Here is a list of all the postings John Purdy has made in our forums. Click on a thread name to jump to the thread.
Thread: Super 7 questions |
15/10/2021 18:20:09 |
Ignatz I just checked and while a M6 screw will screw into a 1/4 BSF threaded hole (sloppily), a 1/4 BSF screw will not go into a M6 threaded hole, it's too large a diameter. So your hole "C" may be either. When I screw a M6 screw into hole"C" it's a nice snug but not tight fit whereas into a 1/4 BSF nut it's a very loose rattling fit. John |
14/10/2021 18:24:33 |
Ignatz You say you checked the holes with some drill shanks. Be aware the core diameter of 1/4 BSF and M6x1.0 are almost the same so your hole "C" may be either. John |
13/10/2021 17:47:49 |
Ignatz I just checked my Super 7 (1976) and, although I have never been aware of it, there is some play in the bull wheel, about .010" at the periphery of the gear. As far as the threads go, as stated above, "A" is for the thread dial indicator ( on mine a 1/4 BSF stud and nut), "B" is 1/4 BSF for the traveling steady, and "C" for fixing the quick change gearbox (on mine this is M6x1.0). John |
Thread: Stuart engine paint colours |
21/09/2021 17:51:01 |
Here is my ST#1 in cream and chocolate brown. (What looks like white in the picture is actually a light cream, further pics in my album.) Edited By John Purdy on 21/09/2021 17:52:14 |
Thread: Digital image size |
13/09/2021 17:30:22 |
Thanks for the replies. Sounds like that's the way it is, so will have to live with it. Never been a fan of digital mags, even less now. |
11/09/2021 01:21:34 |
When bringing up a digital mag in the reader on this site it comes up at 100% size which is really too small to read comfortably. Setting the size to 150% makes it readable but as soon as you turn the page it reverts back to 100%. Is there any way to make it remain at a pre-selected size as the pages are turned? I have tried everything I can think of and nothing works. As it is it is most user unfriendly. John |
Thread: Tapping Drill sizes |
04/08/2021 01:30:49 |
Vic I've sent you a PM. John |
Thread: turbo-generator articles |
13/06/2021 18:12:03 |
Michael Further to my last, the turbo generator write up in Ray McMahon's Darjeeling build article is in ME Vol. 209 #4439 21 Sep 2012 and followup in #4443 16 Nov 2012. John |
13/06/2021 17:48:09 |
Michael I think the article you are looking for might be the one Peter suggested. It's in ME Vol.201 #4332 15 Aug 2008 and followup in #4334. It uses the innards from a windup LED flashlight. John Edited By John Purdy on 13/06/2021 17:48:41 |
Thread: Three Cylinder Steam Aero Engine |
31/05/2021 18:31:23 |
Dave I haven't decided. Apparently there have been quite a few build threads around but I don't think there has been one on this forum. What do people think? NDIY Sorry, there won't be a video of it running as I don't have any way of making one. There won't be an aircraft either as it is too big for a model and too small for a real one! The original swung a 4 bladed, 50 1/2" dia. prop at 2000 RPM generating 70 HP at 300 PSI steam pressure. Mine runs at ~800 RPM at 60 PSI. At that speed it is starting to vibrate, so to get anywhere near 2000 the crank balancing would have to be changed. The write up on the original makes no reference to the steam generator, but to develop 300 PSI within reasonable weight constraints I suspect it would have been a flash steam unit fired with liquid fuel. John |
28/05/2021 22:43:29 |
Now that the this engine is finished except for the stand ( still haven't found any material for that yet ), the next project will be a Red Wing hit and miss, castings are ordered and awaiting delivery.
11/04/2021 00:18:50 |
Here's my solution for the inlet plumbing, made from some pieces of aluminum and 3/8" OD tubing. Inlet fitting is a 1/4' flare fitting. So that's it, finished (except painting??? ). Now I guess I need to fabricate a stand for it and think about a prop !
