Uncomplicated Steam Boiler for first wobbler please
BW26/01/2019 12:05:02
249 forum posts
40 photos
Hello,
This one seems too simple anybody built it ? Any comments ?
http://npmccabe.tripod.com/simpleboiler.htm
Am getting a tadge confused about boilers - have done some googling and they seem to be complicated things.
Any recommended boiler plans / websites / books for a novice builder to consider ? I only want to run little models of wobblers ie over the next few years maximum bore 25mm maximum stroke congruent with that.
My first wobbler running quite happily on 12volt car tyre inflator but would like to have a go at running it on steam.
Bill
BW26/01/2019 12:09:11
249 forum posts
40 photos
....... and this one doesnt seem to complicated
http://www.steves-workshop.co.uk/modelboats/steamlaunch/boilerdesign/simpleboilerdesign.html
Brian G26/01/2019 13:08:57
912 forum posts
40 photos
You could look at Tubal Cain's "Building Simple Model Steam Engines". **LINK**
Former Member26/01/2019 14:42:56
1329 forum posts
Tomfilery26/01/2019 16:23:30
144 forum posts
4 photos
Bill,
Your first proposed design is awful - made literally from a soup tin - don't even consider it!
Your second one looks a much safer bet.
Regards Tom
Former Member26/01/2019 16:34:48
1329 forum posts
BW27/01/2019 00:05:28
249 forum posts
40 photos
Thanks for your comments.
Have ordered the first Tubal Cain book and shall commence learning how to silver solder. Have been avoiding doing this for some time now.
FYI ........ Interesting that I just saw a thread on the Mamod alternative forum where the use of silicon rubber tube to carry steam is considered. That might make things easier for us novices.
My wobbler only needs 5psi .......... I saw a thread somewhere recently where a garden weedspraying backpack with the long lever manual pump handle was used to power a wobbler.
Bill
Martin Whittle27/01/2019 08:10:34
102 forum posts
12 photos
Even more simply one can use a bicycle pump for a quick demonstration. The speed is a bit erratic when pumping, but it works!
I used a schraeder valve body for the air connector on my Reeves Master HO. So the model is easily connected to a compressor, or a bike pump.
Martin
Eric Cox27/01/2019 09:54:25
557 forum posts
38 photos
If you are unsure of your silver soldering capabilities why not buy a cheap Mamod system from flea bay or your local auction house. Don't forget to pressure test the boiler though.
BW27/01/2019 12:13:29
249 forum posts
40 photos
Posted by Eric Cox on 27/01/2019 09:54:25:
Thanks, I always assumed they would be hideously expensive to buy and rarely available.
I will have a look.
Martin
Martin, thanks for the tip, I need to learn the names of various fiddly little things like "schrader valve body" and the different types of tubes and tube fittings etc
Bill
Former Member27/01/2019 14:43:11
1329 forum posts
BW28/01/2019 22:44:45
249 forum posts
40 photos
Posted by Bill Chugg on 27/01/2019 14:43:11:
BW
Have a go.
Bill
Bill,
Thanks for the advice. Am having a go, investigating required tools and materials. Got some books ordered from library.
Will be quiet for a while then shout out after first boiler completed.
Bill
Paul Relf-Davies29/01/2019 12:56:39
84 forum posts
I'm not sure where you are based, but you could do a lot worse than to sign up for the Society of Model & Experimental Engineers' 'Polly' course, starting in May (in South London).
You will end up marvellous little vertical boiler & wobbler engine, plus get a great grounding in a wide range of model engineering techniques.
The ability to ask questions & get feedback on on you progress - plus getting your boiler properly pressure tested - is invaluable. You can't get that from books & videos
P.
Full disclosure: I built this on the course last year...
Edited By Paul Davies on 29/01/2019 12:59:50
BW30/01/2019 00:31:54
249 forum posts
40 photos
Thanks Paul that looks stunning.
Have applied to join Melbourne branch of SMEE
Bill
Paul Ainsworth12/02/2019 16:04:17
97 forum posts
15 photos
54mm copper tube from the plumbers merchants is ideal. I got a 3 foot offcut for £10 from mine, enough for 5 boilers.
My boilers are silver soldered and pressure tested to 60 psi and cost a lot less than a mamod one.
Bill
What thickness end plates do you use?
Edited By Paul Ainsworth on 12/02/2019 16:47:39
