TiddlerTad | 18/06/2022 09:36:47 |
55 forum posts 2 photos | Hi Edited By TiddlerTad on 18/06/2022 09:38:47 |
Hopper | 18/06/2022 09:51:31 |
![]() 7881 forum posts 397 photos | HPC sell a full range of DP48 gears readymade if you wanted to go that route. Not as much fun but maybe easier? |
Brian Wood | 18/06/2022 10:18:13 |
2742 forum posts 39 photos | Hopper, HPC gears will all be to 20 degrees PA and whilst they will mesh with the others, life of the gears thus meshed in service will be short Regards Brian |
Hopper | 18/06/2022 10:58:44 |
![]() 7881 forum posts 397 photos | Yes you have to make them all 20DP. Still might be cheaper than importing cutters. |
bernard towers | 18/06/2022 20:55:55 |
1221 forum posts 161 photos | Any reason for not using 20 deg gears?. They are stronger and tooling is more commonly available. |
John Haine | 18/06/2022 22:01:11 |
5563 forum posts 322 photos | Make your own cutters by the button method? |
Huub | 18/06/2022 22:47:23 |
220 forum posts 20 photos | Making gear cutters isn't difficult and you can make them using a mill, a vice and a tapered drill (centre drill) |
Hopper | 19/06/2022 00:06:11 |
![]() 7881 forum posts 397 photos | Posted by Huub on 18/06/2022 22:47:23:
Making gear cutters isn't difficult and you can make them using a mill, a vice and a tapered drill (centre drill) Great video. Thanks for that. |
DiogenesII | 19/06/2022 09:04:36 |
859 forum posts 268 photos | For a light-duty application, depending how close the desired tooth count is to that of the cutters that you have, using those will make a pair of gears that mesh and run together acceptably. For example if you need say, a pair of timing gears for a model engine, using a '5' cutter to make a 30-tooth instead of a '4', and '8' to make a 15-tooth pinion instead of a '7' is probably a realistic option.. ..dependent on the sizes / desired clearance you may need to slightly adjust the centre distance.. I wouldn't use this method for a timepiece or power transmission, but for certain applications it will work and the results can be surprisingly good - involute cutters are a very loose approximation in any case. If you want to try out the cutters that you do have, it's probably worth making a 'trial' pair in some easily cut material like brass, alu, or even acrylic, and seeing how they mesh.. |
