Member postings for dcosta
Here is a list of all the postings dcosta has made in our forums. Click on a thread name to jump to the thread.
Thread: Colin Usher's Index is back up to date
18/10/2014 10:34:26
Hello All,
Neil: Thank you for making the file available. It also worked for me, directly.
All: I've just made available the MEW_Indexes with the new file made available by Neil covering to the 222 issue. You cand download it from ***LINK***.
If you want download the ME_Indexes or EiM_Indexes you can do it ***HERE***.
Michael Gilligan: My application doesn't have the 'Bells & Whistles" you don't like in Access and goes directly to the "subject".
Best regards
Dias Costa
Thread: Making use of old Lithium batteries
15/09/2014 18:32:28
Hello all,
You can see ***HERE*** some consequences of a Lithium Ion battery explosion in my garage/workshop.
Dias Costa
Thread: Suggestions/ideas for projects
09/09/2014 22:20:46
Hello John,
John: Interesting solution, but it looks like the bamboo curtain doesn't roll up out of the way, does it?
DC: Yes it does. Both extremes (uppermost and lowermost) are attached to the same screw holes where the original bellows was. So the bamboo curtain works in the same manner as the original bellows.
Dias Costa
09/09/2014 20:44:03
Hello John, good evening.
See **LINK** , please.
Dias Costa
Thread: Indexes or Indices ?
09/09/2014 19:20:07
Hello Neil, John, Vic, All
Finally the application EiM_Indexes is working as expected.
I am especially grateful to Mr Neil Wyatt with whom I exchanged correspondence and helped me find the cause of the error.
Anyone interested can find the MEW_Indexes, ME_INdexes EiM_Indexes applications and the usual address:
Best regards
Dias Costa
03/09/2014 22:59:02
Hello Neil, John, Others, good evening.
Now I found the cause of the problem ant it's corrected now. I hard coded an address in a disc as the place for a database file. Now that address it's dynamic.
Please try again and let me know the result.
Thanks in advance
Dias Costa
03/09/2014 20:52:32
Hello John, Neil, Vic.
Thank you for your intereste in the application and help.
Neil, John:
can you, please, let me know if you installed all the files of the EiM_Indexes application in a directory/folder for itself alone before testing?
Thanks in adavance
Dias Costa
03/09/2014 16:59:47
Hello John and Neil.
Neil: it's hard to track down a fault you can't see.
DC: Yes you are right. And a long time passed since I made the programm.
Haved you by any chance made some change on the data in the form "Cross issue by date (Maintenance)" or used the option "Import from an Excel file"?
Couldn't find, yet, the cause of the problem.
Meanwhile I've put in my site a EiM_Index ziped file with new data base file.
Please download it, try it, and let me know what happens.
Thanks in advance
Dias Costa
21/08/2014 17:25:36
I have made ​​small attempts to find the cause of the problem but have not had success so far.
There is, however, one thing that I remembered: during the construction of the program, in testing, that message was presented to me a few times and at that time I found that the problem was a result of the data structure used which is more complex than those used by MEW_Index and also by ME_Index.
I hope to during the next week-end to solve the problem and release a new version of the program.
Almost forgot to say that here, at home, the program works without sending the message.
Thanks for your patience.
Dias Costa
18/08/2014 19:47:53
Hello John and Neil. Good afternoon.
Thank you for your help. Your information is importante for me to search for the cause of the problem.
I'll start working on the EiM_Index program as soon as I can and when I have it fixed I'll let you know in this thread.
Dias Costa
Edited By dcosta on 18/08/2014 19:48:26
17/08/2014 22:12:37
Hello all, good evening.
MEW_Index, ME_Index and EiM_Index
Is there someonelse finding the same problems related above using the Index applications and willing to let me know which one of the three applications doesn't work?
Also, if possible, let me know the steps used to run the application to help me in fiding the origin of the problem.
Thanks in adavance
Dias Costa
17/08/2014 09:39:28
Hello Neil, John. Good morning.
Would you please let me know which one of the three applications doesn't work?
Also, knowing the steps used to run the application would help me in fiding the problem.
Have you put all the downloaded files in a directory/foilder for itself?
I openned all of them and they worked as expetected.
Dias Costa
Thread: Thoughts on "build threads"
31/07/2014 00:32:46
Hello Julian, good evening.
No you are not alone...
I agree with you on all points.
Best regards
Dias Costa
Thread: What did you do today? (2014)
23/07/2014 17:17:40
Hello Raymond,
Very nice work.
Dias Costa
Thread: Optimum BF16 Vario
20/06/2014 23:41:49
Hello Tim.
PM sent.
20/06/2014 17:00:04
Hello Raymond,
please look the page 2 of the Optimum catalog **here** .
You'l find the Optimum products are made in People's Republic of China. With a great difference... I have a BF20 since 2006 and I love it.
regards
Dias Costa
Thread: Toys for Boys
24/04/2014 19:20:37
Hello Muzzer,
Please read also ***here*** about the origin of the Vernier scale. Please search for the word nonius.
Dias Costa
Edited By dcosta on 24/04/2014 19:21:01
Thread: Pottyengineering Cutter Grinder
23/03/2014 09:54:50
Hello Stewart, good morning.
After my Harold Hall's grinding rest suffered deep rust from a fire, I'm interested in to rebuild part of it.
Your draw suggests me a good replacement for the end mill sharpening fixture.
Will you, please, be so kind as to let me use your drawings drawings?
Thanks in advance
Dias Costa
Thread: Outstanding Service
21/03/2014 20:33:55
Hello all,
A few months ago I ordered from the firm Pro Machine Tools a chuck and its backplate to my EMCO Compact 8. Some time have passed and I was informed that the manufacturer of chucks TOS had delayed the deliver and was asked if I would rather get my money back. I said no and would rather wait a few more weeks.
Today I received a Bison chuck replacing the bushing TOS in perfect conditions.
I have no connection to the company other than as a satisfied customer.
Best regards
Dias Costa
Thread: Engine Demonstrator Compressor Project
10/03/2014 22:55:10
Hello Wallace, good evening.
About the Hy-Flow pump...
You could have avoided some work if you had read the message I addressed you on this thread yesterday at 21:08:03.
And I would have been a little happier for someone to recognize my contribution with some information for the matter under discussion.
Best regards
Dias Costa
