Here is a list of all the postings Brian Oldford has made in our forums. Click on a thread name to jump to the thread.
Thread: SEASONING OF CAST IRON |
27/04/2020 10:10:50 |
If you do use the oven make sure you have due authority from the domestic authorities.
Edited By Brian Oldford on 27/04/2020 10:12:19 |
Thread: The good bits coming out of the Covid epidemic |
21/04/2020 10:11:57 |
Posted by Andrew Evans on 21/04/2020 09:25:37:
great for wildlife and stargazing Or Musk Starlink Satellites tonight at 20.58.
Thread: Electronic Lead Screw Project |
19/04/2020 21:58:03 |
Posted by Phil Grant on 19/04/2020 20:51:12:
Nice job, I need to look at mounting mine at a right angle to the leadscrew. What machine have you got Phil?
19/04/2020 21:57:17 |
Posted by Zan on 19/04/2020 21:15:11:
Cracking. That’s a great idea. How will you shield it from all the oil dripping off the tumbler? The bottom inside of mine always has a thick layer of oil on it not excessive oiling, just doing the standard when I remember..... The tumbler will be removed as stepper reversal can done by electrical switching. If not by the SW, by an additional switch to alter the winding energisation.
Thread: Ace Myford S. 7 mod |
19/04/2020 20:07:48 |
Starts scribbling with biro to use it up so the cap can be pinched.
19/04/2020 19:58:56 |
After a minor hiccough with the first attempt I have managed to squeeze the stepper motor into the change-wheel housing of my S7. The first attempt left me unable to close the door without modifying it.
Edited By Brian Oldford on 19/04/2020 20:01:40 |
14/04/2020 18:44:13 |
I've followed this thread from its inception. I plan to drive my Super 7's lead-screw via 90 degree skew gears thus containing the stepper motor completely within the change-gear compartment. To design and make the mounting requires the removal of the banjo but I became side-tracked with other more pressing tasks. Now I'm back on track I'll try and put up some photos of my progress, Edited By Brian Oldford on 14/04/2020 18:48:28 |
Thread: Identifying carbide tips |
11/04/2020 17:39:04 |
Can anyone point me to a on-line resource to help me identify the code of some carbide tips I have please. |
Thread: Sealing circuit boards with silicone |
02/03/2020 20:06:57 |
Posted by duncan webster on 02/03/2020 19:51:47:
I used hot melt glue to pot some resistors recently (for track circuiting) A lot easier than messing about with 2 pack resins, especially for a small amount track circuiting what pray tell?
Thread: What a sad day for the British motorcycle industry. |
01/02/2020 18:11:41 |
Posted by Circlip on 01/02/2020 12:57:53:
Perhaps, in safe hands, part of the money about to be wasted on HS2 could be better spent? Regards Ian. Not wasted if you understand it. Production of a handful of motorcycles will benefit a handful of people. HS2, if completed, will benefit much of the population, even to those parts of the country as far flung from the network such as Aberystwyth.
Thread: Help with finding or making router duplicator |
14/01/2020 15:50:28 |
Posted by Journeyman on 14/01/2020 14:41:06:
Bit more up-market perhaps but is this Popular Mechanics item of any use? John I'm not too sure about the choice of material for the duplicate gun stock.
Thread: Co2 emissions.. Steam or diesel best? |
10/01/2020 15:35:38 |
Posted by Derek Drover on 10/01/2020 15:13:59:
If people are concerned about the emissions from "model" steam locomotives which are used on a very infrequent basis, perhaps they should spend more time worrying about their own personal CO2 emissions and hold their breath !! Particularly those most verciferous.
Thread: Removing superglue from an oak table |
30/12/2019 17:34:35 |
Posted by Nick Clarke 3 on 30/12/2019 17:21:59:
Unfortunately father daughter cashflow is unidirectional - and not in my favour 😥 Nothing new there!
Thread: Stanley Blade Lathe Finishing Tool |
26/12/2019 11:49:32 |
Interesting use of the bandsaw as a power-file towards the end of the video when he was making the knight. |
Thread: 042 Locomotive plans |
25/12/2019 16:48:59 |
Please can we use the correct Whyte notation and call it an 0-4-2 locomotive? Christmas rant over. Edited By Brian Oldford on 25/12/2019 16:49:34 |
Thread: Slight repair required |
19/12/2019 21:43:05 |
Posted by John Reese on 19/12/2019 21:30:55:
I would use oxy-acy using cast iron rod and ferro flux. Normalize after weldinf. If iron, without a specialist muffle to do a pre-weld preheat and (more importantly) post-weld normalise I wouldn't even think about welding. Brazing would be far safer thus minimising the likelihood of producing brittle carbides each side of the weld. Ali is a completely different ball o' wax.
Edited By Brian Oldford on 19/12/2019 21:44:10 |
Thread: MR16 LED Spot lights |
19/12/2019 21:38:42 |
I'm a little unsure why a number of us are getting all excited about varying voltages with varying lamp-holders. Similar pattern incandescent lamps and their LED replacements have been available for years in both 24v and 230v with B27 and GU9 bases Additionally both 24v and 110v lamps are available with E27 bases of the same pattern |
Thread: magnetic motor |
17/12/2019 21:20:22 |
Do I smell Snake Oil?
Thread: Myford Super 7b lead screw end float |
17/12/2019 21:16:49 |
Posted by John Haine on 17/12/2019 13:13:08:
But just to note that Hemingway charge £27 for £10 worth of thrust bearings and some bits of steel and bronze. There's no need to replace the existing bush so you don't need the bronze; and the end caps to position and shield the thrust bearings can be made from a scrap of 1 inch steel bar that may well be in your scrap box. For intellectual completeness could you provide a bearing part No? |
Thread: Keyway Broaching |
15/12/2019 21:02:02 |
Can you get access to a shaper? They are one of those much undervalued machines well suited to such tasks. |
