Here is a list of all the postings Doubletop has made in our forums. Click on a thread name to jump to the thread.
Thread: Sealey mighty mig 150 |
16/04/2018 20:50:51 |
Or Pete |
16/04/2018 20:45:30 |
Posted by sean logie on 16/04/2018 16:23:18:
The link for the welder is different setup to mine unfortunately. Sean Sean Maybe but the overall principles of the design will be similar. Here is another link with various posts of circuit diagrams for MightyMig variants Maybe different models but in all the cases the relay switches on the primary to the transformer. The variation is the way the voltage control taps on the transformer are selected. One other thought is the state of the transformer and whether you've got a short between the coils and it is overloading the relay. Give it a visual check to see if there is any obvious arcing. There was a time I could do the maths on transformers and possibly advise a method of checking with a meter. Unfortunately those days are long gone. Otherwise I'd suggest you jump on the mig welding forum in the link I've given you and ask the same question there. Pete |
16/04/2018 12:10:13 |
Posted by SillyOldDuffer on 16/04/2018 09:37:17:
Anyone got a theory as to why Sean's relay should fail like that? My first thought was that there's a dud capacitor across the contacts but the symptoms don't match. Could it be physical damage, something whacked into the case in the past? I prefer a desoldering pump to wick; both are useful depending on the job. Dave Here is the parts list with the circuit diagram **LINK** The only thing the relay does is switch the power transformer, maybe the back emf of a lot of repeated heavy current welding (switch setting on MAX 1) has finally killed the relay. Just a case of component mortality? Pete Edited By Doubletop on 16/04/2018 12:15:39 |
15/04/2018 09:26:50 |
It looks like it is one of these
Data Sheet here http://www.hongfa.com/pro/pdf/HF102F_en.pdf Beware when searching Ebay. You want a 24v version and they all seem to be selling the 12V version which appears to be JQX 102F. However some are advertising the HF 102F but as 12v which you don't want. Pete Edited By Doubletop on 15/04/2018 09:28:33 Edited By Doubletop on 15/04/2018 09:49:53 |
15/04/2018 09:24:02 |
As the relay is completely stuffed. Take a note of all the markings to help you search for a replacement. Then carefully break off the outer case and using snips cut away as much as the relay as you can. You are trying to get it down to 4 separate connections coming out of the board. Using pliers grip the connection on the component side and unsolder on the solder side and pull the connection free. Repeat for the other three. It may seem a bit drastic at first but it is far easier than trying to wrestle out 4 connections at the same time. Pete
Thread: Merryweather Steam Fire King self propelled |
15/04/2018 09:00:59 |
Werner You have it running very well Pete |
Thread: Bennie Railplane |
13/04/2018 11:21:27 |
Link to streetview and the location of the plaque below. Have a 'drive' around Apparently the railcar was stored in the shed now used by the timber yard. Edited By Doubletop on 13/04/2018 11:24:12 Edited By Doubletop on 13/04/2018 11:24:59 |
Thread: Where have all the Mondeo's gone |
10/04/2018 10:04:15 |
Posted by Zan on 10/04/2018 09:17:14:
So what's this to do with model engineering? Get real this is Facebook and Twitter rubbish We're in the tea room having a tea break... |
Thread: Diesel engines for miniature gauge locomotives? |
25/03/2018 10:57:25 |
One of our local club members has built a 'proper' diesel electric. Rather than plagiarise the article please open this link and read the whole thing. At the recent convention in Tauranga, one of the star attractions for me, and much of the public, was the DE loco of Tony Brown. This from a ‘if it ain’t steam, it ain’t a loco’ man. What made this loco stand out from the crowd? The DE ran with side panels removed, for cooling purposes, which hardly made it look elegant or authentic, (although I know some NZ diesels did run that way, out of necessity). The answer was in the sound, a genuine diesel growl, rumble, throb, or whatever you prefer to describe what emanated from the engine compartment......
