John Hinkley | 27/01/2013 19:52:08 |
![]() 1545 forum posts 484 photos | I am thinking of making a 1/6th scale racing car - possibly a Lotus 23 or something of similar vintage - and would need to source a fair amount of 4mm square tubing to make the spaceframe chassis to scale. Extensive Internet research (i.e. Ask Jeeves) seems to suggest it's rarer than rocking horse manure. Unless anyone knows any different? Or, maybe you could suggest a suitable alternative, bearing in mind it will have to be brazed or welded? John
JasonB | 27/01/2013 20:28:28 |
![]() 25215 forum posts 3105 photos 1 articles | Would anyone know if you used soild?
J |
Chris Gunn | 27/01/2013 20:40:42 |
459 forum posts 28 photos | Metalsmith can offer 4mm square brass tube, could you use this, once painted, no one will know. Chris Gunn |
JasonB | 27/01/2013 20:57:32 |
![]() 25215 forum posts 3105 photos 1 articles | K&S also do a 5/32 brass tube which is near as dam it 4mm |
Clive Hartland | 27/01/2013 21:20:10 |
![]() 2929 forum posts 41 photos | Having seen some of these scale models I believe they are made from a white plastic materiel which comes in tubes and squares and sheet and is very easily formed. I have also seen scale airplanes made this way very realisticly with very fine detail. Clive |
John Hinkley | 27/01/2013 21:24:22 |
![]() 1545 forum posts 484 photos | Thanks all, I knew you'd come up trumps! I think brass is probably the way to go, with the plastic in second place. I'll start making some enquiries next week. Thanks, again, John
Brian Wood | 28/01/2013 12:35:06 |
2742 forum posts 39 photos | Hello John, I don't know where you live, but the Art Shop in Darlington has a display rack of just what you're looking for Brian |
Chris Trice | 28/01/2013 12:38:27 |
![]() 1376 forum posts 10 photos | Go with brass. You can solder it. K&S or Albion Metals (same stuff, slightly cheaper) is easy to source. |
John Hinkley | 28/01/2013 13:23:54 |
![]() 1545 forum posts 484 photos | Brian, I'm in Lower Normandy, France, so it's a bit of a trek to Darlington, though I do get most of my metal from M-Machine there - by post to relatives in the UK, then pick it up next time I'm visiting. Tends to make for long lead-times on projects and advanced planning is required. Chris, I had a Google and K & S seem to be in Illinois, USA! One of my daughters flies for Virgin Atlantic, so, maybe next time she goes to Chicago .........? I did think brass would be best, but I think I might investigate the plastic route a bit more, before I decide. I think I've seen it in a local toy shop. John Edit - searched for Albion (Alloys) and they are in Bournemouth - very handy for daughter #1 !!! So I assume the Illinois K&S is not the one you're referring to, Chris.
Edited By John Hinkley on 28/01/2013 13:34:18 |
JasonB | 28/01/2013 13:35:11 |
![]() 25215 forum posts 3105 photos 1 articles | K&S is sold in may hobby shops such as RC and train outlets and I'm sure you could get it mailorder. The plastic is called "plastistruct" |
Chris Trice | 28/01/2013 15:58:28 |
![]() 1376 forum posts 10 photos | John, where the stuff is made and who sells it are two very different things. Sony make their TV's in Taiwan. You'll find K&S or Albion Alloys in any number of model shops. The plastic sections Jason refers to is actually called Plastruct but there's an even bigger range of sections made by Evergreen, also made in the USA but found in all decent model shops. You could try Avicraft Ltd for the K&S brass and for Evergreen styrene sections, Kit Form Services TJD models stock both. There are also a number of specialist suppliers to the model train enthusiast of very fine fully milled brass sections both decorative and architectural. |
