Member postings for Mike Poole
Here is a list of all the postings Mike Poole has made in our forums. Click on a thread name to jump to the thread.
Thread: How can I cut a 0.75mm radius on a piece of soft rubber sheeting?
25/02/2022 00:28:05
I think cutting an accurate radius will need to be ground or the rubber to be frozen and then cut, trying to cut rubber at room temperature will run into the problem that the rubber distorts before it cuts so the cut surface will have an undercut caused by the rubber yielding before the cut takes place. This is a tiny radius and it would be interesting to know why it needs to be accurate, Rubber being an elastic material is rather tricky to produce to an accurate dimension.
Thread: Songs about Engineering
24/02/2022 12:10:28
Early Einstürzende Neubauten songs had a very industrial sound, much of the sound was produced with scrap metal.
Thread: Front door locks
22/02/2022 11:26:18
I worked with a chap who had an implant in his hand to operate his front door lock, electronic locks are increasingly popular as many hotels have embraced them. The RFID tags are very effective access control and even if a tag is lost or compromised it can simply be deleted to restore security. They could be issued to carers and the window of access programmed for their appointment times and days only. Center Parcs have installed a RFID system that controls accommodation access, swimming pool lockers and can be linked to a bank card for cashless payments to in pool refreshment facilities. The tag is contained in a wristband that can be worn in water. The company I worked for had a photographic ID card that contained a tag and gave out of hours access to the plant, vending machines and canteen checkouts also used the system. It also controlled access to restricted areas. Lost cards could be easily deleted and new ones created very quickly. One hotel I have used controls lift access from the lobby with your room card but once you have been admitted lift access is not controlled so if you lock your card in your room you can return to reception.
Thread: Tracy Tools Delivery
19/02/2022 17:16:39
Our postie Tracey was out yesterday morning, the storm had yet to reach maximum power but still decidedly breezy.
Thread: Spectacles
18/02/2022 22:13:14
Some of these magnifying units make you look as though you have been assimilated into the Borg collective.
Thread: Acoustic Damping/Attenuation
15/02/2022 10:53:44
Cars are fitted with self adhesive pads of a rubbery/ pitch like material to stop the sheet steel from drumming. It must be effective or they wouldn’t spend money fitting them but the size shape and location will have been tested for effective control. I suppose there are two approaches, solve the source of the trouble or control the effect.
Thread: What is this?
11/02/2022 21:04:00
A quick Google shows many pictures of exactly that design so it must play some part in uniform maintenance.
Thread: I am getting shorter - how about you.
10/02/2022 15:04:19
My hair has migrated from my head to my ears and eyebrows, not too worried about losing my hair but appearing at new sites I could do without.
Thread: Tee slot clamps similar to mole grips
10/02/2022 14:41:27
Toggle clamps are a useful item, really intended for production type jigs rather than general purpose clamping but they come in a wide variety of configurations and can make a quick job of a special setup if you ever get involved in making a big batch of something.
Thread: What happened to factory rejects?
09/02/2022 23:37:39
I had an interesting conversation with a chap who ran a machine shop and had a contract to machine exhaust manifold castings for a well known premium brand car. He lost the contract to a Chinese machine shop, the price they charged was hugely attractive but the reject rate was also huge but was still worth it to the end user who had to inspect every component.
09/02/2022 16:35:45
Drill table clamp
Axminster do these but really meant for drill table slots with access below the table.
Drill clamp machine mart
Alan has pointed out below that the same clamp is available from Machine Mart, if these are what you are looking for machine mart are rather cheaper and look identical, top tip from Alan.
Edited By Mike Poole on 09/02/2022 16:55:25
09/02/2022 11:08:26
Posted by Hopper on 09/02/2022 09:36:55:
The soles of your feet wear down from all that walking at one end. The top of your head wears down from all that head-scratching at the other. In the middle, plastic deformation causes length to shorten as width increases as we get squashed down by the pressures of life.
Do you get taller in Australia as you are upside down all the time? My uncle moved to Australia as a young man and many years later returned to the UK for a visit, he was by now sporting a bald head and one comedian in the pub said I know Australia is upside down but didn’t realise you walked round on your heads.smiley
Thread: Hermes and couriers
09/02/2022 10:56:09
Communications from the council are accompanied by a leaflet with a translation into numerous languages, I wonder why they go to such trouble and expense when I feel the onus should be on the recipient to translate if they do not understand it. Since my son moved to Wales I have become a more regular visitor and find the dual language road signs take longer to assimilate than if they were just in Welsh, I drive in many European countries and do not have a problem as I have learned what most of them mean over the years so adding Welsh should not be too much of a challenge. I was talking to a Welsh friend a few days ago and he said the Welsh language was forbidden in school when his father was a child and any child using Welsh would be ridiculed. He said there is a whole generation who were more or less forbidden to use the Welsh language. It would seem that their culture was rescued just in time.
08/02/2022 21:03:41
You may be at your tallest when you get up in the morning, good time to weigh yourself too.
08/02/2022 19:17:27
I may be getting shorter but my waist is getting bigger, anyone worried about losing height should get their platform shoes out from the 70s.
08/02/2022 19:12:36
Our local Hermes man was born and bred in the village, he is helpful and available for queries but of course he can only be responsible once it has reached him.
Thread: Read the T-shirt
08/02/2022 09:31:31
My favourite T shirt was my 1985 Team Bike Bol d’or shirt it eventually succumbed to holes and stains.
Thread: New highway code rule.
07/02/2022 19:19:20
The Terminator will come back to save us.
Thread: Running a Myford S7 in Reverse
07/02/2022 19:05:38
I know it feels safer to cut away from the chuck but it is probably worth practicing disengaging the half nuts which can be done very precisely with a bit of practice, as you have a super 7 you have a clutch to stop the spindle and as screw cutting is usually done at slow spindle speed to give you a decent reaction time it is not as hard as you think to stop the spindle as well if cutting metric threads. I think someone has linked to the Oxtool demo on YouTube of how the threading indicator can be useful even when cutting metric threads.
Oxtool video
Edited By Mike Poole on 07/02/2022 19:17:07
Thread: vertical slide mod
06/02/2022 22:15:52
I imagine that Myford re-engineered the clamping to the two bolt style because the one bolt method had proved to be unsatisfactory on occasion. I think it is probably possible to replace the one bolt clamp with the two bolt version.
