Here is a list of all the postings File Handle has made in our forums. Click on a thread name to jump to the thread.
Thread: Best "v" thread form |
19/11/2021 08:34:44 |
JA is it as simple as a greater angle means greater thread surface area, therefore greater static friction and greater lock? |
17/11/2021 18:17:35 |
Martin, I think that you have posted this on another thread. it was partly the memory of it that made me think about the initial question in the OP. |
Thread: Cutting up bits of metal |
17/11/2021 15:04:53 |
Thanks Michael. |
Thread: Not the time to be complacent about Covid |
17/11/2021 14:56:42 |
" Only a heartless fool would suggest ,even as I assume made in jest, denying treatment to the unvaccinated as a policy of victim shaming based on the totally false "doctors have refused to treat the fat or smokers"narrative. " Paul not false - if you are overweight doctors do refuse operations.
16/11/2021 13:54:06 |
Thanks Dave, that does all make sense and answers my,possibly, simple question. |
16/11/2021 08:27:59 |
Michael, I like your idea of using a wiper motor to drive a 12" hacksaw. Have you a photo of your setup. |
Thread: china/India - Cop 26 |
16/11/2021 08:22:52 |
Anthony, the green hydrogen is made by the electrolysis of water, so burning it just recreates water. thus will have zero greenhouse effect. It has the potential to store excess renewable electrical energy for later use. It also makes use of the existing gas pipelines. The downside is that the electrolysis does need a lot of energy, again we are back to thermodynamics. |
16/11/2021 08:13:26 |
I disagree that being vaccinated doesn't reduce the risk of you spreading the disease. Because your immune system is primed to fight the virus, you respond quicker and reduce the seriousness of the infection. As you therefore have a lower viral load you are shredding fewer virus particles reducing the risk of infecting others. Those not vaccinated also act as a reservoir for the virus. The symptoms of the disease are not caused by the disease per se, but your immune systems response to it. Indeed in some cases death is caused by the immune systems over reaction and not the disease. Our complex genetic makeup means that some are more susceptible. |
16/11/2021 07:52:33 |
Gary, you are correct i was mainly thinking about the role of the angle, and the actual profile as well. I will continue to use whatever I happen to have to hand, usually over-engineered, Mainly because I get fed up of fixing commercial products that have been built to a cost rather than longevity. |
15/11/2021 18:33:15 |
The one thing that is always avoided is reducing the human population. Many so called greens point out that the rate of increase is slowing, but that is still an increase when in reality it needs to be reducing. Edited By Keith Wyles on 15/11/2021 18:33:41 |
15/11/2021 14:42:58 |
Gary, it was the angle that I was thinking of in my OP. Somehow I omitted to mention it. Thanks for the comments so far. The reason i said that finer threads being stronger seemed counter intuitive was that if you take it to an extreeme with tpi approaching infinity you effectively get no thread depth. As well as being impossible to thread without cross threading. So there must be an optimum beyond which getting finer shows no benefit. |
15/11/2021 14:36:10 |
As we are effectively "taxing" ourselves with the green initiatives it would seem fair to make global trade fair by taxing, heavily, imports from the likes of India and China to level things up. |
14/11/2021 18:12:29 |
Yesterday I needed some 7.5 " coach bolts, but not having any I cut up some 8mm threaded rod and added washers and nuts rather than make a trip to get some. This reminded me of a question I have often thought of asking. I have a lifetimes collection of Whitworth, Unified, BA and Metric nuts and bolts. Assuming that they are made from the same quality steel which thread form is the strongest and least likely to fail? I understand that finer threads tend to be strongest, although this seems counter intuitive to me. Edited By Keith Wyles on 14/11/2021 18:14:11 |
Thread: Tool steel suppliers UK |
14/11/2021 08:09:29 |
I think that 10 by 10 might be harder to get because of its use in the Paul Sellers router design.
Thread: Book Your Covid Booster! Errr, How? Where? |
12/11/2021 13:45:57 |
Had ours this morning. We were there for about 1/2 hr. Whole process went OK. |
11/11/2021 08:53:27 |
Booked ours on Sunday for tomorrow There were plenty of slots available.
Thread: Agricultural supplies |
09/11/2021 13:50:25 |
Local one was a good source of imperial threads, but they went all metric. But a good source none the less. often use them.
Thread: Telephone / Internet Scams |
09/11/2021 08:36:33 |
We haven't had any since we bought a phone that blocks them.
Thread: Clamp Sets - Thread Type? |
08/11/2021 14:21:33 |
I have what i thought was a Whitworth tap and die set that I picked up secondhand decades ago. They half inch is marked Whitworth, but the rest are dia and tpi. Makes me wonder if it was sold as UNC or Whit with the half inch only determining what it was sold as. Will look more closely at the thread profile. |
Thread: Recommendations for rust prevention? |
06/11/2021 08:10:43 |
Tim |
