
06/12/2021 11:25:12 |
Of all the applications , the dome is most likely to , over time , see the affect of 'steam creep' through the joint and up into the stud apertures, then condense in the gap in the threads. Seize guaranteed. |
06/12/2021 08:57:39 |
As above , not a good long term idea to use same grade st. nuts.
Thread: Drilling and filling of the Dental kind. |
03/12/2021 19:50:51 |
My last visit to an NHS dentist was in 1962 Allington House , Ipswich , an evening appointment. I was 16 years old , it was the same establishment I had been taken to from 7 years old but this time I was working as an apprentice. Every single filling , up to this time had been done with NO injections of Novacaine and an 'electric' drill. BUT this event was Dustin Hoffman / Marathon Man on steroids. An old man with glasses appeared and said " the electric drill is broken " and proceeded to use a treadle drill. PAIN ....................... NEVER, EVER used an NHS dentist since.
Thread: LBSC drawing costs |
02/12/2021 12:23:08 |
Perhaps half the errors have been corrected. Only perhaps. |
Thread: Perfect Stainless |
02/12/2021 12:20:53 |
Only a guess but a decent dinner service of that era would be Sheffield made nickel steel ( not plated) , Tough is an understatement. |
Thread: Volkswagen |
30/11/2021 12:56:54 |
This bodes well for the future , just one cell u/s and it's game over. No limp home mode for you. |
30/11/2021 08:55:09 |
The first decent wind this year and 100,000 went without electricity for 'x' days. And if they had all relied on their EV.................? |
Thread: Metrotropolitan Vicker Single phase motor |
28/11/2021 17:25:23 |
May even be an early synchronous speed motor ? DC on to the slip rings to lock-on to mains frequency . |
28/11/2021 17:15:55 |
The same comparison by Volvo completely reverses those figures towards ICE cars being the lesser polluting for at least the first 7 years. |
Thread: I can't explain this - can you? |
28/11/2021 10:40:35 |
Yep, had the same thing with an electric lawnmower. Recharged battery , tried every trick 100 times over 4hrs , nothing. Placed an order for new one. 3hrs later and tried the old one again, worked first time ! |
Thread: show us your workshop. |
24/11/2021 09:00:04 |
A lovely idea Steve, in a perfect world. " BUT " , as my hero Harry Enfield would say,... " NO ", |
Thread: Does charging your car battery on fast charge damage it? |
23/11/2021 17:34:36 |
A 'standard ' cheapish battery charger output is not really 'dc' like the battery output , so be careful what you connect it to if not a battery . |
Thread: Dartmoor line to Okehampton |
23/11/2021 10:41:52 |
If the same criteria , as were applied by Beeching , were applied to most connections outside of city to city , I doubt if we would have any railways left. The cost of using the train for normal travel is just prohibitive. |
Thread: china/India - Cop 26 |
19/11/2021 08:33:56 |
A very good effort to justify heat-pumps Sam B , problem , compare the price we pay for gas/kwh against electricity/kwh and we see why , so few today , would choose to install heat pumps over a 'conventional ' gas boiler. |
