Multifix A clamp screws
YouraT24/09/2023 17:51:29
83 forum posts
22 photos
Hi all.
Does anyone know what the clamp screw type on real Multifix size A tool holders is?
As best as I can tell, they are M7x1, can anyone confirm?
Also, if this is the case, where on earth can I but three square headed clamp screws for one...? Even the Swiss seem to be out of stock...
Thanks!
DC31k24/09/2023 18:06:22
1186 forum posts
11 photos
See:
https://pewetools.de/en/shop/product-category/square-head-screw-m7x1x22-for-system-size-a/
Baz24/09/2023 18:07:23
1033 forum posts
The ones on my genuine Multifix are M7x1, don’t know where you buy screws but Tracy Tools will sell you a tap and die if you need one.
YouraT24/09/2023 18:20:39
83 forum posts
22 photos
Posted by DC31k on 24/09/2023 18:06:22:
See:
Oh - thanks - useful!
€9 for three screws - €31 shipping from Germany though <arghhhh>
Nigel Graham 224/09/2023 18:20:56
3293 forum posts
112 photos
The Tracy Tools chart that lives by my PC, tells us M7 X 1 is a standard ISO-Metric Coarse thread.
YouraT24/09/2023 18:25:12
83 forum posts
22 photos
Posted by Nigel Graham 2 on 24/09/2023 18:20:56:
Yes, and that's fine generally - I can buy some hex head or cap head bolts no problem, just wanted the square head on this occasion - I'll perhaps have to make some this time!
Fulmen24/09/2023 18:27:51
120 forum posts
11 photos
My knockoffs are M7x1 as well. I believe it's a "2nd choice" thread, you won't find anything other than 1st choice in normal supply.
Mine are fairly soft, I suspect it's done to prevent people from stripping the threads on the holder. I've worn out several, but they're easy enough to make.
YouraT24/09/2023 18:29:55
83 forum posts
22 photos
Posted by Fulmen on 24/09/2023 18:27:51:
Yes, that makes sense - I think I'll be making some given the shipping cost from PeWe.
Fulmen24/09/2023 18:53:29
120 forum posts
11 photos
Don't forget to turn it down a bit on the end. The screw tip tend to deform when over-tightening, this is probably what causes them to bind and strip in the end.
David Lindquist24/09/2023 19:56:08
28 forum posts
The screws on my "A" series holders from SRW Amestra are M7x1 also. I bought an M7x1 die to make my own screws using 5/16 inch square 12L14 (a leaded steel here in the US). This was made easier by the fact that I already had a 5/16 inch square 5C collet. The 5/16 inch square is very close in size to the heads on the original screws; the Tee-handle wrench fits fine.
Depending on the size of the tool I find the stock screws are sometimes a bit long and like to make shorter ones in these cases.
David
Mark Rand24/09/2023 21:15:12
1505 forum posts
56 photos
Same thread as peugeot 405 brake caliper bleed screws. Don't ask me how I foud out angry.
I have some spares from PeWe because I ordered them when I needed a few new toolholders to replace some of the 1952 originals...
