Here is a list of all the postings ega has made in our forums. Click on a thread name to jump to the thread.
Thread: Painting aluminium |
05/10/2013 16:38:12 |
I used Hammerite Special Metals Primer available from Halfords and no doubt elsewhere on the aluminium castings of my Speedy recumbent trike. You can overpaint with "most paints" and clean brushes with water. My topcoat is still there. |
Thread: collet chuck |
04/10/2013 11:31:35 |
Andrew Johnston: garrygun said "affordable". I imagine you know more about this than I do so what would you suggest? Incidentally, in my post what was intended to be a right bracket has come out as an emoticon. |
04/10/2013 10:33:44 |
My vintage Willson slantbed came with a Burnerd Multisize collet chuck and collets designated MC3 -13 (1.125" - 1.5" Depending upon what is meant by "affordable", I would consider a taper-mounted ER40 chuck and collets (range 3-26mm). |
Thread: Modern taps....... |
01/10/2013 09:31:52 |
Ian S C: Sorry if I wasn't clear - I did find your table in your photo album. I see you have now been able to transfer the photo to this thread, something I have yet to attempt. I did, however, produce a thread in softish aluminium without difficulty. As it happens, my Roltap brand tool turned out to be marked with a tap drill size - 7.4mm - and I actually used 7.35 which was my nearest drill and fell neatly between the high and low range figures. Under a lens the thread appeared to be not quite fully formed. Harold Hall makes some interesting comments including that a good quality lubricant, not a cutting oil, must be used; my favourite Rocol RTD claims to be suitable for "forming operations" |
30/09/2013 14:28:54 |
PS I realize I have committed the all-too-common sin of asking for information which I should perhaps have first looked up myself. The up side is that the many see potentially useful material rather than just the one. I looked out my single 5/16" 24 UNF thread-forming tap and ran all three methods of determining the correct tap drill size with results varying between 7.3mm and 7.4mm. This might seem quite a large range but there is the variable of thread depth to consider; I used 75% for the Guhring calculator. I also checked three other possible hardcopy sources: Machinery's Handbook 1943 - apparently unknown then Newnes Mechanical Engineer's Pocket Book 1997 - not mentioned Tubal Cain's Handbook - not mentioned so far as I could see but he was very keen on the correct size for conventional taps Harold Hall's Data Book (WPS 42) - he calls them fluteless and gives 7.3mm Now off to the workshop to form a thread with the thought in mind that these taps presumably require a relatively large degree of axial pressure. |
30/09/2013 12:32:19 |
Many thanks to Versaboss, Andrew Johnston and Ian S C for their information. |
29/09/2013 12:43:27 |
Prompted by the original post I searched the forum for "TiN coating" and was surprised to get no results. What do the knowledgeable say about this modern fashion? Andrew Johnston: I have one of these thread-forming taps and read your comments with interest; does any one publish tables of recommended tapping sizes for these or do you just go on progressively reducing the hole size until a full form thread is achieved (and then stop!)? |
Thread: Case hardening |
22/09/2013 09:47:50 |
Stub Mandrel: Thank you - that seems very clear. The tip of a push rod would seem to be an ideal application but when a larger surface is involved only the last part treated seems likely to be hot enough to gain from the quenching. I shall therefore re-heat all over before quenching in future. |
21/09/2013 23:48:00 |
colin hawes Thanks for the further information. |
21/09/2013 09:45:48 |
colin hawes: Thanks for your post. What intrigued me about this method was that I had always understood that case hardening was a two-stage process - first introduce the carbon under heat then quench to complete. I seemed to get some kind of effect without quenching. Tubal Cain (WPS1) is very good on this subject and makes a good argument for choosing case hardening mild steel over through hardening silver steel, etc. |
20/09/2013 17:15:23 |
Russell Eberhardt: I agree that hard on hard seems wrong and, in any event, suspect you know more about this than I. However, one authority (the late Cliff Bower) said "clamping screws for tool-posts should always be made of high-tensile and case hardened material and the lower ends bevelled neatly". He went on to suggest drilling the ends and inserting a standard (presumably, hardened) steel ball-bearing making the interesting point that screws treated in this way do not tend to shift the toolshank when tightened. I personally use standard HT capscrews treated as you suggest and try to avoid overtightening. |
20/09/2013 14:11:22 |
My Oxford arc welder has a 12V tapping which can be used with a carbon rod in the electrode holder to heat and solder, etc. The brief instructions also claim that the carbon can be used to harden steel. I had never tried this until very recently when I found that it seemed to work after a fashion. Has anyone any experience of this method or helpful comment to make? |
Thread: Parting off problems |
19/09/2013 11:54:59 |
