Here is a list of all the postings ian j has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford tool post ball handle |
07/12/2016 16:59:38 |
A quick Google search found this description on making ball handles:-
Thread: myford nose thread |
03/12/2016 11:23:03 |
Hi. My third edition,ISBN 978-1-85486-134-4, has sections and no page numbers. The same drawing is on the last page of section 3 ie 3.8. Ian |
Thread: Savage Aggressive big files |
15/11/2016 23:41:01 |
one is fine by me too ian j |
Thread: Toolholders for Myford ML7 and ML10 lathes |
08/11/2016 22:56:11 |
Have you seen this ad on the home workshop site
Thread: 5 HP 3 phase motor |
05/11/2016 15:35:30 |
Just to update you and thank you for all the advice. I removed the rotor, took a rather large hammer to get it out,yes there was rust between the rotor and stator, I cleaned all this off.I tried the idea of connecting a battery charger to the windings but the charger got hotter than rhe windings, maybe I did not leave connected long enough. I found a piece of 6mm ally plate which was just the right width to replace the oven shelf and put the stator in for 6 hours at 50*. After it all cooled down I meggered it. . After replacing the bearings I reassembled it and today connected it up and it runs perfectly. So once again thanks for your help. Ian |
Thread: Tom Senior Light Vertical Milling Machine |
31/10/2016 19:04:33 |
Damian. |
27/10/2016 16:56:11 |
Thanks all for the advice.. I will take it apart , give every thing a good derusting & stick it in front of a fan heater to dry it out. ( I doubt I could lift it high enough to put in the oven
Ian |
27/10/2016 13:16:24 |
A mate has just dropped off a 5 HP 3 phase motor which has sat outside for several months, the gasket under the connection cover is damaged allowing water to enter the motor casing, the motor is seized solid. Before I waste my time stripping it down, what are your opinions on whether it's beyond help. Thank You. Ian |
Thread: The Worden T&C grinder |
17/10/2016 18:15:31 |
When I built my Wardon (now sold) I bored the block over size and fitted PTFE bushes of this type **LINK** On a drill grinding machine I've recently built I used linear motion ball bearing slide bushes of this type :-**LINK** with excellent results.. Ian |
Thread: A decent toolpost |
08/10/2016 21:13:36 |
I think this is the UK company on ebay John is thinking of. used to be AANDRPRECISIONLTD
EBAY seller i/d---------------------------------lynamengineeringltd |
Thread: Decent Brazed Carbide Tools. |
27/09/2016 19:51:41 |
Might be usefull reading this "Grinding carbide health risks"
Thread: Insert identification |
18/09/2016 23:13:33 |
Thanks for that Michael I will have a look there.
18/09/2016 08:45:34 |
Good Morning, Picked up a few bargains yesterday at the Stoke Prior steam rally. A glanze & a Greenwood SRDCN 10x10 profile insert toolholders for £2 each.. Also two boxes of 10 Sandvik inserts for £8 DCMT 070202-UF P45 (M35) DCMT 070204-UM P45 (M35) I understand the style and size part of the code but just asking what material they are designed for turning.. I spent a couple of hours last night trying to understand the information on the Sandvik web site but I'm no wiser. While I'm asking I have a box of PLANSEE DCMT 070204-EN inserts as well.
Thank You |
Thread: What Did You Do Today (2016) |
13/09/2016 07:48:35 |
Last time I went to the shop, about a month ago, there was a sign on the door saying" closed due to illness " |
10/09/2016 08:28:02 |
Your making an excellent job there Damien. Have you managed to remove the chuck yet or are you waiting until it's all reassembled? Ian |
Thread: Tom Senior - E Type - pulley |
28/08/2016 19:03:09 |
I think the E type mill uses the same S type head as on the light vertical mill . I've just had a look at mine & the there is approx 1mm of vertical travel on the pulley. Have you checked there's not a second grub screw under the one you have slackened ? May be when you try to remove the pulley it is catching on a burr made by the grub screw.. You could ask the same question on the "Tom Senior light vertical milling machine " post as Damian has his apart at the moment. . Edited By ian j on 28/08/2016 19:04:59 |
28/08/2016 18:29:32 |
Yes thats the same as mine:- Z axis each increment .001". . 0-130 which takes a bit of getting used to X & Y each increment .05mm Knee each increment .025mm Ian |
Thread: Acceptable wear on leadscrews and nuts. |
26/08/2016 13:15:09 |
Adams oilers here http://www.adamslube.com/Oilers_Main/ Oil guns here http://www.lathespares.co.uk/myford-oil-lubrication?zenid=ormpm5ofgjbp7asd4blf3ujpq7 |
26/08/2016 07:59:30 |
Just out of interest is your machine metric or imperial ? Mine is metric X & Y feed screws but the fine feed on the vertical head is imperial, which seems a little strange ! But as I have fitted a DRO and prefer to work in imperial it's not a problem. |
26/08/2016 07:21:18 |
" but the MT2 seems to be stuck in?" I had the same problem when I first got my machine. One bit of advice I received was to have the fine feed disengaged to prevent damage. I did the same as you & applied WD 40 over night the following morning I was expecting to struggle but a quite heavy belt with the copper end of a small Thor hammer released it. Even now it sometimes requires a heavy belt to release it. |