Thread: Myford Super 7 spanner sizes |
08/04/2021 17:33:26 |
As well as the ones mentioned by JA my Myford (1977) came with a single ended 3/8 A/F spanner for use on the lock screws on the cross slide to retain the top slide. My two double ended Whitworth spanners are "Snail Brand". John Edited By John Purdy on 08/04/2021 17:34:05 |
03/04/2021 03:48:56 |
While re-setting the valves I found that the piston motion could easily be seen through the drilled exhaust ports in the cylinder and it was easy to judge when the piston was at TDC, so there was no need to take the crankcase back plate off. Also if I was doing it again I would make the valve rod ends that are in the valves longer to give more for a 11/32" wrench to grip to hold the valve from rotating as the jam nut is tightened. As it is, it only sticks out of the bottom of the valve slightly less than 1/16". The plans call for the head to be .388" long with the hole for the wrist pin .188" from the end. I would increase the .388" to .588" keeping the .188" the same (the valve rods would then have to be shortened by .200" to compensate ). I found that the valve wrist pins have to be very close to 90 degrees to the plane of the swing of the valve rods or everything jams up as the eccentric goes around, hence the need to ensure the valve doesn't rotate while tightening the jam nut. Edited By John Purdy on 03/04/2021 03:49:47 |
03/04/2021 00:52:15 |
Here are a couple of pictures of the completely assembled engine, minus the inlet plumbing. I first assembled it without oiling any parts to check the fits and it rotated quite freely with no binding. After oiling everything up and reassembling it its a lot stiffer due to the oil drag but there is no sign of any tight spots. The next thing is to design a stand for it and to figure out how I'm going to hook up the inlet plumbing so I can put some air to it and see if it runs. First the valve timing will have to be checked as I think things changed when I assembled it, which means taking off the back crankcase cover so I can see when the pistons are at TDC. For any one contemplating building one, the plans are nineteen 8 1/2 x 11 sheets stapled into a booklet easily separated for use. I found no dimensional errors on the plans but there are a few missing dimensions, but they could be determined from listed ones. The castings were generally good with some porosity in a few and some had minimal machining allowance, requiring careful setup before machining. As mentioned earlier the cast boss on the crankcase back plate was quite a bit smaller than the required finished dimension. |
31/03/2021 22:49:37 |
For the crankshaft counter weights, two slices of steel were sawn off some black plate and machined to be slightly oversize, finishing at 3.375 ( 3.378 ), 1.240 ( 1.260 ), and .851 ( .701 ). The holes for the 10-32 hex socket head cap screws for fixing them to the crank web were then drilled #21 tapping size and counterbored 5/16" diameter. Also two #21 holes were drilled in each for some 10-32 bolts to fix them to a jig plate to be bolted to the faceplate for turning the weights to the semi circular shape. These holes were positioned so that the heads wouldn't be in the way of any of the turning operations. When completed these holes will be plugged with some short lengths of 3/16" dia. rod. I had first considered putting the hold down bolts in the centre section that would be cut out for the socket that goes around the crank web but felt that this wouldn't provide a secure enough hold for the intermittent turning operations. Embryo counterweights mounted on the jig plate and centred on the faceplate using a wobbler in preparation for turning the outsides to the 1.760" radius. As pictured the balance was good enough to run at the lathe's lowest direct speed ( 281 rpm ). The outsides turned to dimension and the .250 x .265 reduced section on the corner of the outer diameter turned to size. Since the two halves are of different thickness, once the thicker one had been turned to .265" deep the thinner was only be .115" deep, therefore the thick one was removed to finish turning the thinner one. Finish turning the recess on the thinner weight, note the extra weight attached to the faceplate to counteract the out of balance. Milling out the recess for the end of the crank web, after chain drilling and sawing out the bulk of the waste. The holes for the fixing screws were then spotted through into the webs and the webs tapped 10-32, and the holes in the counterweights opened up to clear the #10 screws ( #10 drill ). The finished crankshaft counterweights with the holes used to fasten them to the faceplate yet to be filled in. The crankshaft with the finished counterweights attached.
21/03/2021 22:32:08 |
I just realized that for some reason I said the pipe fittings are 1/4 NTP and that the valve body was trapped 1/4 NTP when they are actually 1/8 NTP as Jason said. The valve bodies are currently tapped 3/8 - 32 but that can always be changed! I have thought about making the couplings, I don't have any large hex but have some round that I could make hex out of. I seem to recall that there was article in ME about making couplings with dimensions for various sizes of tube, have to see if I can find it. Edited By John Purdy on 21/03/2021 22:52:19 |
21/03/2021 17:24:25 |
Jason When I said the plumbing looked like commercial tube fittings I should have said pipe fittings as you say. The plans call for the inlet on the valve body to be tapped 1/4 NTP, so I assume all the fittings in the picture are 1/4 NTP. I agree that the union look too big, so am trying to come up with something that looks a little better. PM Research do a 1/16 NTP union which might look better.
21/03/2021 05:55:55 |
The engine partially assembled to mark the over length valve rods to final length. They were then cut to length and the bottom 5/8" screw cut 7/32-40. Reassembled, the valve timing was set by adjusting the length of the valve rods. Note the rear crankcase cover is not on since the tops of the cylinders are closed with the cover on there would be no way to tell when the pistons are at TDC, this way the crank can be seen to determine TDC for each cylinder. After roughly adjusting to get the right distance between the top of the valve and the top of the valve body as determined earlier (.197" ) the fine adjustment was carried out by rotating the valve rod, ensuring that the valve itself didn't rotate. As the threads on each end are a different pitch (.0357" and .025" ), one turn of the rod lengthens or shortens the whole assembly by .0107" depending on which way the rod is turned. The only thing left to do now is the counter weights for the crank shaft and plumb for the steam/air supply to the valve bodies(chests). I think I have come up with some material for the counter weights, need two pieces, 3.335"x 1.200", one at .850" thick the other, .700" thick. As far as the plumbing I'm not sure what to use. From the picture of the model it looks like commercial tubing fittings were used.
Edited By John Purdy on 21/03/2021 05:57:09 |
18/03/2021 00:49:28 |
The finished "eccentric" with the two upper valve rod ends mounted and the bronze eccentric pin bushing pressed in. The manufacture wasn't as bad as I had anticipated and the 5/16" end mill that did most of the work is still acceptably sharp!
Edited By John Purdy on 18/03/2021 00:49:58 Edited By John Purdy on 18/03/2021 00:51:08 |
