Here is a list of all the postings bernard towers has made in our forums. Click on a thread name to jump to the thread.
Thread: Welding a plain bearing |
30/05/2023 17:38:12 |
Just thinking that not everyone has a 20mm reamer, you can make a hone or a lap. |
Thread: Material for Collet Holder |
30/05/2023 17:36:05 |
Dalboy, I made 7 and the nuts were £22 and the material was in stock plus how much is satisfaction per hour? |
Thread: Help Please: Top-Slide Angle Setting. |
30/05/2023 16:30:48 |
To get away from this problem I sometimes fit a right angle round bar to the end of dti shaft and then dti above centre height. the bar drops vertically so is always on centre height. |
30/05/2023 16:24:25 |
You could make a hone to use after welding. |
30/05/2023 16:21:46 |
Thread: Custom nut (Round slotted knurled thumb nut |
26/05/2023 21:03:51 |
diameter looks a bit like 5/32 and tpi should be simple enough with a good rule and eye loupe |
26/05/2023 17:10:23 |
Does distance matter |
Thread: Bending 12mm square mild steel bar |
26/05/2023 16:10:02 |
THis cut and shut idea is fairly common its quick and you don't need 3 hands! |
26/05/2023 16:07:13 |
If you post a drawing you may get a response |
Thread: Any idea where to buy? |
26/05/2023 16:02:31 |
How many do you need? Mine are 7/8 Edited By bernard towers on 26/05/2023 16:03:29 |
26/05/2023 12:12:55 |
depending on what its use the cut and silver solder route would give you a sharper corner, or it could be big welded. |
Thread: NEWBIE FROM SOMERSET |
23/05/2023 09:12:43 |
that's going to keep you busy but the end result will be something special. I am working on a 0.1 Ci single at the moment and the problem of limits and fits is stretching me I fear, best of luck and keep us updated |
Thread: Myford cross slide dial |
21/05/2023 14:32:17 |
Can only point you to MEW 328 page 9 to 16 which should be of help. |
Thread: Holding pipe when anodising?? |
20/05/2023 19:29:10 |
Fulmen, surely you mean depth as anodising is not adding to the material but changing it! |
Thread: very odd |
20/05/2023 18:54:41 |
High pressure fuel pipe, old direct injection feed pipes were like that. |
Thread: Steam paddle steamer |
19/05/2023 15:22:43 |
Dave, and at one time I could see it from my bedroom window as it made its way through Thorpe narrows on th way to Norwich ! |
Thread: Whats the best material to withstand impact? |
17/05/2023 17:25:25 |
Try Makrolon Its a better version of perspex often used for machine guards and in layers for bulletproofing! |
Thread: 1920s Lathe spindle removal |
17/05/2023 17:14:44 |
1920s with Polyvee that's novel and it proves the spindles been out before! |
Thread: BSW threads on fobco drill |
16/05/2023 09:20:58 |
My mates fobco has the nameplate fitted with drive screws! |
Thread: What Size |
11/05/2023 19:48:35 |
The odd Stuart fittings I have looked at have the blanking bolts all threaded 40 tpi by either 1/8 or 5/32 or 3/16 and the threads that fit to boiler bushes appear be 32tpi. I think I would double check your 0.158 measurement as it sounds very unlike Stuart ! |
