Drummond b lathe advice
Neil Mccarthy 1 | 31/10/2020 20:34:18 |
43 forum posts | I have bought a project Drummond b lathe and I was wondering if anyone has any pictures or advice to connect the motor to it. I know I will have to make a metal frame just after some guidance please if anyone can. I’m a long way off putting the motor on as I will be doing a full strip repaint and rebuild on this Thank you in advance https://ibb.co/VNjczZG |
David George 1 | 31/10/2020 21:04:25 |
![]() 2110 forum posts 565 photos | Hi Neil the best way of driving these older lathes are with a intermediate shaft and two belts as the top speed is less than 1000 RPM as the bronze spindle bearings limit that. A motor was originally mounted on a cast iron base sometimes with a treadle and gear. I have an M Type and have a little handbook which I can email to you if you send me a message with that address if you want it as it has information on early models and can help with setup etc. David |
Neil Mccarthy 1 | 31/10/2020 21:32:32 |
43 forum posts | Thank you I have sent you a message |
