Member postings for Russell Eberhardt
Here is a list of all the postings Russell Eberhardt has made in our forums. Click on a thread name to jump to the thread.
Thread: ARC's Adventures in China 2019
29/01/2019 09:27:40
Posted by Ketan Swali on 28/01/2019 12:21:41:
There were four of us being shown around by one of the factory owners, who also happens to be an engineer.
That seems to be the norm in the far east, unlike western factories that are run by accountantssad
Russell
Thread: Original copies of the magazine from 1898 to 1983 for sale
23/01/2019 11:46:56
Posted by JasonB on 23/01/2019 10:58:26:
doe snot come in volumes.
Oh deer smiley
Russell
Thread: ER32 Collet Chuck
20/01/2019 09:38:26
How tight is the tread on the closing nut/body?
It needs some slack otherwise any out of true on the thread can pull the collet out of alignment.
Russell
Thread: Large Wheel Clock
19/01/2019 15:48:01
Yes but for a one off it may be more economical to buy the pinion ready cut from Ian Cobb.
Russell
Thread: Hi from Birmingham
19/01/2019 15:38:51
These people sell Thorntons wheel and pinion cutters **LINK**
http://www.clock-works.clara.net/index.html
Not cheap but probably cheaper than bergeon.
Russell.
19/01/2019 14:45:57
Posted by David Keil 1 on 19/01/2019 11:55:16:Thanks for the information, I think my problem with turning silver steel is due to my lack of ability in ensuring that the tool is sharp enough, I have been using an indexable tool.
Yes, if you are using an indexable insert you will need to use one of the highly polished inserts that are intended for aluminium, they have a sharper cutting edge. The general purpose coated ones have a rounded edge to give them more strength but then need a deep cut to work well. They are also likely to deflect the work somewhat.
Russell
19/01/2019 11:45:34
Posted by David Keil 1 on 19/01/2019 10:18:41:
Hi Russell
Great photo's and very informative. am sure I will be asking several questions smiley.
First one is best way to turn silver steel for the arbors, my attempts so far are a failure!
I can't tell you the best way but what I did was turn them held in an ER collet chuck using a very sharp HSS tool. Then polished starting with oiled 400 grit wet and dry and going through the grades down to 2000 grit. Finally used "Micro-Mesh" with water **LINK**
I cut thin strips of the abrasive sheets and glued them to lollipop sticks to help keep the polishing even. By clockmaking tradition the pivots should be burnished but I found that a good polished surface worked fine.
I don't know if you have a collet chuck for your lathe but you do need to ensure good centering.
Russell
19/01/2019 10:02:02
Hi Dave
Welcome.
I built the John Parslow skeleton clock as my first clock making project. I finished it in 2013 and it has run well ever since although now it has started gaining about two minutes a week so it must be due for a service.
You can see some pictures taken during the construction in my album. If you have any questions just ask.
Russell
Thread: New member with a question
19/01/2019 09:28:34
If you are thinking of buying the Arc SC4 lathe, I would budget for the no. 2 starter set to go with it as a good starting point.
Russell
Thread: Involute, Circular Gear-Cutter on Eccentric Arbor...
16/01/2019 10:09:05
Some time ago the late John Stevenson described an easy method of making single point gear cutters using a tapered cutter to give the required clearance. I can't find the thread at present but it is somewhere on the forum.
Russell
Thread: Use of Colour on Drawings
15/01/2019 16:46:15
For me 1, 2, and 3 in that order. Perhaps I am a bit of a stick in the mud having first been trained in drafting over 50 years ago.
Russell
Thread: Split die cutting undersize
15/01/2019 16:37:19
Posted by JasonB on 14/01/2019 13:16:37:
DIN 225 seems to cover them so see if you can find a copy.
Here is a list of sizes for both metric and imperial threads;
https://www.wegertseder.com/download/techdat/t_6441.pdf
Russell
Thread: Chinese postal charges
12/01/2019 09:57:53
Posted by John Paton 1 on 12/01/2019 07:21:21:
The snag with purchases from China is the cost of returning them if found to be faulty - often many times the original purchase price including postage.
Agreed. I always treat them either as disposable or as a source of materials to make into something useful.
Russell
Thread: More help please
11/01/2019 09:51:50
Posted by Andrew Johnston on 10/01/2019 20:16:33:
Ah, I'd place a small bet it's an RDG cutter?
Most clockmakers stick with Thorntons cutters, expensive but good. I buy mine from Meadows and Passmore and never had a problem. Most clock designs for amateur construction specify cycloidal cutters. You might have difficulty sourcing involute gear cutters in the appropriate MOD.
Russell
Thread: Mill head tramming
06/01/2019 15:10:50
Posted by JasonB on 06/01/2019 14:43:08:
Should not make too much difference, if you do want to play with it then shims under the column base are the way to do it.
Difficult to find shim stock thin enough to correct that sort of error though. His figures seem good enough for me.
Russell
Thread: Lathe identification
04/01/2019 09:17:16
Yes, Atlas 10F. The leadscrew, leadscrew reversing gearbox, and changewheels seem to be missing which will seriously affect the value unless they can be found. I've had one since the 70s. It is like a bigger brother to the Myford 7 series.
Russell
Thread: Leaking camera batteries
30/12/2018 10:28:29
Posted by roy entwistle on 29/12/2018 10:34:33:
I wouldn't advise putting a camera in water of any sort
See Paul's advice above
Roy
I would agree with you for a mechanical (film) camera, however the most common method of cleaning a pcb after soldering is to use water. So digital cameras are fine with water as long as they don't have any power at the time.
Russell
Thread: The Workshop Progress thread 2018
29/12/2018 09:27:36
Posted by JasonB on 28/12/2018 20:43:12:
About 3hrs milling spread over 5-6hrs as I needed a break after each rev and it also let the motor cool.
That would have taken me 5-6 days and then I would have b*****ed it up near the end!
Russell
Thread: Emco Compact 5
29/12/2018 09:15:03
Posted by JasonB on 29/12/2018 07:02:42:
One just come up for sale down the right in classifieds., hope the price is a typo.
That's the solid gold version with the diamond bearings!
Russell
29/12/2018 09:11:32
I wouldn't use tap water on any electronic product. It contains salts that make it conductive. Distilled water is better as it is an insulator. Following the water a rince in alcohol will help to remove the remaining water then leave open for 24 hours before fitting new batteries.
Russell
