Here is a list of all the postings bernard towers has made in our forums. Click on a thread name to jump to the thread.
Thread: Bearings |
20/06/2022 17:41:07 |
I agree with Noel buy decent bearings and buy once. |
Thread: Pultra 10mm Collet Blocks |
19/06/2022 08:04:38 |
I am in the process of making some er16 blocks so they can be used in the sherline. My only complaint with my er25 blocks is that I find them a bit on the short side a problem I hope to get over when doing the er16 version. |
Thread: Book on lathe operation ? |
18/06/2022 22:38:20 |
The amateurs lathe by Sparey for one but google gives you plenty of choice . |
Thread: 48DP gear cutters needed 14-1/2PA, no 4 and no 8 |
18/06/2022 20:55:55 |
Any reason for not using 20 deg gears?. They are stronger and tooling is more commonly available. |
Thread: Blacking aluminium |
18/06/2022 20:42:47 |
coloured anodising is achieved after the anodising process is completed. As I understand it anodising that is going to be coloured is done at a higher amperage to make the pores larger to more readily accept the colour, |
Thread: Edge finder lubrication |
18/06/2022 12:01:10 |
like Thor I use Hyd oil as it is less prone to drying out and its moisture repellence is second to none. you could also try 3 in 1 oil as it is a light machine oil that doesn't dry out. |
Thread: Governor drive belt |
18/06/2022 11:47:27 |
to undo spring belts just put under a bit of tension and unscrew, never had any trouble with mine. you might have been a bit over zealous with your tightening. Edited By bernard towers on 18/06/2022 11:48:23 |
Thread: A TOPICAL point, FANS. |
17/06/2022 21:53:32 |
All our vehicle locks and some were cat 5 security were always lubed with graphite from a puffer. |
Thread: Black and Decker hammer drill |
15/06/2022 21:47:37 |
I would have thought if your locking screw was LH the chuck is 3/8 or 1/2 RH UNF. put a piece of bar in one of the chuck key holes arrest on the bench and give the bar a good whack it should loosen your chuck. |
Thread: FORUM DOWNTIME AND RESULTING ISSUES REPORTING |
13/06/2022 18:11:39 |
log in still SLOW on i pad MacBook and iMac !!!!! |
12/06/2022 23:24:34 |
log in is now taking an age
Thread: Axminster Tools |
12/06/2022 09:35:21 |
So they are matching other suppliers prices! |
Thread: parting off copper pipe in the lathe |
10/06/2022 22:53:45 |
use collets and WD40 as a lube |
Thread: model engineering website . com |
05/06/2022 20:14:33 |
has anyone had dealings with this site as they have taken my money but don't respond to emails? |
Thread: Cutting threads |
05/06/2022 19:33:31 |
I have to agree that it’s likely that it’s dwarf in the die and as it’s silver steel the swarf is slightly hardened causing your damage. I just wonder why you use silver steel to make screws?. From my own perspective it’s a horrible material for that sort of work. Most of the small screws that you buy are from an easily machined steel and if really necessary machine from a material that readily hardened EN8 , EN 16 etc. The other possibility is to use 303 or 304 st st. |
Thread: Finally able to get good finish on mild steel |
03/06/2022 19:24:29 |
The bolts in the picture do not look like mild steel as they are black which means they are likely to be HT of some strength or other from 8.8 upwards, that's maybe why you where having trouble getting a good finish. I have found that when turning these that a low mandrel speed helps. |
Thread: Buried-cable detector |
03/06/2022 19:16:54 |
I use a Draper one that can tell the difference between nails and screws and power cables |
Thread: Back gear and tumbler reverse |
02/06/2022 22:40:20 |
CHris. there is a copy of Bradleys book for sale on the home workshop site, super cheap. Edited By bernard towers on 02/06/2022 22:40:52 Edited By bernard towers on 02/06/2022 22:41:19 |
Thread: The Correct Way To Sharpen Drill Bits Using A Picador Drill Sharpening Jig With Custom Base |
01/06/2022 22:42:57 |
Just came across this thread and am a little confused as you say that you use silicon carbide wheels. I have been under the impression for the last 40 plus years that that material is for soft materials and carbides but am ready to be told otherwise. and as for grinding on the side of the wheel is NO NO NO the reason being is that when using the front face the wheel is in compression but on the side you are trying to separate the bond. Ask Norton abrasives what they think. |
Thread: Metallurgy of Copper |
01/06/2022 22:17:15 |
Clive that's hardening by movement/vibration. |
