Here is a list of all the postings Eric Cox has made in our forums. Click on a thread name to jump to the thread.
Thread: It's not engineering but |
01/06/2019 10:25:02 |
The latest construction for the doll's house, at least it's right twice a day
Thread: Threading 1/8 stainless steel |
14/05/2019 10:37:37 |
cracked it 1 skimmed 5 thou of diameter 2 Bought an MT adaptor at Doncaster and mounted Jacobs chuck in head stock 3 Cut thread simples |
01/05/2019 10:14:14 |
The die is mounted in a die holder in the tail stock. plan of attack is, clean with acetone open die fully use aluminium block plenty of Rocol pray |
30/04/2019 22:22:15 |
I'll try the collet
30/04/2019 16:04:52 |
I'm trying to cut a 5BA thread on 1/8" stainless steel rod held in the 3jaw lathe chuck. The die starts to cut then the rod slips in the chuck marking the rod. Would I be better off using a 1/8 c0llet chuck. |
Thread: Vickers Bl 8 inch Howitzer cannon of 1917 |
22/04/2019 16:26:13 |
Looking at the spokes being milled took me back to my apprenticeship and milling steel samples ready for tensile testing. It was the dread of every apprentice.
Thread: Coming up for auction |
27/01/2019 10:00:13 |
Just need a few more pennies |
Thread: Uncomplicated Steam Boiler for first wobbler please |
27/01/2019 09:54:25 |
If you are unsure of your silver soldering capabilities why not buy a cheap Mamod system from flea bay or your local auction house. Don't forget to pressure test the boiler though. |
Thread: Stuart Beam Engine |
04/01/2019 14:18:37 |
Thanks Jason, I should have paid more attention to the drawing |
04/01/2019 10:17:53 |
On the Stuart beam engine how deep does the recess on the top of the column need to be to take the entablature arms. |
Thread: Alibre link |
28/11/2018 10:20:31 |
When the alibre forum started I saw a link that took you to a 200 odd page instruction of drawing two flywheels connected by a universal joint. I can't find the link, can someone point me in the right direction. |
Thread: Alibre atom |
14/11/2018 14:40:41 |
Just bought MEW to get the Alibre Atom only to find it doesn't run on a mac. Bummer, any chance of a refund. |
Thread: what Christmas present |
05/11/2018 10:59:24 |
Given a limit of £500 what model engineering related Christmas present would you like to receive. |
Thread: Another what is it |
01/11/2018 09:38:47 |
It's a duel size adjustable spanner. One side is imperial the other side is metric Edited By Eric Cox on 01/11/2018 09:42:10 |
Thread: Given the Elbow |
23/10/2018 15:35:30 |
It was a Stewart Hart design published in ME August-September 2011 Looking at the link above it looks very similar. Edited By Eric Cox on 23/10/2018 15:39:54 |
23/10/2018 09:18:51 |
100 mm flywheel, not bad for a conquest super (now superior) with an 80 mm chuck. All that's left to do is to get it running. |
Thread: Machining gun metal |
19/10/2018 11:59:57 |
When machining gun metal should it treated the same as brass and cut at a high speed |
Thread: Warwickshire Event Centre, Leamington Spa |
12/10/2018 09:55:43 |
Careful what you say or every one will turn up on Friday |
Thread: LBSC |
10/10/2018 10:56:37 |
Many moons ago ME reprinted LBSC's article on building Ayesha. As Curly designed many loco's how about another reprint of his articles . |
Thread: Steam chest design. |
07/10/2018 10:13:24 |
The original had two valve chests with separate valve rods per side run off two inboard mounted eccentrics. Yes Neil, so would I |
