Here is a list of all the postings Mark P. has made in our forums. Click on a thread name to jump to the thread.
Thread: Centre punch |
04/07/2018 10:11:27 |
Morning all, does anyone know where I can get another one of these spring punches? https://www.model-engineer.co.uk/albums/member_photo.asp?a=48690&p=807571 Mark P. Edited By Mark P. on 04/07/2018 10:12:04 |
Thread: New shed- bedding material |
12/06/2018 17:07:23 |
John, how about conveyer belting? Mark P |
Thread: What did you do Today 2018 |
28/03/2018 08:45:53 |
Hi Mike, had the same trouble with my local B&Q, I reckon it is the way they store their timber.Either that or the way the wood is dried. Mark P. |
Thread: Any other out of touch members ? |
27/02/2018 18:45:07 |
We've not had a telly for years. We have an old DELL laptop (2nd hand) I do have an old smartphone, well a fairly clever phone I wouldn't call it smart.I really don't need all the so called mod-cons. Mark P. |
06/02/2018 11:53:24 |
I took out all the electric storage heaters out of my bungalow,ready for central heating instalation.Found out the bricks stay hot for a long time! Mark P. |
Thread: R8 chuck problem |
10/01/2018 18:57:25 |
Hi Richard, I hold the front pulley on my VMC to tighten my er chuck. Mark P. |
Thread: What's the strangest project you've ever seen in an old ME or MEW? |
19/12/2017 17:05:38 |
Not MEW or ME, I have a set of The Amateur Mechanic dating from around 1920/1930 which has a build your own Xray machine! Harmless fun it says amaze your freinds and relatives! Mark P. |
Thread: Best Parting off tool |
06/12/2017 11:47:56 |
I've been using a T shaped parting blade from Chronos, made my own holder myself, best parting blade I've ever had! Mark P. |
Thread: Chester or Warco. |
21/11/2017 16:58:46 |
Don't know about Chester but I can't fault WARCO had 3 machines from them and their aftersales service is great. Mark P. |
Thread: Sketch/Drawing holder |
16/11/2017 12:38:58 |
I use one of those plastic coathangers with the clips at the ends, clip your A4 drawing on and hang it up. Mark P |
Thread: New chinese lathe or old Myford lathe |
18/10/2017 19:06:31 |
I've had a Warco WM250 for about 10 years and has done everything and more I have asked of it. Apart from fitting a VFD and motor I've had no real trouble with it. Mark P. |
Thread: Trouble at Mill! |
16/10/2017 12:12:00 |
Says a lot doesn't it Rod! M. P |
15/10/2017 18:26:57 |
Can I keep this thread going, because if it is the company I think it is myself and another person have a vested interest in it. Ie we are owed money. |
13/10/2017 22:02:21 |
Pm for you Geoff. |
Thread: WM250 thread cutting |
23/09/2017 17:57:52 |
Dave, same you I think I've only screwcut on my lathe a small handfull of times in 10 years I normally use a tailstock die holder. I only needed to cut the 20TPI 1"dia thread to make a puller to remove the clutch hub on my 57 Triumph Thunderbird. Mark P. |
23/09/2017 16:39:04 |
John,I know exactly what you mean about not having enough hands! I am thinking about making a new shorter banjo when I have a bit of spare time. Mark P. |
23/09/2017 13:21:47 |
Thanks Jason, I thought I had set it up correctly, I think I may have a longer banjo fitted! I suppose I could machine a bit off the top of my banjo. Regards Mark P. |
23/09/2017 12:55:53 |
Jason, I have the 50T on the right hand side ie next to the headstock with the 45T on the left, the 30T is in contact with the 50T the 45T gear is in contact with the 85T leadscrew gear have a gap of 4.5-5mm between the 30T and the spindle gear! Mark P. |
22/09/2017 15:13:11 |
It appears like that in my photo but the 30T is being driven by the 50T gear with the 45T in front of it. Not much a photographer. Mark P. |
22/09/2017 14:01:17 |
Thank you chaps, job done. This is what I get when I set up as per the charts http://www.model-engineer.co.uk/albums/member_photo.asp?a=43809&p=766181 the banjo contacts the head stock spindle. Mark P. |
