Advice on filling a gap in metal
Neil Mccarthy 1 | 25/08/2020 12:47:30 |
43 forum posts | Hi all I am making an end silencer for an air rifle and I have joined the 2 pieces of metal together the top piece is steel and the bottom piece is aluminium. It has bolts securing it but I was wondering is there anything that’s like a mastic or filler that I could run a small bead of it along either side so that the screws in between can not be seen
thank you in advance
mechman48 | 25/08/2020 14:18:37 |
![]() 2947 forum posts 468 photos | JB weld, 2 part epoxy filler, P38 auto filler, Gorilla two part metal filler ( Dries grey  George. |
Neil Mccarthy 1 | 25/08/2020 14:44:23 |
43 forum posts | Thank you I will take a look at it and it will be painted over at the end With cerakote or black paint for the finish
thanks |
Tim Stevens | 25/08/2020 17:23:51 |
![]() 1779 forum posts 1 photos | There is a polyurethane filler made for car body repairs, which is much stiffer than silicone, sticks like stuff and blanket, and unlike silicone is designed to be painted. As you only need a few inches rather than a whole dent-full, you might get a couple of squirts for a pint of ale at your local body shop. Cheers, Tim |