Someone experiencing parting off problems would do well to start by reading the relevant passage in George H Thomas's book. My own experience improved radically when I built his rear toolpost some years ago. More recently, I invested in a Greenwood KIT-Q-CUT and had very good results using it in a custom turret on the GHT toolpost on a Super Seven. The Greenwood tool is based on a Sandvik p/o blade and insert and appears to be half a standard double-ended blade fastened by two countersunk screws to a rectangular block intended to be gripped in a clamp type toolpost. This design works but is not as robust as the standard Sandvik arrangement, the shear strength of the screws being the limiting factor. At some stage I added a third screw and later still three dowels. The beefed up tool also worked very well in the standard toolpost on my larger lathe until I had a major seizure and succeeded in breaking both tip and blade (I will aim to post a photo of the result). This happened shortly after I had bought two replacement tips including one of the new ones with an angle to reduce the pip. When I learned that the standard, double-ended Sandvik blade, costs about £70, I decided to try the Front or Rear tool advertised on this site and find it excellent. If anyone wants to take the two Sandvik inserts off my hands at cost less 10% they are welcome to message me. There are cheaper versions eg the Glanze but this is not as effective as the Sandvik in my experience. Happy parting! |
Thread: setting 8 degree taper for ER collet holder |
14/09/2013 23:36:24 |
I have now posted photos of the components of my gauge and of its use for setting the Myford topslide. By way of additional explanation, "R" on the gauge label is the distance between centres of the two 12mm dia columns; these project below the base plate sufficiently to engage the c 8mm dia rod when it is located in the dovetail of the topslide (it is, of course, necessary to remove the top of the slide to make the setting). "N" is the wall thickness of the setting ring derived by trig as indicated on the label. The gauge is held on the topslide base by the clamp on the other side from the rod. Removing and replacing the top of the slide is made easier if one has dowelled the gib as recommended by GHT. I believe that late model Myfords have a flat-topped slide and it may then be possible to operate the gauge from the flat top provided that the geometry is correct; it is necessary to align the gauge with the slide travel. In the photo the setting is being made to a test bar held in the tailstock. The bar could perhaps better be placed in the spindle taper. For convenience, Peter Smith's original suggestion was to align the gauge to the extended tailstock barrel but on the Myford this would mean a limited "R" distance. The 8 deg setting ring is shown supported by friction only but in practice it may be more convenient to provide packing so that it sits at the appropriate height and to verify the setting position by trapping slips of cigarette paper between gauge and test bar. I hope this is clear and that it helps someone other than me - if so, give thanks to Peter Smith. |
10/09/2013 14:31:40 |
Some further interesting postings. Douglas Johnston: so far as I can see I can only upload JPGs to an album. For the moment, therefore, I have uploaded only the JPGs in Smith's description. Beyond these, as well as explanatory text, there are a number of GIFs; I will give some thought as to how to make these available and also photograph my own version and post in due course. |
09/09/2013 18:16:35 |
If the aim is 8 deg, as opposed to matching an existing taper, then P J Smith's Taper Turning Gauge is well worth considering. It works on the sine bar principle, is straightforward to make and has the great practical advantage of positively aligning the topslide before it is tightened. Unfortunately, the web page describing his device seems now to be "unavailable" but I have the relevant files on disk and no doubt there is some way they could be posted to this site together with a photo of my own version if these are of interest. The gauge works equally well for larger and smaller angles so would come in for morse tapers and 40 deg included angle collets as well as the ER variety. Finally, it provides an opportunity to brush up one's trig! I note from one of the helpful threads here on ER collets that John Stevenson found it necessary to correct the nose of his collet holder by grinding it in situ and would be interested to know if he has written up the process anywhere. I imagine that most of those who make their own holders turn the taper but, of course, the commercial item is ground (and, presumably, hardened). |
Thread: Bench grinder flanges - to fix or not to fix? |
30/03/2011 12:53:23 |
Dusty - thanks for your input. I suspect that the bench grinder is something that, like the Champion spark plug, we "fit and forget". It just so happens that, since I posted, one of my grinders developed a loose RH nut, something that I have never had before.
I admit I had hoped some knowledgeable type would have answered my main question ie why is the inner flange not now secured against rotation?
Thread: Craftsmanship |
11/03/2011 17:10:03 |
Niloch - thank you for pointing me to a memorable experience. I imagine most members of this forum would be struck by the absence of machine work; Ironbrush says he rejects machines as being too quick. I did, however, notice what looked like a motorised fret saw in one shot and, of course, he is understandably using optical and computer technology, which was possibly not available to the original artist. These wonderful videos say a good deal about Japan.
The saucepan technique reminded me of how lead shot are made.
Two questions (which may be answered by his other videos): was periodic annealing required and how does he sharpen those chisels?
Thread: Heavy Metal |
10/03/2011 19:06:51 |
Am I right in thinking that darts sometimes have tungsten alloy shafts about that size?
We badly need a new KRW!
Thread: Metric screw cutting |
06/03/2011 17:59:55 |
Ruaidhri
3.5mm pitch is included in Myford's table of pitches available with the metric conversion and in fact the table goes up to 4mm. It's true that they counsel caution when cutting coarse pitches but there is nothing inherently dangerous in gearing up. As always, a correctly-shaped, sharp tool makes all the difference. You could always leave the drive belt on the slack side if you are concerned about breaking something. I would be inclined to avoid using back gear if possible because of the large amount of torque available in this mode.
BTW, I'm a woodturner from way back, too.
