Here is a list of all the postings Brian Oldford has made in our forums. Click on a thread name to jump to the thread.
Thread: Sizing Round PU Drive Belt |
16/05/2015 08:58:45 |
Amongst others RDG also sell it on Flea-bay http://www.ebay.co.uk/itm/RDGTOOLS-TWO-FOOT-OF-ROUND-DRIVE-BELTING-3-DIFFERENT-DIAMETERS-TO-CHOOSE-FROM-/350656846669?pt=LH_DefaultDomain_3&var=&hash=item51a4c6db4d |
Thread: Cutting BSPT threads with a die |
13/05/2015 18:51:51 |
Sorry Gents; Jon Gibbs got what I meant. I should have been clearer in that I meant "I could be wrong". |
13/05/2015 09:22:33 |
Posted by Brian Wood on 12/05/2015 19:18:31:. . . . . .
Thread sealing by tape or other means would I think be wise in any case Brian
ICBW but isn't the whole purpose of the tapered thread to avoid the need for tape or other means? We're talking BSPT here not BSP. Edited By Brian Oldford on 13/05/2015 09:23:47 |
Thread: Myford ML7 or Super 7 |
13/05/2015 09:09:26 |
Posted by Russ B on 27/04/2015 23:24:41:
. . . . . . I've owned both the old ML7 and currently own the original Super 7 (with the glass sight oiler). . . .
I've also got what is often referred to as a Mk1 S7 but find the original (drum-brake type) clutch very noisy at the higher speeds. Can anyone suggest ways of making it quieter or can it be easily swapped for the later type? |
12/05/2015 08:44:00 |
Posted by Baldric on 12/05/2015 08:04:50:
What you have said is slightly wrong, some plugs have the thread cut with the tool at 90 degrees to the centre line, others at 90 degrees to the taper, you do have to make sure you get the correct type, and depending on where they came from may not be 11tpi. See **LINK** for full details. Baldric Clearly I haven't seen all variations and accept my post as being too encompassing. I should have said; As far as I'm aware all the ex-main line locos I've encountered use plugs as I described. |
11/05/2015 21:59:48 |
May I add what little I know to this discussion. Washout plugs on full size loco boilers have a tapered 11TPI thread. The threads on the plugs are lathe cut using a taper turning attachment and with the tool set as shown on the LH diagram by Jon Gibbs. |
Thread: Lathe chuck indexing? |
11/05/2015 19:13:18 |
Thread: Draftsight 64bit |
05/05/2015 08:04:31 |
Is anyone still using the 32 bit version? |
Thread: Myford ML7 Repairs and Renovation |
05/05/2015 07:34:55 |
Now having an old S7 (Mk1) after owning a ML7 for a time I agree regards the top-slide swivel. The bit I don't fully understand is the wide shear/narrow shear difference. |
04/05/2015 20:55:17 |
Whilst discussing repairs and renovations to the ML7/S7 range is there any way of producing a definitive list of inter-changeable parts? F'rinstance can a ML7 bed replace that of a S7? What's the real difference betwixt early and late head-stocks, saddles and beds? etc etc. |
Thread: How to make an arc furnace? |
01/05/2015 19:49:32 |
I have the vision of the lights dimming through brown outs in your neighbourhood every time you fire it up. Unless you follow Oompa Lumpas idea of using street lamp post supplies I suggest you also prepare yourself for some big 'leccy bills. |
Thread: Wood Glue for Teak |
29/04/2015 17:48:04 |
I'd be inclined to give the PU adhesive a go. Assuming it's the foaming type make sure the joint is firmly clamped to prevent the expansion opening the joint. If used primarily for its gap filling capabilities it'll have little or no strength. |
27/04/2015 06:00:38 |
Thanks. A good starting point. |
26/04/2015 21:38:51 |
I'm trying to get a George Taylor mill working that had all the original flat belt pulleys removed. A wet finger in the air says a 1450 rpm 1/2hp motor should be enough grunt . . . .but what rpm for the spindle? I've got a four step pulley that looks like it came off a S7 as a starting point.
26/04/2015 20:30:58 |
Can anyone point me in the right direction to determine the correct size round belt(s) to use to transmit power from a fractional 1450rpm electric motor. |
Thread: Inside cylinder casting patterns |
15/09/2010 23:23:26 |
If you are only intending casting a few from time to time go with the 4 piece pattern in a 3 piece box. (http://en.wikipedia.org/wiki/Core_(manufacturing)#Cheeks) |
Thread: help with seeing |
08/09/2010 19:39:26 |
Until I was 48 I managed without glasses at all. I then realised my arms weren't long enough so had to resort to ready readers. |
Thread: Caprotti Valve Gear |
28/08/2010 09:07:08 |
Thread: Rimless wheels |
20/08/2010 08:22:59 |
The link attached may explain things a little better. http://www.railway-technical.com/whlbog.shtml
Note: "Contrary to popular belief, the flanges should not touch the rails. Flanges are only a last resort to prevent the wheels becoming derailed - a safety feature." |
19/08/2010 09:06:04 |
Answering what I think is your question.
The reality is, on a correctly profiled wheel, the flanges rarely touch the rails. The wheelset is guided primarily by the tyre coning. |