He uses the 3 cylinder diesel engines from small Kabota tractor lawn mowers Also NZ uses 3' 6" guage so a larger loco when scaled to 7.25"
Edited By Doubletop on 25/03/2018 11:02:17 Edited By Doubletop on 25/03/2018 11:06:13 Edited By Doubletop on 25/03/2018 11:06:32 |
Thread: Vertical Boiler Fittings |
24/03/2018 07:30:56 |
Gary I see references to Sandy Campbells 3" boiler. There are plenty of refernces to it if you Google and build logs on some of the other forums. Drawings (but not the originals) here **LINK** Pete Edited By Doubletop on 24/03/2018 07:31:26 |
Thread: Model engineer's workshop to be cleared |
23/03/2018 08:00:31 |
That Boley looks nice and the collets and step chucks etc all look like they would nicely complement my Lorch. Pete |
Thread: super heaters |
23/03/2018 07:48:03 |
After I was advised to use the Harris Stay Silv black flux I've never had an issue with silver soldering copper to copper, copper to stainless or stainless to stainless. As part of my rebuild I remade the copper headers for my Dart superheaters that had stainless tubes and spears (not concentric). To add to the mix of the discussion one of our club members has been warning about the copper to stainless joints being susceptible to failure. The advice was:
The reason for these warnings were some failures recently. One was a failure of the stainless superheaters that were T’d into the copper header. Another case, apparently, was a loco with the superheaters ‘upstream’ and the copper stainless joint failed. The fire door was open and hot coals were ejected. Fortunately, the driver wasn’t on the driving seat. The upstream/downstream scenario comes about with the use of ball valves as regulators. Something that doesn’t occur with LBSC or Martin Evans designs. I’ve replaced the Stroudley regulator on my Dart with a ball valve but the super heaters are still downstream, but when a ball valve is located in the smokebox it most likely results in the super heaters being upstream of the regulator. The industrial engineers no doubt will have something to add…. Pete . |
Thread: ME vertical boiler |
23/03/2018 06:18:02 |
Posted by JasonB on 19/03/2018 10:07:11:
Gas As you say any air needed for combustion would be drawn in as part of the burner in most cases so not sure what the holes are for. The boiler looks remarkably similar the Sandy Campbell design. http://www.modelengineeringwebsite.com/3%22_vertical_boiler.html The holes in the side ar to allow the ceramic gas burner to draw in the secondary air. It would not be possible for the ~ 92% air required for combustion of the ~8% gas to be soley drawn through the holes in the jet assembly of the burner. Pete Edited By Doubletop on 23/03/2018 06:33:10 |
Thread: Slitting saw question |
09/03/2018 10:02:58 |
I'm glad to see that my limited experience with slitting saws reflects those of the experts. I've tended to avoid using them as much as I could becuase I wasn't sure I was using them correctly. Jasons video, with sound effects, was spot on with my efforts. I've resoured to making ny own arbours in an attempt to deal with eccentricity. Maybe I'll give them another go armed with the info in this thread, at least I was using the right speed... Pete |
25/02/2018 19:22:37 |
Werner We need to catch up. There are items of yours I could use and there's stuff I can share with you. I'll send you a PM
Pete |
25/02/2018 08:57:09 |
Werner Déjà vu? I'm looking forward to seeing what you have done Although theres not much constuctional detail in the zip file Neil posted for me (scroll down to his post). You'd need to read the ME article I'm currently working on a steam indicator using the same hardware Pete |
Thread: In praise of P M Research in the USA |
25/02/2018 06:15:24 |
Posted by Harry Wilkes on 23/02/2018 20:59:40:
PM Research also do a fine range included in that are steam fitting some of which are sold by Forest Classic but beware if you do think about purchasing any threaded parts they are to US standards. Link H I had a quick look at the site and some of their fittings look very nice. I noticed reference to 1/4x40 MTP and found this on their site So maybe not as much a problem but as Harry suggest be carefull Pete P.S. I've just ordered some of thelr globe valve kits. At $15 for 4 they've got to be worth a try, and no problems with thread sizing
Edited By Doubletop on 25/02/2018 06:55:08 |
Thread: TDA2030A Audio Amp |
16/02/2018 21:01:46 |
A late arrival at this discussion. For many years now, I've had a Technics deck on standby waiting for a preamp so I could connect it in to my home entertainment system. Over Christmas the Jaycar pre-amp kit was acquired and assembled. With a new cartridge it was all systems go. After the earthing was sorted, no hint of hum. The box of LPs from the 60's through 80's was dug out from the back of the garage and a day spent reminiscing. I grew up with those albums and they are ingrained in my brain. However, after such a long time it was now clear how production standards had improved over the years. Sgt Peppers from the 60’s was good but nowhere as good as Relax from the 80’s. The Pink Floyd and James Gang albums had noticeably different production standards as the years progressed. I spent years working with Jet engines, and the compulsory rifle firing as well as attending many F1 races pre and post turbos. Technically I’m deaf but not at the hearing aid stage yet. Music is in the ear of the beholder, that’s the variable that can’t be tweaked. Pete |
Thread: Arduino Uno Programming Assistance Request |
23/01/2018 22:48:38 |
Configuration management. You do it on physical engineering projects but can be so much harder in the virtual world when you can't see the detail
Suddenly all your imperial nuts become metric and things assemble properly
Pete Edited By Doubletop on 23/01/2018 22:50:44 |
19/01/2018 22:04:29 |
A further thought on this. Under certain conditions the use of PWM could result in the striker progressing slowly towards the bell as the power level increases. So basically you are reducing the acceleration rate of the striker when actually you want it to be at a maximum. Pete |
