Here is a list of all the postings Chris Gunn has made in our forums. Click on a thread name to jump to the thread.
Thread: machining pulleys for vee belts |
04/04/2013 09:58:47 |
We used to make a simple form tool to finish vee pulleys, just a piece of gauge plate, grind it to match an existing pulley groove, relieve the cutting edges, and harden. take the big volume of metal out with your parting tool, plus a little at each side, then use the form tool to finish, no messing about, and all grooves will be the same, which is important. Chris Gunn |
Thread: Chuck Jaws |
25/03/2013 20:52:00 |
Soft jaws are a real benefit, once you have a set you will not want to be without them. My tip is to recycle them when you have machined them down a fair bit. When they have about 1/2" thickness left, machine them flat, and then carefully mark out and drill and tap a couple of holes in the centre of the jaws. Then make up some mild steel blocks to match the section of the jaws, and drill and counterbore holes to match those in the jaws, make the clearance holes as small as possible. The counterbore needs to be as deep as possible, then secure the blocks to the jaws with cap head screws, and you have some new jaws, almost free. I drilled mine carefully using a DRO to position them, and I made many sets while I was at it. I have been using the same base jaws for about 30 years, changing the blocks when needed. I have to make a new batch of blocks soon, but the scroll teeth on the base seem as good as ever. Chris Gunn |
Thread: Molesworth''s HandBook |
02/03/2013 15:18:15 |
Falco, thanks for those links, started downloading to my Kindle already, isnt technology wonderful!! Chris Gunn |
Thread: Cutting fluids |
02/03/2013 15:04:37 |
Paul just be careful with some of the alternatives to proprietary cutting fluids and lubricants, lard and rapeseed oil and the like will go rancid in the chip tray, probably a lot quicker in Oz than they do here. Chris Gunn |
Thread: Cross feed problem |
25/02/2013 18:19:00 |
The Super 7 leadscrew nut is awhite metal casting, and could easily pick up swarf. If is is worn and the screw is OK, you can replace just the nut. CG |
Thread: Grit blasting |
07/02/2013 16:06:45 |
I would reiterate what has been said above, you need a lot of air to grit blast continuously, we needed a big screw compressor to run our sand blaster, and we needed dust extraction to keep the dust out of the workshop, and still it was messy, it would be even worse in a home workshop. I think Chris J was trying to say if it costs £40 to sand blast a mower, why go to all to bother to get the sprayer, media etc, plus the cost of running your compressor non stop, (is the Jun air continously rated, by the way?), when £40 could get the job done, dust and hassle free. On the same tack, I have just had 2 front and 2 rear traction engine wheels in 6" scale sandblasted for £50 cash. Chris G |
Thread: Turning Phosphor Bronze |
05/02/2013 20:07:43 |
Wolfie, my tip concerns drilling, try and drill the hole you need in one pass, do not try and put a small drill through, and then follow up with a bigger one, as the bigger drill will dive in, and jam up. If you can use an offset point drill as suggested, do so. If the job has a stepped bore, drill the big hole first, then drill the small one second, if the job allows. If you are drilling the job in a bench press later, clamp it in the vice, and clamp the vice, and be careful the drill does not snatch. Use new drills if you can, if you have a miller, drill the hole in that, and use the table raising screw to put the cut on, not the drill press lever feed which you can lock up. Sharp tools are a must. Chris Gunn
Thread: 4mm square (mild) steel tubi |
27/01/2013 20:40:42 |
Metalsmith can offer 4mm square brass tube, could you use this, once painted, no one will know. Chris Gunn |
Thread: Student Mk1 motor |
08/05/2012 17:08:31 |
If you have got one, why not use it. Not sure what the starting current would be, maybe you should check this, as far as starting in higher speeds is concerned, if it is cold, my Bantam takes time to get to high speeds, as the oil is cold, when running from the converter. Once it has warmed up, no problem at all. If I go out and it is very cold, I run it for a few minutes at low speed until the oil has warmed up, then switch to the high speed. Chris Gunn |
08/05/2012 15:41:25 |
I was faced with a similar decision when the 3ph motor blew on my Bantam. I had run this for years with a single to 3ph converter made by Transwave. I looked at putting a new motor on it, so I could use an Inverter with variable speed and so on. If I went in that direction, I would need to do something to run the 3 ph coolant motor, as I use this a lot. When I costed it, just for the main motor, the new motor plus new inverter, plus controls, all from suppliers who advertise complete solutions, it was not cheap, and still did not give me anything for the coolant motor. In the end I got the old motor rewound, and continued with the 3ph converter, which enabled me to run the coolant pump as well, for a quarter of the cost of the new stuff. I know I do not have variable speed drive, but I can still use the gearbox, all carefully selected by the original designers, and I can use the coolant. If you have no motor to rewind and no converter either, the economics will be different for you. Inverters are not the only solution. Chris Gunn |
Thread: Lard Oil or it's modern day equvalent? |
13/04/2012 11:11:17 |
I know it is a little off topic, but the mention of whale oil reminded me that the company I used to work for, way back, designed and built machines for scraping the last scrap of whale oil out of the wooden barrels it was shipped in. When we had a clear out in the drawing office, I kept the general arrangement drawing of this machine, beautifully drawn in ink on silk. I thought it might come in handy one day. Chris Gunn |
Thread: Getting a boiler tested |
13/04/2012 11:02:18 |
If you are in Northants or Bedfordshire, or willing to travel to Rushden for testing, you could contact the Rushden Miniature Steam enthusiasts society, who exist mainly for boiler testing road locomotives, although the boiler testing weekends are over for this year. The club does have a social side as well, and members are happy to assist and advise, but was originaly formed so a group could get their boilers tested. The membership fee is much lower than a commercial inspector would charge. Anyone wanting contact detail please PM me. Chris Gunn Edited By Chris Gunn on 13/04/2012 11:04:39 |
Thread: think tank |
27/01/2012 16:38:59 |
I think the forum is a wonderful place for getting assistance, it does not seem to matter what the question is, someone has the answer. Perhaps we should remember that not everyone wants or has access to it, for whatever reason. These folk are denied the collective wisdom of the forum. Perhaps if the best idea of the month were published in the magazine, together with an invitation to ask questions, then in the fullness of time any existing answers from the forum could be published or answers invited from the forum, and then published. In the ME for example, the letters page is now exactly that, just a page, rather than several, so this may be a good substitute and take up the "spare" pages. It could also encourage folk to join the forum and add their wisdom to the pool.
