Drill press KTF-13
Svarven29/12/2013 13:34:45
35 forum posts
8 photos
Hi
Is there anybody who have a manual or drawing for the
KTF-13 Drill press
(King Feng Fu Machinery works co Ltd)
Bertil
Svarven01/01/2014 17:38:56
35 forum posts
8 photos
I have to disassemble the spindle then this unfortunately was a little crooked. So it can be when buying used items.
This machine is available under a variety of names.
So if anyone can help me with instructions to mount the spindle down without ruining anything, I would be happy.
Nobby01/01/2014 17:50:03
587 forum posts
113 photos
Hi
cant help with spindle . But I notice in No. 2 photo . there is a large gap between the head and the stop on the pillar . elf and safety . slide it back under and lock in place . if you swung the head round at the moment the head would drop and my do some damage or injury . Please accept this in the spirit of this forum
Nobby
Roderick Jenkins01/01/2014 18:20:57
2376 forum posts
800 photos
Bertil,
Apart from the colour it looks the same as my Naerok. Mine has quite a lot of runout on the quill and I have just replaced it. Sorry I can't help with your problem
Nobby,
The head is fixed. That ring is the upper locator for the rack to raise the table. Sadly, not like a Fobco.. Kind thought though.
Rod
PS If anybody wants the Naerok its free for collection from Tadley.
Oompa Lumpa01/01/2014 19:45:31
888 forum posts
36 photos
That drill is identical to mine but mine is branded Nu-Tool.
I have owned it for exactly twenty years now and it has always done as asked.
The only issue I have is that the handles to lower the quill have come loose and the threads are shot.( The three round bars with the balls on the end are loose in the capstan)
If anyone has a fix for this I would like to hear it.
graham.
Oh, yes - mine is green!
Edited By Oompa Lumpa on 01/01/2014 19:47:37
Bazyle01/01/2014 23:17:17
6956 forum posts
229 photos
1997 178 4037 330 Peter Spenlove-Spenlove Constant Force Springs and a Problem Solved Discusses Tensator springs
I haven't checked but this might be an article about replacing the spring with a tensator spring. If it is the article I remember it probably has some information for taking off the original spring and reworking the spindle rack fit.
Trevorh02/01/2014 09:04:09
316 forum posts
89 photos
Hi, if it is assembled like the old Alpine then its quite straight forward
with the spindle in the raised position you need to remove the coiled tensioner spring
next remove the 3 handles and gently pull out the splined shaft
once this is out you can now -by hand- lower the main shaft out as a unit
once out there will be a couple of circlips to be removed and then the inner shaft can be removed
you now have access to all of the main components - had to do this to my Alpine to change the Taper roller bearings the other month
cheers
Svarven04/01/2014 16:10:08
35 forum posts
8 photos
Thanks
Now i have to test that.
Bertil
