Here is a list of all the postings Trevor Drabble has made in our forums. Click on a thread name to jump to the thread.
Thread: Sources of decent quality ER25 Imperial Collets |
03/05/2023 11:22:58 |
Have re-checked Weston's page on their UP collets , and it should read 0.005mm . Apologies gents for my typographical error. Trevor. |
03/05/2023 10:30:03 |
Neil , I merely repeated the company's claims . Suggest any queries or comments you may have should therefore be directed to them . It would be interesting to hear the outcome of such a discussion. Trevor. |
02/05/2023 21:34:04 |
Weston Tooling supply good quality ER25 collets via their UP range with a stated run out of 0.0005mm , but only in metric I believe. |
Thread: Reversing switch |
02/05/2023 17:28:35 |
Steve , FYI. Following on from Robert's excellent suggestion , thin plastic sheet is available from model shops such as Leeds Model Shop and Nitro Models in Rotherham. In fact just bought an A4 sheet of 0.020" material from NM for only £2.00. No connection with either supplier. Hope you find this of interest. |
Thread: 13A plus USB adapter : not recommended |
30/04/2023 11:11:41 |
Michael , Would you happen to know if BS5733 describes any dimensional requirements please ? Trevor . |
Thread: Remotely oiling a workshop of line shaft machinery |
19/04/2023 10:55:43 |
Maybe worth approaching various suppliers concerned or the museums trust ( or whatever it's called these days ) , or the local council ( providing some child education can be proven ) for some degree of sponsorship ? |
19/04/2023 09:04:50 |
The Grease -O-Matics are available with different feed rates . Am sure consultation with the company coupled with variable and logged initial manual monitoring would result in an eminently suitable solution in all facets. |
18/04/2023 13:06:13 |
Further food for thought . I eventually replaced the large (leaking ) brass Hunts bearings with Cooper bearings ( they were in Kings Lynn I think ). Basically rather than the shaft having to be machined , they have a split precision machined collar which bolts onto the shaft on which the roller bearings bare between it and the housing . Reliable , long trouble free life , better speed tolerance ( so as to allow easy use of VFD's ) and no hazardous oil deposits on the dark plant room floor. |
18/04/2023 12:18:48 |
Search Grease-O- Matic . They were available with different grease types and oils . We used the oil types on the Hunts bearings on our slow revving extract plants and the grease types on the supply plants as well as laundry equipment . Highly cost effective . We ordered ours from a bearing supplier ( Wyko or City Seals I think ) . |
Thread: Infrastructure Engineering |
09/04/2023 12:43:55 |
The surface car park at New Miller Dam in Wakefield is , or at least was , marked 30 cwt maximum safe vehicle weight. My large old 7 seater Citroen DS estate weighed 33cwt. |
Thread: Belt Grinder Upgrades- Rubber Sheathing? |
27/03/2023 22:50:31 |
There are a number of suppliers that advertise in Old Glory / Vintage Spirit who apply a rubber coating to traction wheels of all sizes . Also PAR in Lancashire may be able to help . Maybe avenues worth exploring ? Edited By Trevor Drabble on 27/03/2023 22:57:44 |
Thread: Simple case hardening recipe |
27/03/2023 22:45:46 |
Blackgates also sell case hardening powder . They had it on the stand at Harrogate . Think it was around £17 / tub. |
Thread: A tool for sharpening milling bits. |
27/03/2023 14:12:29 |
+1 for Abbco. |
Thread: Fastener Storage |
11/03/2023 23:29:42 |
Vic , I've got a load of Old Hoborn ( or similar ) backy tins you can have at reasonable cost . Can supply a pic if interested and if so , which part of country are in so as to avoid postal costs please ? Trevor. |
Thread: Harrogate show |
10/03/2023 09:15:09 |
I spoke with a member of the Showground at 8.30 this morning and she told me that the roads around Showground are clear and the internal roads have been snow ploughed and gritted and that the show is still on . Edited By Trevor Drabble on 10/03/2023 09:16:14 |
Thread: Trefolex |
09/03/2023 17:34:36 |
Bob , Blackgates sell ( sold ) it . I think it was something over £15 for a tub in 2021 . Assume they are Harrogate from tomorrow and there may be show offers on ? Also suggest Polly Engineering. Trevor Edited By Trevor Drabble on 09/03/2023 17:39:49 |
Thread: Disassembling a Pratt 10 inch 3 jaw |
08/03/2023 14:38:45 |
Nick , Suggest you consider consulting such sources as Pratt Burnard 600 or Rotagrip or Colchester Machine Tools.
Thread: Myford VM-F Mill |
07/03/2023 16:45:33 |
Alan , Have you tried Googling "Manuals Online " ? Trevor. |
Thread: Bronze - Unsolderable |
24/02/2023 12:52:09 |
If , as Phil suggests it is aluminium bronze , then you may find adding 20% - 25% household salt to your existing flux will help inhibit the aluminium oxides from forming . Trevor. |
Thread: Nut sizes imperial measurements, disorientation! |
24/02/2023 12:43:21 |
Edward , Why not check with your preferred fittings supplier that their tee pieces and elbows are fully compatible ? Initially fit an elbow , and then simply exchange it for a tee piece as and when required . Trevor |