Chris Gunn
Thread: Storage of taps, dies, slot drills and end mills |
26/01/2012 19:52:05 |
I made some wooden blocks just like those shown above, which I shuffled around on a shelf for ages. My blocks hold a range of taps, eg BSF, together with the right tapping drill. It is easy to grab the right tap together with the right drill, with no rootling around. When I needed a particular tap, it was always in the last block I found. Then I made a wooden ply turntable supported off the wall, and located by the drill, and attached the blocks to the turntable together with drill stands with number, letter, imperial and metric drill stands. Now whatever I need is a short spin of the turntable away. It is amazing how much valuable time this simple device has saved, and it took an hour or two to make. I am just sorry I did not think of it 40 years ago.
Chris Gunn
PS I also did a similar thing with my morse taper drills, using an old pulley as a base, a wooden turntable about 9" diameter, and all the drills arranged in a spiral. |
Thread: Facing a casting in the lathe |
24/01/2012 17:39:54 |
Jason you are right about the top rake of course. However I do think the shape of the tools shown in the picture in the Boxford manual is confusing in the context of the original question asked.
Chris Gunn |
24/01/2012 09:53:02 |
The guys at Boxford obviously never wanted to turn up close to a shoulder or into a corner going towards the chuck with the tools they show in the illustration, or is this just artistic licence? I would describe what Boxford calls a LH tool as a RH tool being used in the wrong direction, and vice versa. The "LH" tool would go into a corner or close to a chuck, and could be used to face off as well.
Chris Gunn |
23/01/2012 19:57:46 |
I have a rear toolpost, and use it for a parting tool which is always there ready to go, but really the most useful accessory IMO is a quick change tool post, and 5 or 6 tool holders, then you can have the 3 or 4 tools you need all the time permanently set up and at the right height, and a couple of spare holders for the tools you use occasionally, which you can change over as required. if you do this, you can get a lot more done.
Chris Gunn |
23/01/2012 11:27:57 |
When I was an apprentice, i was taught to use a tool with a 45 degree chamfer on it to face across a workpiece, and then one could use the same tool to put a chamfer on the machined face to break the edge. I still do this today but with a throwaway tip tool which gives me 4 edges. To turn down the diameter, we always used a right hand tool with a tip with a small radius. Nowdays I use a throwaway triangular tipped tool, giving 3 edges. I have a round nosed tipped tool for occasions where a nice big radius is required in the corner, in either direction, but this will chatter a bit if too big a cut is put on, and when getting into the corner when it is cutting on 90 degrees of the tip. The previously mentioned tools will not chatter with the same cut, this is no doubt due to the longer cut length. These 3 tools will do 95% of what I need.
Chris Gunn |
Thread: Storage of machine tools |
01/01/2012 18:54:00 |
Clive, I used to use Shell Ensis coatings to protect new machinery and parts, they have several varieties that will protect your machines for up to 3 years. Just paint it on the machined parts, and wash it off with a solvent after you get back. Google Shell Ensis, and you will see their data.
Chris Gunn |
Thread: Turning very thin bar |
31/12/2011 11:33:25 |
The other tool we used to use to turn long thin diameters is a roller box, it is a similiar principle as the tools described above, but uses 2 small rollers to support the work, and a tool to do the cutting, all set at 120 degrees apart, and all on adjustable slides. I used these on capstan lathes in the turret, but they could be used in a tailstock. there is no need to make any bushes with this tool, as every element is adjustable. you often see these on secondhand tool stalls, for a couple of quid, and all you need is to adapt the shank to suit your tailstock.
Chris Gunn |
